Question about Maytag Atlantis MDG7400AW Gas Dryer
Dryer runs, but no heat , gas dryer and everything is reasonbly clean. It is a maytag model#mdg7400aww
  • 6,784 Answers
Check the following components to combat this issue.
1. Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
Posted on Jun 16, 2009
I am using a Maytag Atlantis MDG7400AWW gas dryer. It is not heating. I have replaced both solenoids that open/ close the gas valves. The heat coil glows orange, and the thermal fuse is showing 0.0 when...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 06, 2011 | Maytag Atlantis MDG7400AW Gas Dryer
Sometimes having heat and sometimes having cool air Maytag Atlantis dryer, Model # MDG7400AWW
heatman101
May 03, 2011 | Dryers
Gas Dryer only runs burner once after starting, why
Lets see, you have power to the gas assembly so the fuse is good and the ignitor will fire up. But she won't fire off again. The flame sensor is working because the ignitor is coming on and off. That means the control thermostat is working so everything is working. So what's the problem. Simple.933a1bb.jpg The solenoid coils heat up and quit on these machines with a little age. Very difficult to diagnose unless you know the trick.
Cheap parts link, your part sir: AP3094251,
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 14, 2010 | Maytag MDG2706A Gas Dryer
Ihave a maytag atlantis gas dryer model mdg7400aww that when I first start it up it gets warm but then stops heating? what is the problem
The operator coils get hot and quit on these ,when they get a little age on them, quite difficult to diagnose. If the coil feels hot to the touch after failure then that is a clue. f00c98f.jpg
Mar 05, 2010 | Maytag Atlantis MDG7400AW Gas Dryer
My Atlantis won't start after I ran it with the lint filter out
might be a sock or something in the blower housing jamming the motor
Sep 28, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Dryer works only on high heat; will not respond to touch pad.
Replace the gas valve coils. They have gotten weak and do not open on the next call for heat.
Aug 30, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag MDG7600AWW not staying hot
Hi, It sounds like that the coils on top of the gas valve are not opening the valve later in the cycle. They get weak enough ovwer heat and will not open the valve. You can listen for the ignitor to click on and then you can hear the gas ignite. If late in the cycle you hear the igniter click and then no gas ignition, change the coils.
You should also make sure the vent going to the outside is clear of any lint or kinked.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jul 13, 2009 | Maytag MDG7600AW Gas Dryer
Gas Dryer does not run, light comes on in drum, everything else is dead.
do you mean it doesn't heat or does not run at all. i would check the door switch, if its not running at all. try opening the door and push the door switch closed by hand, if the light doesn't go out replace the switch
Nov 11, 2007 | Maytag MDG7600AW Gas Dryer
Maytag Atlantis MDG7400AW Gas Dryer Logo
328 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
