Question about Kenmore Washing Machines
Transmission won´t shift in spin - Kenmore Washing Machines
  • 135 Answers
Very likely you need a replacement transmission part # 3360629. Available for $90 shipped from timerking.com or other sources. Hope this help!
Posted on Jun 16, 2009
Pulsar 220 gear shift problem
Hi, Deepak and the usual suspects are:
1. Clutch dragging slightly.
2. Primary chaincase overfilled with lubricant.
3. Corners wore off shifter clutch dogs.
4. Shifter return spring bent or broken.
5. Bent shifter rod.
6. Shifter forks sprung.
7. Transmission oil too heavy.
For more information about your issue, please visit the websites below. Good luck and have a nice day.
DOWNLOAD Bajaj Pulsar 180
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Nov 12, 2013 | 2011 Bajaj Pulsar 180
The machine doesn't spin properly and doesn't drain the water
see this causes and fix it. God bless you
Lid Switch Assembly If the washer won't spin the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Motor Coupling If the washer won't spin the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission. Another common problem is the lid switch.
Drive Belt If the washer won't spin, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin properly.
Door Lock Motor and Switch Assembly If the washer spin the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Drive Block If the washer won't spin the drive block might be worn out or may have come loose. Underneath the agitator the drive block connects the inner tub (the one that spins around) to the transmission. If the drive block wears out the transmission shaft will still spin but the tub may not - or it may spin slowly. This also usually causes a lot of noise. The drive block is relatively easy to replace.
Clutch Assembly If the washer won't spin, the clutch assembly might be worn out. The clutch assembly makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may prevent the tub from spinning. The clutch is not repairable, if it is loud or not working properly it will need to be replaced.
Clutch Band kit If the washer won't spin, the clutch band kit might be worn out. The clutch makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may prevent the tub from spinning. If the washer won't spin, this clutch band kit may need to be replaced.
Drive Motor If the washer won't spin the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged It will have to be replaced.
Tub Bearing If the washer won't spin the tub bearing might have seized. This is a common problem and relatively easy to replace.
Tub Seal and Bearing Kit If the washer won't spin the tub seal and bearing might have seized. This is a common problem and relatively easy to replace.
Bearing If the washer won't spin the bearing might have seized. This is not common. The bearing doesn't require any normal maintenance. They generally go bad when the tub seal fails and allows water to leak past into the bearing.
Basket Drive If the washer won't spin the basket drive clutch might be worn out. The basket drive sits on top of the transmission and engages with the inner tub. If the basket drive wears out the tub won't spin.
Basket Drive Hub Kit If the washer won't spin the basket drive hub might be worn out. The hub is a set of plastic gears underneath the agitator. The basket drive hub kit is easy to replace with standard hand tools.
Transmission If the washer won't spin the transmission might be worn out or defective. There are numerous more likely causes when a washer won't spin, which should be checked first.
Sep 28, 2012 | Hotpoint Washing Machines
I have a 1998 Oldsmobile intrigue (automatic). The car drives fine in reverse, however when I put it in drive, the car does not move. You have to rev the motor up real high for it to move an inch. Any...
The transmission is nearly dry. Add some transmission fluid! Automatic transmissions require oil pressure for the car to move, and if you don't have enough oil in it, it won't build up enough pressure to move the car
Jun 12, 2011 | 1998 Oldsmobile Intrigue
Transmission will shift, but car won't move.
Hi, if it is an automatic transmission, it could be several things:
It could be really low on transmission fluid or the fluid may have leaked out. Do you see an reddish or reddish-brown fluid under the car? Check the fluid level by looking at the transmission fluid dipstick.
The torque converter (essentially a motion transfer device that resembles two fans facing each other) may be bad. As the engine spins, up, the fluid in the torque converter starts spinning and flowing and starts to 'spin' the blade on the transmissin side (it's called locking up the torqure converter). If there a malfunction in the converter, or no fluid, as noted above, no motion to the transmission.
Is the emergency brake stuck on?
Another issue might be the transmission linkage - when you move the shift handle to "D", there is a linkage that moves a lever on the transmission to change how fluid moves thru the transmission, etc. Check for a broken linkage between the bottom of the shift handle and the tranny. This is best done at a good auto repair shop or dealer.
If this is a manual transmission car, you probably have a worn out clutch plate or broken shift linkage. See a mechanic.
May 27, 2011 | 1997 Subaru Legacy
Transmission won't shift when engine heats up
Dear Madam or Sir,
if the problem has an electrical cause, the oil temperature sensor is defective, this should be checked first.
If the sensor is working good, there is a mechanical problem with your transmission due to worn bushes and / or gaskets. The viscosity of the oil is decreasing while heating up, if there is a worn gasket the shift pressure drops and the transmission won´t shift.
Jun 26, 2010 | 1992 Dodge Caravan
When the car is warm the transmission will not shift
Dear Madam or Sir,
Jun 26, 2010 | 1994 Ford Taurus
Trans won´t engage when cold
cleaning the valves for trans conversion might but that is up to a pro do not atempt yourself
Apr 03, 2010 | 2001 Jaguar XJ8
Whirlpool A5380XTWO will not spin or agitate. Is
check the "wig-wags" that shift the transmission in the washer,they are 2 coils(solenoids) located adjacent the motor on the transmission,if they get no power they wont shift transmission into next cycle of wash mode
Feb 03, 2010 | Washing Machines
Subaru impreza automatic transmission won t shift
Try replacing the transmission filter and the trannie fluid. Mine would only go in reverse, and now it drives pretty well. This year has a screw on filter. Hope this helps
Mar 25, 2009 | 1994 Subaru Impreza
Washing Machines Logo
61 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
