Panasonic Workio DP-4530 Grayscale Copier
Problem for Panasonic Workio DP-4530 Grayscale Copier
Our office recently aquired a Panisonic DP-4530
By heather_ratt on Jun 16, 2009
Our office recently aquired a Panisonic DP-4530 hoping to use it as a network printer. Much to our dismay none of our computers have serial ports. Is it possible to connect this machine using a USB cable and if so how would one go about doing it.
Comments:
Jun 16, 2009
- It does have an ethernet port. I really have no idea what to do with that.
Solution #1
posted on Jun 16, 2009
Not Rated)
sandmanmac
Rank: Wiz
Rating: 84%, 791 votes
I assume you mean "Parallel"? regardless, you can pick up a "Parallel" to "USB" adapter cable at your local electronics store to convert it, and then install it the usual way. Although i'm surprised that there isn't an ethernet port on the machine, because I believe it came standard with the Printer interface option, but if you bought it used it may have been removed.
Hope this helps.
Please rate solution
Comments:
Jun 17, 2009
- Setup is a little more difficult on tcp/ip (ethernet) if your not familiar with IP addresses, etc. Give the adapter a try
Was this helpful?
Yes
No
Popular Solutions for Panasonic Workio DP-4530
Questions and Unsolved Problems for Panasonic Workio DP-4530
Do you recommend Panasonic Workio DP-4530 Grayscale Copier?
Answer
Answer
my hp photosmart c4400 series, when i want to print it will say catrage jam
Answer
how to solve the toshiba problem having error code 0070
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Copiers Experts
Top Copier & Fax Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
