Question about KitchenAid KSCS25IN Side by Side Refrigerator
Ice and water dispencer is not dispensing ice or water and the ystem s not locked.
  • 3 more comments
  • Chris1228 Mar 01, 2008
    Our ice dispenser, water & light have all quit working. Worked fine one day, then "poof" it stopped!
    How can this be fixed? Date of mfg is 01/02.
  • Anonymous Mar 08, 2008
    same problem - but ice dispenser went out first. Motor doesn't engage to dispense but ice is still made inside the freezer. Then, the other day, the water dispenser stopped working as well. Freezer still makes ice though
  • jphite Jul 07, 2008
    ice and water dispencer is not dispensing ice or water and the ystem s not locked
  • aeisner007 Jul 14, 2008
    my side by side dispenses ice and water when using the ice dispenser, but no water when using the water dispenser alone. Also, the ice is crushed, even though the setting is for cubes!
  • kikalicious Aug 07, 2008
    Ice is producing, but ice and water not dispencing. The water filter light is yellow, could that be it? I just moved into this house with the existing fridge.
    Problem Solver:
  • 12 Answers
I have seen this problem before .the wires locted near the bottom hinge have all broken from the constant open and closing of the door causing it to break the wires.
eeggman
Posted on Mar 10, 2008
I have a side by side westinghouse fridge with water and ice dispencer. the springs that control the lever for ice dispencing are either of their hinges or fell off how do i get in there to fix it
Insert a pin in the slot under the lower edge of the trim, You should see 2 small holes, that will release the lock tabs, from there you can just pull the frame toward you, Inside you will be able to see the problem.
May 19, 2011 | Westinghouse WRS6R3EW 36" 25.8 Cu. Ft....
Last night, I connected an active water line to the back of my Kenmore side by side. The ice maker is making ice but water water and ice is not coming out of the dispencer. There is another water jug...
You have a dual water inlet valve where your water supply connects. One goes to the ice maker and the other goes to the water dispenser by way of the water reservoir you mentioned in the fridge.
Open the door and hold the door switch down and try the ice dispenser. Do you hear any thing.You should hear the ice door open and the augur motor turning to turn the augur which pushes the ice out the door. If the augur doesn't turn Take all the ice out of the bin and try. perhaps the motor is too weak or the augur is locked up. Take the bin out and try to see if the motor will turn with no load. The motor is behind the back cover where the bin sits. See if you get power to it using a voltmeter when you try the dispenser. If you are, probably bad motor. If not ,dispenser switch or solenoid is not working.
Apr 20, 2011 | Kenmore Side by Side Refrigerator
How do i access the ice dispencer door in the door? The door is stuck open and freezes up the dispencer.
1. Disconnect the unit from the electrical
supply and wait for 3 to 4 hrs to get ice melted.
2. Pull out and unclip the drip tray on the ice
and water dispenser compartment.
3. Remove the screws from the ice and water
dispenser compartment front panel and
turn it over. The selector switch pack and
dispenser switches are now accessible for
testing.
Jan 29, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
GC3SHEx300 ice dispencer does not dispense cube or crush ice. Water comes out, lights work. it is not deactivated.
Sep 06, 2010 | Whirlpool 21.8 cu. ft. Side-By-Side...
How to unlock ice and water dispencer.
Press and hold the lock button (one that has key emblem) until the lock light goes out. If that does not solve it or that light is not on , you may have a dispenser board problem..
Jun 11, 2010 | Maytag MZD2766GES Side by Side...
No water supply to water dispencer
I had this problem with an old amana and my water filter neded replacing. Filter was enough for ice but not for water dispenser.
Mar 27, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Sid by side ice dsspencer and water dispencer(all the indicator light suddently are shut off) not working
you could have a problem with your dispenser module. a burnt pcb that could lead to all of your problems. switches not working, lights not working, dispenser not working, etc.
check your dispenser module and if you find a burnt part or a burnt PCB, then replace it.
tnx 4 using fixya,
drcool
Oct 14, 2008 | Frigidaire FRS3R5EMB Side by Side...
Water/ice dispenser activates at will, selector panel locks up
Hi jrupich,
There is only two things that can cause this problem. One would be the dispencer control board. Part #61003425
The other thing is a stuck or shorted dispencer switch
part #61005520
Since you say that you have already replaced the control, I would have to go with the switch, but in rare cases the new board installed in the dispencer can also be faulty. Some appliance techs will even sell you a used one and tell you it is new. You have to trust your repairman. Good luck to you and I hope this will FixYa. please dont forget to rate me.
Mike Anderson (Owner)
Anderson Appliance
(865)945-3808
Sep 30, 2008 | Maytag Refrigerators
Door dispenser stopped dispensing, starting making a constant clicking and now the entire fride isn't working
We had the same problem. Our frigerator is 1.5 year old. Everytime we try to dispence water or ice the dispencer clicks and the whole thing turns of. We had a GE repairman come by: the electronic board needs to be replaced: total cost $350. (cost of the board only: $150. We are considering disconnecting the dispencer by unplugging the board (according to the repain man the ice maker wil still work)or buy a new refrigurator (for sure NO GE!!!!!!)
Aug 01, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
KitchenAid KSCS25IN Side by Side Refrigerator Logo
159 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
