Question about Toshiba Satellite A75-S226 Notebook
Toshiba Satellite A75-S226 Laptop gets warm and shuts down.
Screens are clean on outside fan ports. Have recently cleaned these a few times on the outside. Is it easy to take it apart to clean it inside? Or do I have to send it back to the dealer to get it cleaned. It was already sent back once when it was under warranty. I am a retired System engineer, former electronics technician and now 75 years old. Still fairly good at repairing electronic equipment. Is this a job I should undertake? Anyone having worked on this problem, Please advise.
  • jimmcwho Jun 17, 2009
    I reviewed your info and then got an online manual for disassembly. I then decided to try using my air compressor to blow it out both directions, making sure I did not get full force of the air in the fan areas. This solved my problem as I did get a lot of lint from the unit and it now runs cooler than it did before this treatment. If the problem reoccurs, I will totally disassemble it and clean the heatsinks. Thanks so much for the help from all of you.
  • Toshiba Master
  • 2,404 Answers
When you take it apart your probably going to find dirt on the heatsink next to where the cpu fan vent is.
Its not that its hard to take apart but its alot of screws that need to come out and you need to keep things in order.
First all the screws on the bottom need to come out, then take out the hard drive, dvd drive, any doors covering memory, wireless card etc.
Then the keyboard cover needs to come off and then that should expose the screws to take of the keyboard. The other end of the keyboard is help in by a ribbon connector that needs to be loosened and that will take the keyboard out. The any other screw that you see on the top cover need to come off. The 4 screws holding in the lcd need to come of and then if there are wires that are being ran to the wireless card, those need to come loose as well cause they are part of the lcd.
There maybe a few more conectors for the speakers and a ribbon cable for the mouse pad that need to come off.
After all of that you can get the top cover to come off and that will expose the motherboard. There maybe a few screws that need to come off from the motheboard.
Then at that point you can get the motheboard away from the bottom assembly and at this point you can unscrew the screws from the cpu heatsink and then clean off the heatsink.
Posted on Jun 16, 2009
  • 30 Answers
Taking apart any laptop can be a pain. Just make sure you know where each of the 50 screws go and what is a screw or fastener and what is a clip. Also be careful of any ribbon cables and other delicate things inside. Clearances are tight and you need small fingers at times (I use hemostats for a lot of things.) You may also be able to find a manual online that will describe disassembly, sometimes even from the manufacturer.
The heat issue may be a hardware problem. Most modern Laptops use a heat pipe to transfer heat to the heatsink. It uses a coolant that as it heats up, it changes states and goes up the pipe, cools off and changes back to a liquid. The pressure is adjusted at the factory and is not servicable. If the problem persists, check this and the fan.
  • 555 Answers
My recommendation are try to used vacuum it cause the fan itself is within outside or try to find a technician to clean it and maybe you could as to fix some minor error or problem to prevent it from growing.
Toshiba laptop satellite A75 dim screen
The used inverter maybe faulty. The inverter supplies high voltage to the CCFL lamp in the LCD screen, the CCFL lamp provides the backlight.
LCD screens and Inverters are available from this WEB site.www.lcdparts.net
Feb 15, 2012 | Toshiba Satellite A75-S226 Notebook
Power supply problems
the problem is from the motherboard. One problem with toshiba laptop, is that they overheat too much.
Check if the fan of your laptop is working and make sure you keep your laptop where there is ventilation, so that air can enter into the laptop.
You could also open up the laptop, clean every dust on the motherboard and also the fan and cooler.
That's the area you should concentrate your attention on and not the battery or AC adapter.
Take care.
May 28, 2010 | Toshiba Satellite A75-S226 Notebook
Overheating and shutting down within several
The A-70 and A75 series both suffer from a very tight cooling system. If you are running a P4 its pretty marginal. Basically what you need to do is blow out and or clean the cooling system. On my A70 I had to do it every 4-6 months. Basically as soon as it started getting past warm on the bottom of the laptop it was time to blow it out.
Basically what happens is dust and oils (cooking oils, perfume oils etc) and hair collect on the cooler and reduce how effective it can cool.
So what you do to clean it is get a can of compressed air (keyboard blow off stuff) and two toothpick. Take the battery out and unplug it.Turn the laptop upside down. Insert the toothpick in the cooling fans. This is important as the air can turn the fans faster then they are meant to spin and could damage the fan bearings (new fan annoying and expensive -lots of labour). Take the compressed air and blow in from the exits and then blow in over the fans. What will surprise you is just how little dust will come out. It may just be one good puff of dust and thats it. When you do this a couple of times or don't see any more dust you are done. Take out the toothpicks and put the battery back in and turn it on. It should run much cooler.
May 17, 2010 | Toshiba Satellite A75-S231 Notebook
Toshiba Satellite A75-S226 function keys on keyboard ... What switches on a Video projector?
Keep pressed <Fn> key and press/release <F5> key until you get the image to external monitor/projector.
Oct 08, 2009 | Toshiba Satellite A75-S226 Notebook
Toshiba boots up power light stays on and shuts down, bad m/b ?
I own a Laptop Toshiba Satellite A75-S2131.
This series have a problem with the cooling flow to the processor.
The processor overheats and the laptop shuts down.To solve this particular problem you must tear down the laptop and clean up the processor heatsink (you will find it totally plugged or partially dirty).
Find in the internet the step by step instructions (with photos) for dismantling this laptop. Do not forget to apply thermal paste between processor & heatsink.
I hope this solution helps.
Posted by MCampos
Mar 12, 2009 | Toshiba Satellite A75-S209 Notebook
Screen changes
Please check on it by updating the video driver. You can go to support.toshiba.com for the latest driver. Hope this helps. Thanks.
Oct 19, 2008 | Toshiba Satellite A75-S226 Notebook
Toshiba Satellite A75-S226 Notebook Logo
154 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
