Question about Kitchen Ranges
My coleman stove does not let the propane pass from the hose to the burner. I have determined that the hose is releasing the propane as I can depress the nozzle and get the gas to flow. The stove is clean and the connector is clean and clear at the point of hose insertion. Seems the blockage is happening somwhere else. There is no evidence of corrosion or breakage or pinching of the small tubing going from the connector to the burners. The burners are not damaged or gooped up. What can I do do try and clear any suspected blockage?
This is a camp stove issue. I fixed it with my tire pump. I opened up all the valves, duck taped the hose to the stove valve and pumped air thru the system. No more blockage. Works like a charm.
Susann
Posted on Jun 17, 2009
Can I buy a replacement grill?
You could try Coleman, they might be able to supply one.
The Coleman Company, Inc.
3600 North Hydraulic
Wichita, KS 67219
1-800-835-3278
TDD:316-832-8707
Jul 03, 2014 | Coleman Vintage Bernzomatic Deluxe Propane...
Can a 20lb tank be hooked up to a Coleman 2 Burner Stove 5430A
Yes. There are multiple adapters made to fit this application. Your local walmart most likely will have them. http://www.walmart.com/ip/Coleman-5-High-Pressure-Propane-Hose-and-Adapter/19897422
Sep 18, 2013 | Coleman 2 Burner Propane Stove 5430E700
Coleman 5423b701
Try Coleman directly.
Wichita, KS 67219
1-800-835-3278
Sep 01, 2013 | Coleman Camping Stove 2 Burner Propane W/...
Need parts
If there is no nearby repair dept, try Colemn.
Wichita, KS 67219
1-800-835-3278
Mar 31, 2013 | Coleman Vintage Bernzomatic Deluxe Propane...
How do you convert a coleman 425e into a propane stove
Is there a reason or a need? I cannot imagine why you would want to, except as a point of interest for your camp kitchen. A new propane stove would work better and not cost all that much, relative to the work and cost of putting fittings, pipes and burners into the old stove box.
Feb 07, 2013 | Coleman 425e 2 Burner Vintage Used Camping...
The electronic ignition (piezo lighter) on my Coleman 2-burner propane camp stove just quit sparking to 1 burner. It still lights the 2nd burner. A fix?
I've had this issue a few times. Complete cleaning of the under side of the burner and all components of the ignition system fixes it every time.
The slightest bit of carbon build up is the probable cause. I would suggest cleaning the contact with 400 grit or higher emory cloth. This will remove any contamination from the ignitor,
Aug 06, 2012 | Coleman 2 Burner Camping Propane Stove W/...
Why does my coleman stove regulator leak gas from the hole on the top of the regulator
Its a safety feature of the regulator. The regulator is designed with a pressure release valve. This has happened to me twice: once with a carbon dioxide tank for my kegerator and once on my propane stove. In both cases I left the regulator (designed with a max pressure rating of X psi) attached to a full bottle in the sun. The heat caused the pressure to exceed the limit of the regulator and the release valve popped. A welding supply store may be able to reset/replace the mechanism but in my case I just bought a new regulator for about $15.
Aug 14, 2011 | Coleman 2 Burner Propane Stove 5430E700
I have a Coleman two burner propane campstove and
Try cleaning the carbon out of the burners.
Jun 22, 2010 | Coleman Gas Grill Stove
Need to fix regulator for coleman stove 5410708
Just where the regulator attaches to the burner there is a small nut that may be loose. If you look closely at this and turn the regulator (stove off and hose detached!) you may see the nut hat turns easily. Tighten it and make sure the regulator does not rotate too freely, but still turns to adjust when attached to the hose or the smaller gas cartridge, if using that. Test carefully after this.
Feb 06, 2009 | Coleman 2 Burner Propane Stove 5430E700
Coleman propane stove problem
The connector for attaching the regulator to a disposable propane cylinder has a sintered bronze filter in the tip of the brass probe tube that is prone to clogging, or the bronze pellets get mashed down over time, restricting gas flow, and this will cause a portable grill or camp stove to perform poorly. The filter is so fine that it takes very good eyesight and bright light to see that it isn't solid metal, or use of a strong magnifying lens. The best solution is to buy a new Coleman regulator assembly. If you are unable to get a new regulator assembly and have the skills and the tools, you can try drilling a very small hole on the side of the probe tube with a #60 drill bit, just below the bronze filter, but near enough the end of the tube so that the hole will be past the plastic seal when the disposable cylinder is fully screwed into place. You should avoid drilling directly into the end of the probe tube, as the end of it is used to depress the Schrader valve in the disposable cylinder to allow gas to flow. A #60 wire gauge drill bit is only 0.040 inch (1.016 mm) in diameter, but makes a hole large enough to supply sufficient gas to a portable grill or a dual-burner camp stove. If you choose to perform this work, the probe should be unscrewed from the regulator body and the Schrader valve core in the probe tube should be removed before drilling. Be sure to clean all brass and bronze particles out of the probe tube before re-installing the Schrader valve core and the screwing the probe into the regulator. Use a removable-grade thread locking compound to secure the probe in the regulator body and don't over-tighten it, so as not to crush the rubber gasket. Allow the thread locking compound to cure for several hours before attempting to use the regulator. Keep in mind that this modification increases the likelihood of dirt getting into the needle valves and jets of your stove or grill, which can cause maintenance problems in the future.1_28_2013_4_49_27_pm.jpg
Aug 19, 2008 | Coleman Gas Grill Stove
Kitchen Ranges Logo
124 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
