Just moved into my house and found that when you turn the cold water on (at any cold water outlet such as faucets, tubs, outdoor water hose and even the toilet), the water comes out hot for approx 10 second and then turn to cold. There isn't a hot water circulating pump or crossed piping connections that I can find. I haven't had a plumber look at it yet but I can't find anyone handy that has ever heard of such a problem. Is this something common or does it sound like a serious problem. Please let me know what you think.
none of the hot faucets are working but the cold water works fine. the pilot is on & we can...
(More)
none of the hot faucets are working but the cold water works fine. the pilot is on & we can hear it heating up but still no water. the heater is only a couple of years old. also it bangs very loudly. any ideas?
iv replaced my cylinder and emmersion heater and its not giving hot water the stat is set at 60...
(More)
iv replaced my cylinder and emmersion heater and its not giving hot water the stat is set at 60 degrees its wired to the mains the tank is full but no hot water please help
operates on propane but not o 110v,circuit board appears to be operating correctly when 110 v switch...
(More)
operates on propane but not o 110v,circuit board appears to be operating correctly when 110 v switch is on
On a Vanguard residential 50 gal 6E715 the burner igniter glows but won't fire.Vacuum switch OK. Is...
(More)
On a Vanguard residential 50 gal 6E715 the burner igniter glows but won't fire.Vacuum switch OK. Is it the ignition control module or the gas valve that has failed?
