Question about Brother MFC-465CN InkJet Printer
Unable to Print code 34
I have cleaned the printer head but still have the code 34 showing on the screen.
What can I do about the problem, Is there a way to slove the problem
  • 37 Answers
Check that there is no paper jammed up on each side of where the print head travels.
Easiest way to do this is to power off/on. While the machine is going through its initial startup listen for when the print head travels along its carriage (from right to left). When you hear it, immediately switch off the power.
Open the main body of the printer and hopefully the print head will be stopped midway, you can then check at each end for any jammed paper.
If this does not solve issue, it will require an engineer.
Posted on Jun 16, 2009
Unable to clean
Sounds like the print head is stuffed, It'll be cheaper to buy new printer then mucking around with it
Apr 10, 2014 | Office Equipment & Supplies
Unable to print 4f
good day, unable to print 4f is printer head problem...replace new printer head
Apr 09, 2014 | Brother DCPJ125 All-In-One Inkjet Printer
I have a printer problem, it is a Brother MFC-465CN. the lcd display screen is showing "Unable to Int. 48" can ou help please
This indicates a problem with the print head.
Clean the print head when needed by doing one of the following:
  • Press the Ink or Ink Management key and then select Cleaning. Or
  • Press the Menu key and then select Ink Management, Cleaning.
These cleaning processes do consume an amount of ink.
Nov 02, 2010 | Brother MFC-465CN InkJet Printer
Cannot cleaan printheads
Did you mean "Unable to clean"?If it's that follow this:
Unplug the printer from power cord.Press and hold the "menu" button, then plug the device.You'll see on
the LCD screen a "machine error" code.If this code is 40,41,49 or 4F the print head is defective.If the
error is 50 or 51 there is error in Purge unit and printer require service.If the error is 48 - defective print
head cable or circuit board.If the error is 46 the waste ink tank is
full.Follow this:
1. Pres 'menu', 'mono start' then 'menu' one by one...
2. Press the arrow up or down to go to 'maintenance 80'.
3. Press 'mono start' several times to go to 'Purge'. Finding the PURGE will show some numeric value which is Iassume the number of times the printer had cleaned.
4. Press 'arrow up' key and scroll for number "2" then press "set".Do the same for numbers 7, 8 and 3.
After you have entered this combination, the purge numeric value will be reset to 00000.
5.Restart printer
Nov 24, 2009 | Brother DCP 115C All-In-One InkJet Printer
Unable to clean print heads
Unplug the printer from power cord.Press and hold the "menu" button, then plug the device.You'll see on the LCD screen a "machine error" code.If this code is 40,41,49 or 4F the print head is defective.If the error is 48 - defective print head cable or circuit board.If the error is 50 or 51 there is error in Purge unit and printer require service.If the error is 46 the waste ink tank is full.Follow this:
Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.This will reset the purge count value. Then restart the printer, hopefully without the annoying cannot clean message.
Nov 24, 2009 | Brother MFC-640CW All-In-One InkJet...
Unable to clean,check manual
LCD screen a "machine error" code.If this code is 40,41 or 4F the print head is defective.If the error is 50 or
Oct 25, 2009 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC-665CW 'unable to print 32 and 34'
This is a error about the head unit! it got problem with moving or lockate a position!Service is the solution for these :)
Aug 20, 2009 | Brother Office Equipment & Supplies
Xerox c2424 Printer won't work
34 codes are related to the print head. Print head NVM or the print head itself. Most likely, I would say 95 percent chance of a print head failure.
Mar 01, 2009 | Xerox WorkCentre C2424DN All-In-One Laser...
Brother MFC-240C Error 34
I think error 34 is print head related. I've had the same problem with my 240c but was able to fix it. I took the printer apart to access the print head. It is rather easy to take apart so I won't post a how-to on that. I noticed that the print head was getting kind of stuck on the right side. First, I cleaned the tracts, metal and plastic parts that come with contact with the print head. Then, I lubricated these parts using WD-40. A Q-tip works well for all of this. This resulted in a smoother movement of the print head and solved the problem. I can you can or should use gear grease but I love WD-40.
Oct 29, 2008 | Brother MFC 240C All-In-One InkJet Printer
Brother MFC-465CN InkJet Printer Logo
752 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
