Question about Sony NWZB133F MP3 Player
I have the same problem.
I formatted my player after connecting it to the pc. the moment i disconnected from the pcs i din't found the player working. again i connected the player to the pc and it couldnt recognise the player at all.
You **** you should have never formatted it in the pc. there is a formatting option in ur walkman settings menu. now u contact sony websit or ur dealer. may be WINAMP media player will detect ur walkman
Posted on Jul 13, 2009
    President:
  • 828 Answers
This time you are reformatting that player, i think that connection between is malfunction...
Posted on Jun 16, 2009
Reset timming
Powerful DIN rail PCs with PC 104 UNO 1100 Advantech
No idea what you've done but here is the manual and drivers link
Mar 31, 2014 | Advantech UNO-1172AE-A33E UNO-1100...
94 Honda Prelude Factory Car Stereo/CD Player
The BUS wires are a serial data link, probably incompatible with other makes of CD player. I'd hesitate to connect it to +12v, this may cause damage. If anything try connecting it to BUS.C through a 1kohm resistor to start with.
Perhaps you need something like this to make it work. http://www.caraudiocentre.co.uk/product_m-alpine-kcm-122b_p-20941.htm
Oct 21, 2007 | Car Audio & Video
Tip
Connect MP3 Player To Computer and Transfer MP3 Songs From Computer To MP3...
To successfully transfer songs either MP3 or WMA files to your MP3 player follow these steps.
1) If your device came with a CD insert this into your computer and follow the on-screen instructions.
If the device has no CD most PCs will recognise the device and update the drivers automatically once you have connected it via USB cable.
2) Connect the device to the PC using USB cable. With many players this is the only means of charging the device.
3) On your computer go to 'Start' - 'My Computer' and you should see the device listed as a USB Mass Storage or Removable Disk.
4) Click and highlight the songs you want to transfer to the MP3 player. You can either drag and drop them directly into the USB Mass Storage Folder shown in Step 3 or you can right click the song file and select 'Send To' USB Mass Storage Device.
5) The songs are now on your MP3 player.
6) Disconnect the player from the USB cable. The player will take a moment to update and you can now play the songs on the player.
Note: In order to transfer music files from a CD these must first be converted to MP3 in order for the player to be able to play them. To do this you can use Windows Media Player to 'Rip' the songs onto your computer in MP3 format. From here use the steps above to transfer them onto the player.
If your MP3 player has video capability these files will need to be converted in to a format that the player can handle. To do this, use the software that came with the device on the CD or you may use a free converter like this one if the original software is lost.
Hope this Tip has helped.
Please do reflect this and indicate your rating using the Yes/No buttons below.
on Jan 01, 2010 | Audio Players & Recorders
Cand incerc sa incarc melodi in el din pc nu le salveaza si scrie file not found.ce sa fac?
Salut! Incearca sa-l formatezi. Daca nu merge s-ar putea sa fie arsa memoria. Si din cate stiu nu prea se pot repara...poate merge totusi cu format. Succes!
Dec 04, 2009 | Nextar MA933A MP3 Player
Zune USB problem. Connects/Disconnect constantly.
Well the microsoft Guys said that when it appears not to work as expected then you need to reset it. Here is the way to do this. Good Luck!
Sep 19, 2009 | Microsoft Zune JS8-00001 Digital Media...
Deleted songs from sansa e260 still show up on the menu
Turn the player off.
Push the HOLD button to the locked position.
Press and hold the RECORD button while connecting to PC.
Let go of RECORD button when you see Welcome to Recovery Mode on the player's LCD.
You are now connected in, you guessed it, Recovery Mode. Open My Computer and you will find a new removable flash drive labeled, 16MB-FORMAT.
DO NOT ATTEMPT TO FORMAT THE 16MB-FORMAT VOLUME!!!
Open the 16MB-FORMAT volume in My Computer and create a new folder on the drive in its root directory. Name the folder sansa.fmt, use the Safely Remove Hardware icon in the system tray, and disconnect the player from the PC. The player should now format itself. If all goes well the format will be successful. If not, I suspect you might have a defective internal memory module. If it is defective, you can replace it with one from another v1 or Rhapsody model unit. You can often find defective players on eBay for parts. The memory module from the e250, e260, e270, or e280 will work just so long as its from a v1 or R model.
Aug 28, 2009 | SanDisk Sansa e260 MP3 Player
My pc accepts mp4 hardwear momentarily then rejects it
A connection is possibly loose, seems like a hardware problem that would require service. Check the usb connector and its pins.
You have tried it on two other pcs? what was the result there did it work? If it worked on both fine, then the issue is on your computer and not on the mp4 most likely.
Please clarify.
Jan 30, 2009 | Audio Players & Recorders
OPAL won't charge.
Get the firmware upgrade for the player. If the pc will not recognize, force recognition:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If this does not work, I suggest that you reformat the player by using the WindowsTM format command on the unit. To reformat the memory
1. Right click on the device within the Explorer or My Computer window
2. Select the format command (full format) to reformat the internal memory of the device.
3. Reinstall the firmware from http://download.rcaaudiovideo.com/downloads/opal_fwutility_v2.3.0.exe
Jun 08, 2008 | RCA OPAL M4001 MP3 Player
Zune will not connect to PC
Make sure the hold/lock is not engaged
Make sure the OS is compatible
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Dec 26, 2007 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Player does not play
Hi, I had the same problem, MiMusic wouldn`t even recognise there was a disk connected although I could see it in My Computer.Found the answer on internet.
Attach it to your p.c. Then go to My Computer and highlight it. Right Click it and a box will appear . Go to FORMAT and format it. Another box will appear and ask if you really want to do it as data will be lost. Answer YES. Then format it. Disconnect from your p.c. Turn it on and you will be able to access the menu facility. Follow the instructions and goto CREATE LIB, BEFORE you put any music on to the thing.
I found it created library as soon as I disconnected it. BACK UP anything you have on it first as it will be wiped. It is working perfectly now and MiMusic is too. Yippee. Pat.
Jul 07, 2007 | Goodmans GMP33000S MP3 Player
Sony NWZB133F MP3 Player Logo
248 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
