Question about Garden
Hey thanks. My Mom's Toro 20018 lawn mower has
Hey thanks. My Mom's Toro 20018 lawn mower has NEVER started right as they guaranteed. Warranty has expired. The starter turns the motor over but it wont kick off and run, it sputters after a few tries but won't run. I've cleaned the filter, changed the plug. It's a pain to work with. I'm trying the easiect stuff first before I have to break down and take it to a mech, so is the carb out of adjustment somehow, and if so, how do I adjust it? Thanks.
    Top Expert:
  • Garden Master
  • 12,962 Answers
Should have had it taken care of while still under warranty.
You have carb issues. In google they will tell you how to adjust various makes of carbs after you clean them out or get a new one.
Posted on Jun 23, 2017
  • 6966 Answers
SOURCE: hard starting and poor running
Try running the engine without the filter and check if the idle would smoothen, maybe a little high. If problem persist, then it would be fuel delivery problem. If the idle is constant (but high), then some sort of blockage on the air filter or a vacuum leak.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 10, 2008
  • 36 Answers
SOURCE: 2 1/2 Briggs......doesn't run smoothly....surges at all speeds.
Hi, Check that you have the correct spark plug fitted or fit a new one as it sounds like your plug is getting hot then shorting out.
Sometimes the magnito can do this as well. but I would start with the plug.
Posted on Nov 29, 2008
#1 Taper
  • 1040 Answers
SOURCE: Toro Tecumseh mower won't start or stay running
Sounds like you need to clean the carburetor. If you need tips on how to do this, just let me know.
Posted on May 31, 2009
  • 1129 Answers
SOURCE: Toro lawn mower. Have trouble starting(starts and
Remove the float bowl located under the carburetor it is a 1/2 bolt some gas will poor out so put a rag under the carb to soak up the gas, you actually may want to use a small container to collect the gas or make sure the gas tank is empty, remove the float bowl after removing the bolt by grasping it and turning, the bowl will most likely have debree and water in it clean with a rag and solvent and reinstall, becareful of the ruuber ring gasket when reinstalling the float bowl, one some movers there is no float bowl if you have this type of engine the tank and carb must be removed disassembled and clean out. Do not store mowers uncovered they must be covered when not in use, water gets into the fuel system and causes this problem.
Posted on Jul 14, 2009
  • 68 Answers
SOURCE: Murray 4.5 hp Q lawn mower runs rough and smokes.
White smoke indicates that it is burning oil. The smoke would be black if it was running rich. So probably the rings will need to be replaced eventually. These mowers are prone to problems but the carbie is least likely to be the problem. So before you adjust the carbie take the cover off the top and give it a good clean and check that all the hoses are connected and are not cracked. Then make sure the airfilter is clean, blow it out with an air compessor or better still get a new one. Then try it out agian. If this doesn't help there is two screws on the carby marked L and H. Turn these only 1/8th of a turn at a time and note or make their current position. Start with the H scew with the mower at full revs. Turn anti clockwise untill you get max revs then turn it back a bit. Running too lean will over heat the motor and damage it. Then if needed adjust the L (or Low)screw. If you get black or grey smoke when you push the throttle up from idle to full its too rich so turn clockwise. If if slows before it picks up to full revs turn anti clockwise.
Posted on Sep 06, 2009
I just purchased a new toro recycler self propelled mower and it will not start
return it to the supplier or get them to give you support for the unit. It must have a a warranty, do not attempt to remedy it too much...they may turn round and say that you tmpered which will invalidate your guarantee
Jul 16, 2015 | Toro Garden
I have a Toro 22"
Odds are the battery needs replaced. If it is a 12V battery, you could try jump starting to test the starter to verify. If it is a 6V battery you will have to find another one to jump. You could check the battery with a multimeter to check voltage if you have one or know of someone who does. Make sure you know how to do this properly so as not to destroy the meter. The meters can be cheap or expensive, depends on the model and the features, but always bad idea to let out the magic smoke.
I hope this helps.
Jul 27, 2011 | Toro Lawn Mower With Toro Power Tools
I have a toro 20018. The bracket that holds the wire from the starter and battery has a cable that pulls the switch together at the bottom and off the kill switch at the top --- it has completely...
Bypassing probably isn't a good option as far as the kill switch is concerned because it is an important safety feature you want to always have. I'm not sure if you are in need of the bracket or the cable. Parts are available, finding them is the usual problem. OK
The cable can be found here. There are 2 listed. One is the traction (drive) and the other is brake (kill switch).
The bracket is possibly listed here as part number 6. It is listed as the mount for the switch. Your mower has different serial numbers and about 3 versions of diagrams are listed. This vendor has very good diagrams that include yours. Here is the diagram of the switch bracket with the starter assembly. If this isn't what you need, click on the menu tab above the diagram to view another location on the mower.
May 14, 2011 | Toro Lawn Mower With Toro Power Tools
My toro lawn mower is hard to start in cold weather. (40 to 50 degrees), I have an auto-choke. mower was bought in spring of 2010.
This is covered by the Warranty. Take it to a local dealer like and have the thermostat replaced.
The first generation thermostats are known for sticking.
Good luck
Nov 01, 2010 | Toro Lawnmower 20099 Mower Mowers Lawn
I replaced ignition coil on a Tecumseh Toro 20018 mower. It would not start without disconnecting green "kill" wire. Now what do I need to do - replace the kill switch? Is the kill switch located on the...
It is a short in the kill switch, or the wire running to the kill switch. check insulation on the wire running to the kill switch and check the routing of the wire to insure that it is not being rubbed by moving parts, or the insulation melted by hot engine parts such as the exhaust system. Finally check that the kill switch itself is functioning properly with a test light or OHM Meter.
Aug 12, 2010 | Toro Garden
don't waste time looking for the primer bulb. probably wont work anyway if its over 6 months old and repairs probably wont do any good either. bad design for a primer system.
Apr 08, 2010 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Mower Electric Start Won't Engage
you'll need to pull the starter. It sound like your Bendick's is bad. that's the upper gear drive assay. the only other res ion would be, low power to the starter, and not receiving an acquit amount of amp to reach the rpm's it needs. good luck
Oct 23, 2009 | Toro Lawn Mower With Toro Power Tools
Cannot re-start lawn mower!
Take it back where you bought it and let them deal with it.
Sep 13, 2009 | Toro Lawn Mower With Toro Power Tools
I have a Toro electric start 22'' inch lawmnower Model No. 20018 with a Tecumseh LEV 90-120 engine. The mower may be started with the electric start or manually with the cord. The battery was in need of...
It sounds like the starter drive may be jammed. It should not be engaged unless you are using the starter motor. Take the spark plug wire off, put on heavy leather gloves, and try turning the blade by hand to dislodge the starter drive. If it does dislodge, plug the spark plug wire back up and try the pull start again.
Aug 29, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
253 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
