Question about Sony XDCAM HD PDW-F330 DV Digital Camcorder
No accept the disc and mark error 20-213
IS A SONY PDW-F330, THE SIGNAL RECORD, IS FLASER
4 Suggested Answers
SOURCE: disc error 1300
Had the same problem after purchasing DVD+RW discs. Exchanged for DVD-RW discs and it worked. I guess they are formatted differently.
Posted on Feb 21, 2009
SOURCE: Hi when i put the
03-354
03: optical drive two-axis (FCS, TRK)
-354: No signal from disc required for OP focus servo can be detected. Disc is not rotating
I would try another disc and if you get the same error call Sony's service center.
Posted on Nov 09, 2011
dalehendel
  • 12 Answers
You can't use 50 GB discs in your camera. Insert a 23 GB disc and the error will clear.
Posted on Nov 04, 2013
Sony pdw-700 error 02-f37 Sony pdw-700 error 02-f37 How to fix it
There's a internal ND filter mechanism check around the optical block detecting that something is not working.
Send it over to a Sony Service to repair, there's nothing you can do about it.
Apr 20, 2018 | Sony Televison & Video
After recording, I recieve a toc error c14 when I try to finalize it. How can I fix this problem?
There's a solution to the problem : the problem is one word..; '''Sony''. Throw the unit away as to my knowledge there is no company who makes discs that will allow a TOC (table of contents) to be written to the disc. All those Sony units were only designed to be accept Maxell CD-R Music Pro blank discs. They are unfortunately unavailable /no longer being produced. Step one: .Buy a Tascam recorder they accept consumer grade cds.. Step two: Boycott Sony as most of us who owned one of their standalone units didn't get two years of use out of it..including myself and most i've ever talked to about it.
Feb 18, 2015 | Sony RCD-W500C 5-Disc CD Recorder
SONY PDW-F355 error code 02 F 37
There was a firmware update (2.01) to correct this. May 14, 2012
Servo drive function is improved as follows.
The servo drive is now adjusted correctly, and the adjustment no longer results in offset values from characteristic variations in the alignment disc (PFD23A-RS).
Previously, when not adjusted correctly, inserted discs were not recognized, DRV ADJ Err (Error 6F-E00/6F-E80) appeared, and the unit stopped operating.
Apr 15, 2013 | Sony PDW-F355 DV Camcorder
Pdw u1
This indicates the hard drive has errors from bad sectors to file corruption, the hardware should be tested, maybe possible to repair.
May 08, 2012 | Sony PDW-U1 XDCAM Drive Unit PDW-U1 USB...
My sony dvd oplayer/recorder only sometimes accepts the dvd-rw discs without displaying disc error
That is odd, the only other option is buy a DVD cleaning kit and follow the instructions it might solve your problem.
Mar 07, 2012 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
Hi when i put the XDcam DLA 50 GB disc in my Sony PDW 510 XDCam recorde geve code 03 - 354 error. i dont know about dat. do You can help me ? Thank
03-354
Sep 21, 2011 | Sony PDW-510 Camcorder
Error message 03-354 on Sony PDW-510. What is it?
You may be using a disc that isn't compatible with the camera. This message appears if you put a 50 GB disc in a camera that can only use 23 GB discs. The error will not clear until you put the right disc in.
Apr 11, 2011 | Sony PDW-510 Camcorder
Error 03-454 on pdw1500 deck
What is error03-354 on my Sony XDCAM PDW-F350L?
Thank you. HELP! email: kaltpro@gmail.com
Jan 18, 2011 | Sony PDW-510 Camcorder
I get a "Data Disc" message when I press record.
have you purchased the correct blank discs? sounds like you've inserted discs that can only be used on a PC. these players can only record onto blanks bearing the "compact disc digital audio" mark. these are for use on home audio recorders. hope this helps?
May 02, 2009 | Sony RCD-W500C 5-Disc CD Recorder
Sony XDCAM HD PDW-F330 DV Digital Camcorder Logo
692 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
