Question about HTC Touch P3450 Smartphone
The battery is pathetic. Need to recharge twice a day. Any suggestions for a better or different battery? Moreover How do I use GPS on this set
    Problem Solver:
  • 5 Answers
If your battary runs out really fast it could be that your bluetooth is switched on. With bluetooth on this phone uses a lot of power and the battary is empty really quick. The HTC Touch p3450 has no built in GPS. You need to buy an external GPS device and connect to it. How to do this can be found in the manual of the GPS device.
Posted on Jun 18, 2009
Garmin gpx files
After you are finished one bike ride, look for the settings option to choose "end this ride" or to save it. This way when you do another ride it will start a new separate gpx file.
Apr 21, 2014 | Garmin nuvi 500 GPS Receiver
Won't hold a charge
Hey
How old is the garmin? The battery is probably going bad and would need to be replaced.
Sep 12, 2008 | Garmin Nuvi 660 GPS Receiver
Battery charging
Hi Patrick,
A rechargeable battery will eventually fail to accept a charge - just like your car battery.
The number of recharges a battery will be able to accept is dependent on a number of things, such as: temperature, if it is run to almost nothing before recharging (or if it is recharged after only being discharged slightly), how much of a load is on the battery and how fast (high amperage) or slow (low amperage) the battery is recharged.
Generally, cooler temperatures are better for batteries, as is using the battery almost completely before recharging rather than topping off after minimal usage, small loads are better (you don't have a choice in your GPS watch tho) and a slow or "trickle" charge is better than a fast, high current charge (you may not have a choice on this either). A few hundred discharge / recharge cycles is not uncommon - significantly less if the battery isn't cycled properly or used in harsh conditions.
I hope this helps!
Jul 01, 2013 | Bushnell Neo Plus GPS Watch
I got TomTom for a birthday gift in January. I only used it twice. How long does it hold a charge and how do I recharge it? Need to know asap. Thank you.
One full charge will hold good for approximately 3 hours.If you got it in January, it is better to recharge it. There are two easy ways to charge it. I assume you have got two different cables with it. One connects directly to the car cigarette lighter/12V socket. The other cable can be connected to a USB port of a computer. Tom get charged while connected to the computer also. On the outside chance you did not get the cable or cannot find it go to this link below to get the cables.
http://www.tomtom.com/products/accessories/index.php?AccessoryCategory=-1&Lid=4
Please note Tom charges through the same port (USB) as it connects to the computer, which is it at the bottom of the Unit.
May 19, 2010 | Tomtom ONE 130 GPS Receiver
Low battery. Cord plugged to dash does not recharge
The battery might need to be replaced.. These types of rechargeable batteries are good for around 1 year.
Good day ;o)
Sep 17, 2009 | Garmin StreetPilot C330 GPS Receiver
HTC Touch Flo 3450: Battery is pathetic
Well you should make sure that your wi-fi is disable because enabling wi-fi consume alot of battery and disable bluetooth as well. Do not overcharge battery more than 2 to 3 hours.
Regarding GPS, No, the HTC Touch P3450 doesn't have the GPS hardware. It cannot support GPS
Jun 13, 2009 | HTC Touch P3450 Smartphone
Will not power on
Did you use rechargeable batteries? The Garmin seems to be extremely picky about enough voltage. I had good rechargeables which I use in my foto flashlights, but they did not suffice for the Gamin. Simple non-rechargeable batteries ones solved my problem. Not good for the environment, but for my bearings...
Apr 21, 2009 | Garmin GPSMAP 176C GPS Receiver
Recently after working one day the next day when i tried to use mt tom tom 710 it wouldnt switch on but the mains light was lit when plugged into cig lighter
Try giving it a full charge. I used different model Tom Tom that would not turn on even if plugged in until after the battery was recharged.
Oct 10, 2008 | Tomtom GO 700 GPS Receiver
Garmin GPS 45
It is probably one of the following:
1)Old Software
In 1999 the GPS satellites were reset and the new almanac data had to be loaded into the GPS 45 for it to continue to work. It was not uncommon for that model to quicly kill a set of batteries when it is having difficulty acquiring, which would cause it to shut down in order to save the batteries for its internal memory.
I just did a quick search of the Garmin website and it appears they no longer support that model. If you go to their support page and send a request for a software update they can probably e mail it to you. The update is free but to down load it, you need a PC interface cable (RS232 serial port connector) Part Number: 010-10141-00 Suggested Retail Price: $ 38.09.
2)Bad antenna
To rule this one out, borrow an antenna from another Garmin 45 or Garmin 48, or plug the unit into an external antenna and see if the unit still shuts down. The drawback to this method is that you can buy a new GPS that is superior to the one you have for about the same price as an external antenna.
3)Bad batteries
If your batteries are low, the unit will automatically shut off to protect its internal memory. I tried a lot of different batteries in my 45 and I found that Eveready alkaline batteries worked best. Rechargeable nicad batteries don't work very well because they fool the battery meter. Newer models have a setting to specify that you are using rechargeable batteries.
Ultimately the best advice I can give you is buy a new GPS. For less than $150 you can buy a new model that is more accurate, more reliable, stores more waypoints, has a better display, is easier to use, and gives you more valuable information.
Please rate this information as helpful.
Jan 23, 2008 | Garmin GPS 48 GPS Receiver
HTC Touch P3450 Smartphone Logo
95 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
