Question about Samsung T220HD 22 in. LCD TV
Antenna signal when setting up to select Air or Cable when choosing Air do I then choose Digital & Analogue or just Digital.
  • 92 Answers
Just digital
Posted on Jun 16, 2009
When i do a factory reset on the Sharp Aquos and it says air or cable, which do i choose if i have satellite
You should choose 'Cable', which is the same input system as Satellite. Air is the coax cable on the back of the set for an analogue connection, over-air signal from an aerial.
Jun 09, 2018 | Sharp Televison & Video
How do I run a channel scan on new tv
Once hooked up go into the menu under set up. You will have to choose between air/antenna or cable. Select your choice and then it will prompt you to do a channel scan automatically or manually. Select automatic. If you are doing this as an antenna it should prompt you as to whether you want to scan for digital, analog or both. Select both.
Jan 27, 2016 | Televison & Video
How do I watch normal tv on my audiosonic television ?
That depends upon which source your "normal" TV is connected. If you have a cable box using a coax cable, then you will either select the DTV source if the cable box uses digital output or a digital over-the-air antenna, and ATV source if the box is using analog signals or if you are using an analog over-the-airwaves antenna. If you are using a cable box but have an HDMI cable connecting it to the set, then you need to choose HDMI1 or 2 as appropriate. If you have a box that uses the red-black-yellow RCA cables, then select the AV input. Remember that for ATV and DTV inputs from a cable box, you usually have to tune the set to either channel 3 or 4 and use the box to change the channels.
Jan 05, 2016 | Televison & Video
Do i need a digital set top box for conia cpdp4290 2007 model in australia
possibly yes but check what your input is set on to get antenna signal it can not be set on cable either AIR or antenna.
Jun 17, 2015 | Televison & Video
Removed TV from cable,connected a antenna.Changed setting to antenna.All I get is a Blue screen like no signal is coming through.Connections are good. It seems like a setting is missing. Help
Hi, is the tv set to analogue broadcast, should it not be set to digital. I have a Grundig that does the same thing on analogue.If your tv is and/digi this might be the issue.
Jun 16, 2015 | Apex Digital Apex At2002 Color Tvs
Loss of Digital Shows??
U have cable's or dish's boxs?unplug,replug the box for the software to down load to upgrade.Unplug,replug the tv.Go to the menu set for Air or Cable then rescan all channels
Oct 26, 2009 | iLO V27DMBX Television
Unable to tune in the digital programs after digital switchover . there is no analogue signal. when i click on menu it allows me to select all but 2 of the options and tuning is one of the options that it...
If you were unable to tune in digital before the switchover then most likely your digital reception is poor. Unlike analog signals you will not see anything on screen until it can lock in. You may have to repoint your TV antenna or check what size of antenna you need at antennaweb.org
Sep 10, 2009 | Televison & Video
I have my cable coax connected to the UHF, VHF, CATV input. If I connect cable to Digital Antenna In input and do channel search will I receive local digiatal broadcasts or do I need to split the coax to...
You need to put a compatible cable decoder box between the cable and TV as the sanyo will only decode analogue cable signals via the catv UHF vhf input
the digital antenna in is for digital air broadcasting signals only
Jul 25, 2017 | Sanyo HT27546 TV
We are getting a weak signal, no picture.
Make sure that at the box you are connecting the antenna in the right "Ant" connector at the converter and using the other connector to jump to your TV set "antenna in" connector, and have your set tuned in channel 3 or channel 4 (try both, just in case).
Another thing you may want to check is that your TV is set to receive channels "From the Air" not "cable". use you TV menu selections to find this setting.
You may also choose to connect the signal transfer from the converter to the TV using a 3 cable set of Audio (red and white RCA connectors) and a video cable (yellow connector) and setting your TV to get the "signal input" from the right input selection, (it could be labeled as Front, or Video or Aux) in this way you will get a even better image quality.
Then press "menu" on your Digital TV converter remote, then if and when you can see the menu in your TV, look and go for auto setup so the converter can look and find all the available channels in your area.
If there is nothing broken you should be able to get you Digital programming right there.
Jun 13, 2009 | Insignia Digital-to-Analog Converter for...
Samsung T220HD 22 in. LCD TV Logo
85 people viewed this question
Jerry Greenberg
Jerry Greenberg
