Question about Philips SA2310 GoGear Mp3 Player
Philips mp3 player problem
When..i..connect it to usb it never responds
    President:
  • 828 Answers
Check the power is on...
Posted on Jun 16, 2009
How can i delete music from my player
Philips produces a variety of MP3 players that differ in capacity and design. All of the Philips MP3 players have one thing in common, however: the way that you manage files on the MP3 player. All Philips MP3 players appear as USB mass storage devices when connected to your computer. This means that you can delete files off of your Philips MP3 player using Windows Explorer, much like you would remove a file off of a USB drive.
To delete them, follow this instructions:
1)Connect your Philips MP3 player to your computer using the USB cable provided with your device.
2)Find your Philips MP3 player in Windows Explorer by clicking "Start" and then "My Computer." You should see your device under the section labeled "Devices with Removable Storage."
3)Double-click on your Philips MP3 player to view the files stored on the MP3 player.
4)Navigate to the folder that contains the files you want to remove. Your files are organized based on the type of file. For example, open the "Music" folder to delete music files.
5)Right-click on a file you want to delete and select "Delete." Click "Yes" when asked if you are sure you want to delete the file.
6)Eject the Philips MP3 player before disconnecting it. Click the "USB Mass Storage" icon in the system tray and select "Safely Remove Hardware." The system tray is in the lower-right corner of the screen.
Apr 07, 2011 | Philips GoGear SA3125/37 MP3 Player
Hi my name is sherman & my problem is that my mp3 player just stop workin 4 some reason! the only thing it does now is just lights up when plugged in the charger & read Philips in big bold letters...
mi reproductor mp3 no responde solo cuando lo conecto a la coneccion de la memoria usb aparese el logotipo de philips esto lla me habia ocurrido antes pero lo solucione presionanxdo el boton de reset pero ahora no responde ustedes podrian desirme que puedo hacer lla lo e formatiado varias beses pero no responde
May 17, 2010 | Philips GOGEAR SA6045 MP3 Player
I have philips gogear hdd070/17 mp3 player. My computer is not recognizing the mp3 player. when i connect via usb the mp3 player lights up with the usb connection. i have gone to philips website and...
Have you tried to use it on a different computer other than your own? Try different USB ports on your computer (if you have more than one). Reinstall the software on your computer. Don't install the upgrade. Also you may want to use Rhapsody or Windows Media Player to sync your songs onto the player.
Oct 14, 2009 | Philips GoGear SA3125/37 MP3 Player
Charger broke
There is a proprietary charger for the HDD6330, but it is no longer available through Philips. Try contacting Fox International or some third party seller for the original USB cord.
Mar 13, 2009 | Philips GoGear HDD6330 MP3 Player
In my window media my mp3 player want respond.when trying to put music on it. i change usb cords
Make sure hold/lock is not engaged first.
Here is something you can try:
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
Jan 19, 2009 | Philips HDD1630 MP3 Player
NOT'''' RESPONDING
Connect your mp3 player to the computer.
Run the Repair function.
If the Device Manager does not recognize the player, connect the player to the computer (while the player is in the OFF position) while holding in the volume + button. Continue holding the vol + button for 5-15 seconds until a window pops up on the computer screen that says Found New Hardware Wizard. Follow the directions and it will lead you to do a Repair in the Philips Device Manager.
If this strategy doesn't work, your player is screwed. Call Philips and find out how to get an in-warranty replacement (or take it back to the store).
-Tha Mp3 Doctor
Nov 16, 2008 | Philips GoGear SA178 MP3 Player
My computer don't found my mp3
The HDD1630 is only compatible with Windows XP and Windows Media Player 10.
If you have Windows Media Player 11, unistall it to roll back to version 10.
Install and run the Philips Device Manager from the product CD.
Connect the HDD1630 to the power supply and connect to the PC.
The MP3 player should show as an MTP device. There should be a connection icon on the player screen.
Start Windows Media Player, and select the SYNC option to transfer music.
Feb 17, 2008 | Philips HDD1630 MP3 Player
Philips SA2310 GoGear Mp3 Player Logo
104 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
