Manual for sanyo fax machine model sfx-111, mechanical error, not feeding paper...
  • 240 Answers
(718)787-1301 call the above phone no and u ll get one i think its a authorised sanyo service centre
Posted on Jun 16, 2009
How do I fix the paper feed mechanism
Try to rep[lace the paper separation rubber.
May 21, 2014 | Brother IntelliFAX 2800 Laser Fax
Have a sanyo sfx 111 fax. cannot get the # key to work when I use the phone , aslo cannot get the flash key to work when I use the phone. help please
Put a DROP of alcohol or WD-40 on top of those keys and let it drip down into the key base. These 2 keys get sticky because they are seldom used.
Mar 02, 2010 | Office Equipment & Supplies
Cannon laser fax 1060 P "check paper size"
Hi Margaret
Ok,the problem normaly with this model is in the feeding of the paper.For some or other reason the paper is moving to slow threw the machine and then the machine detect it as a longer size paper.
  • Clean the rollers that pick the paper up and clean also the sepatation rubbers under neath the paper pick up rollers.This rubbers is called the separation pads.
  • To clean this rollers,remove the cartridge and you will see the feed roller at the back.
I think what happened with the move the machine might collected dust and now the rollers are slipping.
Thanks for you support
Dec 29, 2009 | Canon L220 Plain Paper Laser Fax
My fax keeps saying check paper, why? I cant recieve faxes but can send them, please help.
you will need a technician to inspect the paper feed mechanism. feed rollers worn, bad sensor or paper scrap in unit. difficult for customer to get into unit.
Nov 18, 2009 | Brother MFC-970MC Plain Paper Thermal Fax
Can't print faxes due to error messages
Please check rear door area for paper, can you use manual feed slot? Power off machine with all jams removed and paper loaded, then power on, can you tell us exact error message/lights that are shown in this state?
Oct 15, 2007 | Brother IntelliFax-2820 Laser Fax
Doesnt Know How To Use Fax
Very easy. Make sure you have a phone cord plugged from the wall to a port in the back of the machine marked "line". Place you document in the feed, dial the fax number of the other machine and press start. Your machine will dial the other machine, make some beeping noises then scan your document. If it feeds through ok, and you do not get an error message in the display, then it has been sent!
Jun 19, 2007 | Brother FAX-T78 Plain Paper
Fax machine jams or stops loading document for a copy or sending fax
try to open your fax machine ang check paper feed gear maybe 1teeth of gear is broken..or maybe your machine incountered feeding timing error.
Jan 30, 2007 | Panasonic KX-FL511 Plain Paper Laser Fax
Panasonic model no kx -FL 512cx fax machine
1-use fresh papers and fan it .
2-clean paper feed roller carefully.
3-confirm that no foregin object droped inside.(pins etc..)
4-confirm that gear train working propably and there is no broken gear.
Nov 15, 2006 | Panasonic KX-FL501 Plain Paper Laser Fax
651 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
