Question about Arris SURFboard SBG900 Wireless Router (DHSBG900)
Xbox live is saying that i need 1364 mtu setting were do i go to change this.
    President:
  • 828 Answers
That 1392 is a firewire, your xbox is in need a connection going to your firewire... install the firewire 1364 driver...
Posted on Jun 16, 2009
4 Suggested Answers
  • 35 Answers
SOURCE: I need to increase my MTU settings on my router for Xbox LIVE.
You can do that by configuring your router. Look for the default ip address of yoour router, it can be found in your router's manual. After you found it, run internet explorer and type in your ip address (ex. 192.168.10.1). There you o just enter your username and password and your on your way to the configuration process. Go to internet setup and under DHCP Internet Connection Type you can change MTU there. Just give it a try...
Posted on Jun 21, 2009
Comp-U-Doc
  • 148 Answers
SOURCE: i need to change the MTU settings
To change your MTU settings download a program called DrTCP (google for it) then change the MTU size of your Internet connection, try 1465 and keep dropping it until you get a figure that works...
You can also check out xbox support site for more information on MTU settings here
Posted on Mar 12, 2010
dexterlim29
  • 70 Answers
SOURCE: how do i change my 2wire routers mtu settings cant
you need to call your internet service provider because that is the firewall of the 2wire.
Posted on Jun 17, 2010
Change MTU settings on an RCA DCW 725
  • There are no user configurable options to cable modems, everything is based off the configuration file that your ISP pushes to the modem during registration.
  • Try connecting your XBOX directly
Apr 07, 2010 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Tip
Xbox Live - MTU Error
Xbox 360 MTU errors
This issue occurs if your router or the gateway is incompatible with Xbox Live, or if your router or the gateway has an incorrect MTU setting. Note: Xbox Live requires a minimum MTU setting of 1364. We recommend that you try out the steps shown below.
Things to try:
1. Ensure that you have properly setup your connection to Live by using the Connectivity Wizard http://www.xbox.com/en-US/support/connecttolive/xbox360/connectionmethods/webconnectivitywizard.htm
2. Visit the following Web site to determine whether you have the correct firmware version that has been certified as compatible: http://www.xbox.com/en-US/live/connect/routerlanding.htm
3. See the router or gateway instruction manual for information about how to change the MTU setting to 1364, to do this, or to determine whether your router supports this feature, see the router support documentation or contact support for your router device.
4. If you share a connection with a router and a modem, try a direct connection without the router.
For additional information on this topic refer to the following KB article: http://support.microsoft.com/kb/908882/
on Sep 30, 2008 | Microsoft Xbox 360 Console
I need to change the MTU settings
Feb 23, 2010 | Arris SURFboard SBG900 Wireless Router...
How can I change my mtu on my wireless router to be able to play xbox?
Xbox LIVE requires a minimum MTU setting of 1364. Usually, you can change your MTU setting from your router configuration web page, which is supplied by your router manufacturer.
Learn how to find and use your router configuration page
Look for the MTU setting on the router configuration page. When you find it, set it to Auto or 1364 (or higher), save your settings, and then try to connect to Xbox LIVE again on your console.
Nov 21, 2009 | Zhone (6218-I2-200) Router
Connection interruption while playing xbox live
Xbox LIVE recommends using an MTU value of 1364(defaults are 1492 and 1500) on your router.
You will need to log onto your Router, go to the setup section, locate the MTU, set it to Manual, and change the Size to 1364.
If that doesn't work, you will need to clarify the following:
  1. How many machines(do you have other computers?)
  2. What router are you using
  3. Ethernet or Wireless?
Sep 28, 2009 | NetGear WGR614 Wireless Router
How to change mtu settings to get x box live?
heres a good site that discusses adjusting the MTU(maximum transmission unit)
Usually in most cases MTU of 1500will work just fine, I suggest using DrTCP a free program available online to help you tweak your settings
http://help.expedient.com/broadband/mtu.shtml
Dont forget to rate the advice.
http://www.aa1consulting.com
Aug 03, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
My x box says change mtu to auto or 1364 how do i do this
My MTU is at 1500 and I get the same message. I don't think it's up yet.
Jun 17, 2009 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Bestdata cmx300v2 mtu setting is too low
My MTU is at 1500 and I get the same message. I don't think XBL is up yet. It is under repair.
Jun 16, 2009 | Computers & Internet
Changing the MTU setting
Log into modem using 192.168.2.1 in your browser and go to modem utility through browser.
May 18, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Arris SURFboard SBG900 Wireless Router (DHSBG900) Logo
814 people viewed this question
Top Arris Computers & Internet Experts
jimmy Leo
Jerry
Jerry
Greg Ulan
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
