Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Files turn to shortcuts
Files I move to my mp3 player turn into shortcuts
I can't delete files using the PC
Seems like you got a virus in your mp3 player. Try scanning the device with an antivirus first. You can use the program unlocker to delete the files which are adamant to go away.
Jul 19, 2017 | Samsung YP-S3JAB Digital Media Player
I add ebooks to my coby mp282 and it shows the title of the ebook but the file dont open.. how am i suppose to open the file?
If you took them from your PC to the device, it might have only made shortcuts to the files. Check and see if the files are larger than just a few Kb instead of hundreds of Kb.
Sep 17, 2012 | Coby MP828 MP3 Player
All the folders in my samsung i-pod YP-Q1 have become shortcuts that refer to 'uIaU3k3kzmh4Otjy73o.exe' and does not open
Propabely it is a surface disk problem which damaged your files or a virus could do so,try to open the folder by right click and choose open, if it is the same problem then it must be a virus and you have to reformat it, sorry for that . You have to scan your pc also for malware, viruses.
May 17, 2012 | Samsung Yepp YP-Q1 (8 GB) Digital Media...
I sync music onto my mp3 player and it keeps saying no files
Either there is an error with how the files are being placed in the device, such as shortcuts, or the files you placed are not supported by the device.
There should have been instructions that came with the mp3 player, try reading up on where the files need to be placed. Make sure you didn't change any folder names (or maybe you have to create a folder before syncing.) Also, doing a quick google search, I found that it supports .mp3, .wav, and .wma files. So be sure to check if the files you sync'd are the right format. (Right click the music file, properties, Type of file: ____) I can't imagine that being the problem, as most music is already in mp3 format.
Good luck.
Mar 06, 2011 | Eclipse CLD2 MP3 Player
I need a driver for a touch screen polaroid 4gb PMP280-4 mp3 player .
you dont need a driver. you got the driver w/installation cd.you need an icon(shortcut) on the desktop so you can find and start the program to convert or encode the vid files to the correct format.btw, on the box of mine it is "pmp280c-4". the problem is that when the setup disk installs the software it DOES NOT put the icon (shortcut) to the software on the desktop like it says it did or will! the software and device are ready but one cant find the program. i have win vista and i found the program with: start button on the taskbar (at the far left), click it and then click "all programs" and then look for "media player utilities 5.20". click that, and then right click "video converter" and then "point" to "send to" and then click "desktop (create shortcut)". this will do what the setup program did not do-it puts the shortcut on the desktop.
Sep 04, 2010 | Polaroid Audio Players & Recorders
Help
you might have copied the shortcuts alone instead of copying the whole music files into the player.for e.g if you have gone through the following sequence
start>recent items>right click on the file>removable disc then only the shortcuts alone would have been pasted in your player.please go to the folder containing music files and the copy them to send it to the player.
else the best way is to synchronize the player with the computer using music software like real player or windows media player etc.you can learn about this in the help (press f1) in the software to know more about it.
P.S: please format you player before doing the above actions.thanks
Jan 01, 2010 | Sony NW-E103 MP3 Player
I cannot store music on the mp3
Use Copy and Paste. Dragging might creating Shortcuts only in your MP3 so when you double clicked shortcut in MP3, original file starts play.
Aug 24, 2008 | Sony NW-A1000 MP3 Player
No files found on mp3 player
One very important tool when using file transfer is windows explorer. Keep your flash drive connected. Go to Start/Accessories/windows explorer (or with the keyboard shortcut: the windows + the letter e).
Need more info?
May 24, 2008 | Centon Electronics 1GBMP3-001 MP3 Player
Is there an easy way to delete all the music off of my mp3 player?
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
or
http://www.sandisk.com/DriverDownload/driverList.asp
-Tha Mp3 Doctor
Apr 17, 2008 | SanDisk Sansa E280 MP3 Player
it says in the user manual that you have to hold down the power/menu button for about 15 seconds
Feb 19, 2008 | SanDisk Sansa E280 MP3 Player
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
48 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
