Question about HP Officejet Pro L7680 All-In-One Printer
Bottom feeder paper is continuously getting "chewed up"...
    President:
  • 828 Answers
Clean the metal gear or put some oil on the metal inside... so that he will not bite your paper inside
Posted on Jun 16, 2009
Paper jams in the feeder on the left side , tried to opentop cover does not allow me to open back. how do I GET THE ROLLER from curling the paper?
One reason for paper jams is due to some obstructions in the paper path. Remove the sheets of paper from the feeder. Grab a flashlight and look into the paper feeder. Clear the feeder from any foreign objects or debris that could cause "curling" of the paper. If feeder is clear, open the printer cover and ensure the paper path is clear in the cartridge area.
Unplug and replug the printer into the power source to reset it. When the printer turns on, try to print again. If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Jul 28, 2011 | Lexmark X6650 4-In-One Wireless InkJet...
Paper jams
Paper jams - Kodak Printers
Feb 19, 2011 | Kodak Office Equipment & Supplies
Paper feeder stuck
If the paper feeder stuck, do the following:
  1. Gently pull any jammed paper out from the output tray or sheet feeder.
  2. If paper is stuck inside, open the printer cover and remove the jammed paper, including any torn pieces. Then close the printer cover.
  3. If paper remains near the sheet feeder, press the paper feed roller lever inside the paper feeder to release the jammed paper, then carefully pull it out.
  4. Load the paper correctly.
  5. Press the cp_button_14.gif stop button to resume printing.
  • If the printer continues to jam or misfeed paper, and you are certain that there are no foreign objects lodged down inside the paper feed area, your printer may require service. Please call Epson technical support for further assistance.
  • Jan 29, 2011 | Epson Office Equipment & Supplies
    Paper is pulled sideways infrom feeder....
    Look for possible dirt or sticky material in the roller. use some methy spirit to clean the rollers that take up the paper.
    Check if there is any paper stuck on to the rollers, if so remove and clean.
    Check if there is any wearing of the rollers, alignment of the rollers.
    Finally use printer paper as thin paper might be chewed in.
    Hope you check with my advice.
    Aug 21, 2010 | Canon PIXMA MX310 All-In-One Printer
    The paper keeps jamming during feed I have changed it but it still jams, I think there is a fault with the feed section at the bottom but I cant find a manual that shows technical details for repairs so I...
    Did you replace paper feeder with new one? Most paper feeder problem are rubber at paper pick up roller (bottom side) and small spring at bottom paper pick up roller. Check for "something" slip at paper feeder and lubrication at paper feeder mechanic.
    Feb 02, 2010 | Epson Office Equipment & Supplies
    Printer chewing the papar
    This is due to problem with paper feeder roller. Replace the will resolve your problem.
    Revert back for more assistance.
    Feb 01, 2010 | Canon PIXMA MP830 All-In-One InkJet...
    My epson stylus r265 wont feed paper it just chews it up
    Most printers now are made of plastics and very light…when you store your printer in hot enclosed place that will affect the printer, and you can see the result on the prints, paper feeds, etc. you need to clean the printer if you did not used for over one week by conducting software head cleaning and open the door for the paper feeder and clean all around the inside…you have a jammed paper in the back that push the feeder out from the track and end up been shredded, make sure that all the doors closed very good and that the paper tray has the side track very close to the paper from the sides so the papers do not move side way when they go inside the feeder… Let me know if this what you are looking for, and please rate my service so I am able to continue serving everyone and improve on it.
    Sep 21, 2009 | Epson Stylus R265 InkJet Photo Printer
    X5150 printer turned; no paper in printer; paper feeder continues
    Unplug the printer and then open the front and look at the Rear right side and you should see a small ce6913f.jpg
    Tab If it is bent then gently with a pencil or pen push it back and try printing if it still gives you problems then contact Lexmark and if you still have a warranty they will replace it if not then you will have to get a new one.
    Best suggestion for a new printer that is almost the same is the Lexmark X3550 printer.
    Apr 07, 2009 | Lexmark X5150 All-In-One InkJet Printer
    Problems with paper feeder-wont feed through-chews up paper
    I HAD THE SAME PROBLEM A MONTH AGO. I LOOKED WHERE THE PAPER LOADS AND THERE WAS A PAPER CLIP JAMMED IN THERE. I HAD A HECK OF A TIME GETTING TO IT, BUT I DID. AND IT WORKS FINE. MAYBE SOMETHING IS THERE.
    Jan 31, 2009 | Canon PIXMA MP130 All-In-One InkJet...
    HP Officejet Pro L7680 All-In-One Printer Logo
    52 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
