Question about AOC LM729 17" LCD Monitor
AOC LM725 Color Cycle
Im a novice in electronic repair. just researching here n there about what i need to fix. My AOC got power on/off cycle. Learning from few articles, and a book, I found s push/pull transistor (C5705) shorted and replaced it. I also replaced C945 and A733 transistors and /A431 IC. Now it did power up but only display Red Green Blue, White and Black color cycle continuously. Im suspecting an IC labeled SC68410Z KA23500506C, or something like that but can't find it from the shop I frequent. Any help out there?
-filmdock
  • filmdock Jul 05, 2009
    Because the AOC LM725 I was trying to fix belongs to the studio I work for, I didn't bother to bring the video cable along because the original problem was power cycle. Now when I changed the push pull transistor (C5705) which I tested and found shorted and the precision shunt regulator IC (A431) the power came back but it just kept cycling through full-screen RGB, Black, White color display. I thought that maybe if I'll try connecting it to the cpu with the right video cable it might behave differently, so I did, and walla--it's working! I just have this OSD lock display whenever I press the menu but I've read from some articles that it could be disabled by turning off the LCD and pressing the Menu button while turning it back on again.
    I hope this helps someone else out there.
    President:
  • 828 Answers
AOC brand are disposable, now if your going repair its chips, its definitely work or not... i tell you this monitor is very deliquate to work normally.... buy a new one...
Posted on Jun 16, 2009
Have no picture or sound on aoc hdtv aoc l42h961?
Is the power cord plugged in all the way? Try a different power cord if you see no indication of power. If that doesn't fix it, you might have a bad power supply. Electrolytic capacitors in the power supply are a common failure component and it might be cheaper to repair than to replace. I am a repair technician and was able to repair my two AOC televisions for less than $3 by replacing 4 electrolytic capacitors. You will need to pay a technician for parts and labor.
May 14, 2014 | AOC Televison & Video
How do I reduce the brightness of my AOC monitor?
If you are using windows XP :
1.Right click on desktop
2.Properties
3.Settings
4.Advanced
Windows 7:
1.Open Display Color Calibration by clicking the Start button , and then clicking Control Panel. In the search box, type calibrate display, and then click Calibrate display color. If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
2.In Display Color Calibration, click Next to continue
Aug 01, 2011 | AOC Monitor
PANASONIC PLASMA model# TH-42pz80u.I plugged it in the wall ,and it just blinks 10 times in a cycle non stop.I repair MACs and P.C.s so im aware of the rules that apply to L.E.D color codes and that each...
I diagnostic flowchart manual to solve the problem but It will not fit in this limited space.
If there is some way to send it let me know. You will need to know how to work on electronic circuits to use it.
It could be boards P, A, GS,K ,GH
Feb 10, 2011 | Televison & Video
Can't find AOC LM725 driver for XP
click here to download the latest drivers you required.
May 12, 2010 | AOC 917Sw 19" LCD Monitor
MY MONITOR AOC LM725 GOES ON & OFF REPETEADLY ?
No, all you need to do is reset the monitor to factory settings. I fixed mine that way.
If your monitor goes off every 3 seconds (like mine did) you have to be fast or siwtch it on/off few times between the steps to get it fixed.
- 1st. unlock the OSD if when you press 'menu' you get the message 'OSD Locked'. To do this switch off the monitor, and press 'menu' while you switch it on again.
- 2nd. Switch it on, press 'menu' and quickly 'press '<' (left) twice and 'menu' twice to get it reset.
- 3rd switch it off and on again and if still goes off after 3/4 secs, try to reset it again.
I reset mine and it is working find. Before it went blank after 3 secs.
I just tried this because I did not understand why if it was a hardware problem I could see the screen for 2/3 seconds and if pressed on/off it came back, it made no sense as a hardware problem.
Dec 03, 2009 | AOC LM729 17" LCD Monitor
Problem inAOC LM725 monitor
Maybe one of the volume buttons on the front panel control is randomly shorting. Check it out...
Nov 14, 2009 | AOC LM729 17" LCD Monitor
AOC LM725 Monitor Problem
Change the monitor and check if the PC works. If it works then the problem is with the monitor, you will have to send it to repair. If not then, the problem should be with the power supply, check whether all the cables is kept intact.
Mar 21, 2009 | Rosewill R900J 19" Flat Panel LCD Monitor
AOC LM725 LCD Monitor
try looking for bloated caps, check all diodes... see if its not shorted/leaking and finally check the power regulator ic if its not shorted! note: some capacitors and diodes are very tiny, you should use a lens with good amount of light...
if it does not help..... well, what the hell? try pouring some gas, then light it up! that should solve the problem, at least it turned on right? hehehehe!
Mar 21, 2009 | AOC LM729 17" LCD Monitor
Aoc lm725 display off after few seconds
I've had a very similar issue on many Dell Monitors. Mine have been under warranty and they usually send me a new monitor, but I believe the issue lies with the power supply within the monitor.
Jul 10, 2008 | AOC LM729 17" LCD Monitor
Unlocking of OSD in AOC LM725 Monitor
Solution #1 above fixed my problem. Turn the monitor off, then hold the left button down while turning it on again. Works like a charm!
Nov 29, 2007 | AOC LM742 17" LCD Monitor
AOC LM729 17" LCD Monitor Logo
437 people viewed this question
Top AOC Computers & Internet Experts
Raj Patel
Mohammed Ebrahim M
Mohammed Ebrahim M
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
