Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
Fridge freezer . fridge not working door light comes on when open
Freezer works ok
  • 159 Answers
Low gas in the system
Posted on Jun 17, 2009
Fridge light bulb
Not sure how the light socket only has 6V supply? The bulb for this fridge is a pretty standard 15 Watt/230V SES lamp. If you are sure the current lamp is OK I would suggest the door lamp switch has issues. Try pressing and releasing the door switch manually and check that it functions ok without getting stuck or any sluggish movement. This action in itself may fix the problem.
Jan 18, 2014 | Miele KFN8462S Bottom Freezer Refrigerator
Fridge light does not work.
Some appliances have electrical schematics on the back of the fridge, some are hidden behind rear cover. Wire,Switch or fuse..not much else it could be.
Aug 24, 2012 | GE Refrigerators
Fridge part working freezer not
The fridge is just the end of the freezer evaporator. If the freezer isn't cold inside, check the rear panel. It is probably frozen solid with no air getting through. Switch off, leave doors open for 24 hours and be prepared for lots of water to come out. Clean the condenser and make sure the fan inside is ok. Reset the thermostat to middle of the range and be sure to come back to tell us how you get on.
May 17, 2012 | Hotpoint Refrigerators
Freezer is cold, but refrigerator is warm. The fan is running, but I don't feel cold air coming into the refrigerator compartment. There did not appear to be a large amount of frost anywhere, but just...
If the freezer is cold the compressor is Ok. Now if its a two door fridge . Open both the doors while the fridge is On. Press the lower door switch ( the lower light should turn off and you should hear the fan humming sound come on ). While holding the door switch pressed close the freezer door, you should see cold air come out of the slits in the back of the lower compartment. If not icicles have blocked the passages due to the non working of the heating coil.The heating cycle is controlled by the timer switch located near the compressor at the back. Unplug the fridge and remove the timer switch.Note the color of the wires and mark on the old switch. Replace and it will work.Only frost free fridges have heating cycle
Mar 07, 2011 | Refrigerators
Fridge not working but freezer is ok fridge light works
There is probably an ice build up between the two sides of the appliance. There may also be a problem with the damper unit which controls the cold air coming from the freezer side to the fridge. The fridge is controlled by the freezer. Dependant on appliance. The door opens and closes letting the cold air go into the fridge and when the fridge is cold enough the door will close agin. This is not something that you will see happening it is normally concealed behing a diffuser.
Feb 24, 2010 | Freezers
Model gss20iepcbb freezer side works fine ...fridge
on most units they have two controls refrigerator control is electric t-stat that runs compressor freezer control think of it as a door colder freezer door is barely open warmer freezer door all the way open all cooling coils are in the freezer and a fan moves the air to refrigerater side possible problem fan not running
door freezer control all the way closed
light switch broken light staying on door gasket not sealing tight find door switch press verify light shuts off and fan starts
look for torn or damaged door gasket can look from outside with light and see if gasket contacts case on all four sides
freezer is cold enough so compressor is ok hopr this helps good luck ron
Dec 10, 2009 | Refrigerators
Freezer ok - fridge not working - if we defrost it works again - have been told it can be up to three parts - fan does kick in when fridge door is open. which parts need replacing
It will need to be tested if the fan is not working then you need to see if the fan is getting power, if it's the thermal bulb that is defective it could cause the same problem, Does the light come on when you open the door? if it does then test the fan you can locate parts for this at http://WWW.partspros.com.
Nov 06, 2009 | Zanussi ZX99 / 5 Bottom Freezer...
Fridge/Freezer combo - Freezer working fine but fridge is not
There is a duct between the freezer and refrigerator. Sometimes this duct blocks off with ice and won't allow airflow. Open your refrigerator door and check for air flow if there is none the duct needs to be defrosted. turn off freezer/ refrigerator and defrost.
Feb 24, 2009 | Hotpoint Freezers
FFA60 Hotpoint fridge/freezer Red warning light
if i read the english right, the compressor runs but the freezer fan only runs for a short time. no fan then no cooling. there is a fan stat so that the fan only runs when the evap is down to temp. this may be faulty. also on some hotpoint, the fan switches off when door opened. check door switch operating ok. this may also explain problem with fridge lamp
Mar 11, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
75 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
