Question about Troy-Bilt Pony Garden Tiller
Craftsman 5 hp briggs with mag. its old but runs just no power.
The pull start was squealing, my son poured oil on it .didnt work . i fix that but now it runs but no power like before..
    Scholar:
  • 81 Answers
When the pull started is squealing you need to remove the "ratchet" which is located under the shourd that covers the flywheel. Remove it from the engine and disassemble making sure you do not misplace any of the bearing balls that are in there. You will probably find some dirt in the cup. Clean it really well along with the balls and reassemble. The only place you are to put oil is in the very top of this rachette, there is a small hole there, put a few drops of oil in the hole, trying not to get any oil elsewhere on the rachette. Oil anyplace else in this area will make it hard to start as it catches and retains dirt. Make sure there is no oil elsewhere also.
Posted on Jun 17, 2009
2009 elantra SE, whistling sound this morning after a rainy night when i turned the key to start, it had delay for few sec and long whistling noise then started!
What you heard was probaly the drive belt, if it stopped after a few seconds, take a glss of water and pour on belt while running and see if it does it while pouring the water, this also works to tell if you have a bad belt or idler pulleys, if the squealing goes away its a belt if it keeps squealing its the idler. If its an actual whistle, before it starts, who knows......
Dec 19, 2017 | Cars & Trucks
My sons used the unit 2 to 3 times (8 hrs. total). They put the unit away 5 years ago and has not been started since. I just got it out to try to start. The oil level is good and I added new fuel. But,...
May be partially seized from sitting. I'd pull spark plug and pour/spray some WD-40 or similar in cylinder and let it soak for a while and keep trying to pull rope once in a while until it lets loose. Once it starts to turn over, install plug and see if it will start and run for a minute or 2 then change oil and should be good to go. If not, get back to me.
Feb 05, 2011 | Briggs & Stratton Pressure Washer...
How many quarts of oil does a 1993 Chevrolet Silverado 1500 w/4 wheel drive take? My son wants to change the oil.
4 1/2 to 5, including the filter. Pour in 4, start the motor and run for a minute or two, shut off and recheck oil. Add as needed.
Nov 10, 2010 | 1993 Chevrolet C1500
How much oil do i put in my 2000 dodge stratus air conditioner compressor?
Most the time its 8 oz,, need to check with the seller and see the specs on compressor,it should say on ac compressor
Aug 22, 2010 | 2000 Dodge Stratus
My son poured gas in the oil line. i dumped the gas out but the mower will not start now.
Open the oil drain plug let out all oil and let sit open for a few days. Then fill with some new 30W and try to start again.
Jun 23, 2010 | Toro Lawn Boy Self Propelled CARB Walk...
Squealing losing power not chargeing batter changed alternator
If the belt is 3 yrs old or older, change it. If it has oil or anti-freeze or grease on it, change it. If new, add more tension to the belt.
May 13, 2009 | 1994 Isuzu Rodeo
1997 dodge avenger 2.0, belt squealing
Hi
The Power Steering Belt tension requires adjustment, to give it more tension, to cure the slipping, resulting in the squealing, or perhaps renewal, due to cracking or excessive wear.
Your Power steering Belt, belt is your primary problem.
Good Luck !
A FixYa Would Be Nice, Thank´s......John.
Mar 04, 2009 | 1997 Dodge Avenger
Car stalled and oil poured out the bottom
you probably cracked the block or punctured the oil pan if it was a rattling kinda noise (cracked block) one loud thump or slap probably the pan
Dec 22, 2008 | 2000 Dodge Caravan
Yamaha ttr 90 dirt bike
well i had the same problem with my old ttr 90 it smoked realy bad so i took off the top end an looked at the piston rings an they were fried so i bought a new piston rebuild kit an put it in an changed the oil an it ran like a champ an didnt smoke so thats what i think ur problem is
Oct 11, 2008 | Sport & Outdoor - Others
Troy-Bilt Pony Garden Tiller Logo
139 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Jim Parker
Jim Parker
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
