Question about CADAC Safari Chef Portable Grill
Gas is very slow will not burn hight - CADAC Safari Chef Portable Grill
    President:
  • 512 Answers
You are opening tank valve to fast. Tank valve thinks it is leaking when you open to fast and shuts down. Unhook tank, hook back up, open valve slowly. This should correct problem. Remember to always open valve slowly.
Posted on Jun 17, 2009
Pilot light on 1954 wedgewood gas stove burns too hight how to adjust
There are small screws on the manifold that control the pilot fame. They could be accessed by removing the top panels or sometimes they can be accessed from the front , Some of the front panels snap off. remove the burner tops and trace the tubes back to the valve manifold and you should see a screw on a small valve. Turn these and the pilot lihght should go up or down.
Oct 01, 2014 | Kitchen Ranges
Fouling out new plug
over rich - if it does the same with no filter on try dropping the needle .
if it's fine with no filter than try a free flowing one . float hight may be incorrect - double check where the float hight should be measured from. if carb has a diaphram in it make sure its correctly positioned it could be keeping the needle to high up. you could try a lower octane fuel.
Oct 02, 2012 | 1998 kawasaki KLX 300
Derestrict 2007 kymco agility 50? Its to slow street speed is 45mph in miami, help...
Ckeck spark plug,batterie,put super fuel with a hight level of octane its gonna clean ir engine .
Jul 21, 2011 | 2007 Kymco Agility 50
I have a 2000 ford mustang v6 I was putting 89 octane gas in it. my manual said to burn 87 octane so i'm burnning 87 now .but when I accellerate I get a knocking, rattling sound took it to a ford dealer...
Humm, give it some time. there are upper cylinder cleaners, but I worry about converter damage, and oxygen sensor damage. The lower the octane, the hotter and more masssive the burn, exactly backwards from what you would think, but higher octane is slower burn and av.gas is really, really slow.
Ford has had slow to start issues that traced back to drivers using too high octane....
Still, if it keeps pinging, you may need to run higher than spec octane.
I would have thought that your car would have knock sensor that would trim this issue...
Oct 04, 2010 | 2001 Ford Mustang
Just hade new clutch in my 96 bandit and when first started clutch is sticky can you help plz
have a look at the cable if its free has it got any slack on it, a new clutch needs to be burnt in a little to take off all the hight spots so it works right, but as the hight spots burn off the cable go's tight,,
Feb 24, 2010 | 1996 Suzuki GSF 600 N Bandit
It heats the pool but the hot tub gets warm for ten min then the heater shuts off ???
ARE THE TEMPETURE SET HIGH IF YES THEN THE FLOW VALVE IS BAD . WHAT ABOT THE FLOW TO THE SPA CHECK THE PRESSURE READING WHEN SWITCH FROM POOL TO SPA IF VERY HIGHT THE JETS MAY BE PLUG MAKING THE FLOW TO SLOW FOR THE HEATER TO WORK OK
Dec 01, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Kemore gas Oven /range - oven very slow to warm and gas leaks but Broiler ok
Hi thanks for the question. the problem you are having is with the igniter in the oven. it ignites but not hot enough to burn all the gas. replace the bake igniter. thanks the appliance doc. please rate my answer. thanks.
Oct 06, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Vaccum stops cleaning after a while it shuts off
Sounds like the motor is overheating and thermalling out (Hight Temp shut down). This could be caused by overfilled cannister, obstructed passageways, or debris accumulated around the motors cooling fan. Try emptying the catch container and blow out / clean all the filters. Check for obtructions by going to the hose mode and alternately blocking and uncovering the nozzle end - feel for good suction and listen for a definite change in motor sound (Pitch Change) With the intake open, the motor should rev freely, when blocked it will slow and sound labored / loaded down. Another possible cause could be a binding brush roller overloading the motor - but this will usually burn out the belt first. Notice any unusual smells? Burned belts stink like burnt rubber.
Jun 01, 2008 | Fantom Vacums FM760 Twister 500DX Bagless...
CADAC Safari Chef Portable Grill Logo
392 people viewed this question
Top CADAC Grilling Experts
Paul Carew
Andrew Taylor
Andrew Taylor
ray gallant
Are you a CADAC Grilling Expert? Answer questions, earn points and help others
