Question about Western Digital Elements powered by WD 320 GB External USB (WDE1U3200N) Hard Drive
Hdd unreadable my internal hard drive is not working unreadable error
    Problem Solver:
  • 12 Answers
Ur hdd is phisicaly damage or its infected to virus
Posted on Jun 16, 2009
HDD mount failure on Toshiba 351c copier
"HDD mount" means it has an internal hard drive (HDD, or hard disk drive), and the copier has failed to "mount" (place in operation) that disk drive. That error means that the internal hard drive has failed and needs to be replaced. It will very likely need to be a special proprietary hard drive, preloaded with some sort of operating system for the copier, and you'll need to get it from a dealer.
Jul 30, 2014 | Toshiba E-studio 351c Color...
Fix syntax error external hard drive
It's likely the drive is failing. For remote data recovery or do-it-yourself data recovery see http://freedatarecovery.us
Sep 04, 2012 | Western Digital Computers & Internet
1. read time of hard drive clusters is less than 500ms 2. 33% of hdd space is unreadable 3. bad sectors on hard drive or damaged file allocation table 4. boot sector of hard drive disk is damaged 5. hard...
You can run ChkDisk utility to fix Bad sectors on the hard drive(If its fixable).
This utility actually marks the bad sectors on the Hard drive and Isolate from the being accessed thats why 33% of HDD space is unreadable.(Which is very high)
There is no option to fix this HDD, so suggest you to replace it with a new one.
Hope this helps Let me know if you have any query on this.
Jun 23, 2011 | Computers & Internet
I have Dell inspiron 1525 window vista recovery reports 5 error are detected in hard drive and memory errors detected on my laptop 1. hard drive doesnt respond to system commands-critical error 2.boot...
your HDD may be corrupted, re-installing windows vista is one option. Your best bet is if you have/ can obtain a copy of windows vista run setup and try the repair wizard in the windows vista setup, the wizard automatically finds errors and missing files and replaces them therefore solving any errors in your HDD. you can also try to use the recovery wizard from your recovery disc. best of luck
May 17, 2011 | Dell Inspiron 1525 Notebook
My hard disk is unreadable or its damaged i cant boot from it , why? i need to format my system and make a new windos installation but i cant ...
> Samsung ... 80 GB ... 3-year warranty .. unreadable ...
Sorry, but your disk-drive has stopped working (compare it to writing in pen onto greasy paper, and then trying to read what you wrote -- you won't get 100% readability).
The only "good-news" is that the warranty for your disk-drive could still be valid,
meaning that Samsung will replace the disk-drive, at their cost.
Oct 23, 2010 | Samsung 80GB INTERNAL 3.5- IN SATA HDD...
E 68 error code.
The e68 error on your Xbox 360 is caused by a hard drive/HDD problem, much like all of the problems in the "e6x" family of error codes on the Xbox 360 platform. It can be caused by an internal connection error with the hard drive, a general failure of the hard drive, or overheating of the hard drive. Basically, there is quite a large range of things that can cause the Xbox 360 e68 problem, which can make troubleshooting the issue slightly difficult.
Step one to fix the e68 code on your Xbox 360 is to remove the internal hard drive and try playing your console without it. If it then works, then you can be sure that you can permanently fix the problem. If not, then you will have more serious issues on your console that will need to be checked over by Microsoft
if it is the hdd there are guides on the net on how to fix it
Aug 23, 2010 | Microsoft Xbox 360 Console
Error code 0X80070571 with the external HDD
The Seatools test has verified that the "physical" hardware is working fine, which is good news.
However, the error-message "disk structure is corrupted" means that there is a "logical" problem. Compare it to a book with a Table of Contents that has been overwritten by a two-year-old with crayons;
the pages are not physically torn nor missing, but you cannot "read" the original Table of Contents information.
Connect the drive, and note which drive-letter that Windows assigns, e.g., 'E:'.
Click Start
Click Run
Type CMD and press ENTER
Type CHKDSK E: /F and press ENTER,
and let Windows try to reconstruct the Table of Contents on the disk.
Jan 02, 2010 | Maxtor Personal Storage 3200 (M1227310)...
Maxtor external HDD not detected by Vista
try to format it.it might need a quick format for you to use it. if still doesnt work check for the sata,pata cable that connects your motherboard.
Apr 30, 2009 | Maxtor Hard Drive
External hard disk unreadable
Your hard-drive is crashed and unreadable by win32.dll what you can do is try kick starting by using your friend computer it just might do it. I had same problem and I asked my son to using my hard-drive on his PC. It worked and still working. good luck
Jul 26, 2008 | Seagate 160GB 3.5" External USB Drive 160...
Can't open HDD drive
Hi
1. Start > Run > type in cmd then click OK to get a command prompt.
2. Type in chkdsk e: /r (replace e: with the drive letter of your external hard drive).
This won't do any harm, it will fix errors on the disk and try to recover data from bad sectors. It might not solve the problem but it's worth a try. Jyo
Jun 19, 2008 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Western Digital Elements powered by WD 320 GB External USB (WDE1U3200N) Hard Drive Logo
295 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marvin
Marvin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
