Question about FrancisFrancis! X5 Espresso Machine
Francis Francis fuse defective?
Francis Francis x1 fuse defective, power is on to the coffee maker but boiler does not heat up and pump works. It appears to be a defective fuse. Is there a parts manuel to identify the fuse and subsequently purchase?
  • 1,089 Answers
Hi
If you have power its not likely the fuse. It could be the heating element or the board.
Posted on Jun 16, 2009
Francis Francis X1. Why does it work sometimes and sometimes heater trips GFCI?
take it to an appliance repair shop to have it checked out
the trip is working but if you ignore the problem you may get electrocuted
Dec 25, 2015 | Coffee Makers & Espresso Machines
"francis francis" x1 blocked - Fix Suggestions?
You can tell if the pump is working by the noise it makes. Mine got blocked with scale and I took it apart and cleaned out the boiler. It's possible; the boiler is bolted together with standard bolts (metric size). If you've got the interest the Francis Francis is easy to service; you will find a way into each part of it and clean it, and if you do it will work like new.
Jun 22, 2014 | FrancisFrancis! Coffee Makers & Espresso...
My Francis Francis x1 wont heat
You should check the temperature of the water coming out from the machine when it show that is heated. If it is lower than 90 C then the thermostat inside the machine attached to the boiler is need to be replaced. If the temperature of the water is about 90C then the problem is with thermometer, and in this case is only an accesorie since the machine can faction properly and make a good espresso.
May 21, 2012 | FrancisFrancis! X1 - Stainless Steel...
X2 francis francis trips breaker when plugged in?
Hi
Tripping the breaker is usually a bad heating element. You have to check each heating element to determine which element is bad (2 on and X2). Use an ohms meter and check the 2 elements on each boiler for a reading of between 12 and 16 ohms. If no reading that is the bad element. Its in an aluminum boiler so lubricate the end of the bolts(threads) before you try to remove them or they might break.
Apr 27, 2011 | FrancisFrancis! X1 - Stainless Steel...
Boiler gets too hot
Hi Contact Francis/Francis because you need power board.
Apr 12, 2009 | FrancisFrancis! X5 Espresso Machine
Francis Francis X1
Some leaking from the group head of the machine is totally normal while the machine is heating. The reason for this is that the valve that sits above the shower screen is simply a spring and rubber ball. The spring expands, creating a seal with the rubber ball and the boiler, once the boiler reaches a specific temperature. Until the boiler temp is reached, leaking from the group head will occur.
Feb 26, 2008 | FrancisFrancis! X1 - Stainless Steel...
Low temperature
I had the francis francis examined.  It is indeed the boiler, a $200 fix if you could get the part.  Francis Francis X1 is now a brick!
Dec 19, 2007 | FrancisFrancis! X1 - Stainless Steel...
FrancisFrancis! X5 Espresso Machine Logo
595 people viewed this question
Top FrancisFrancis! Coffee Makers & Espresso Machines Experts
dharmanos
Level 1 Expert
Jim Goldsmith
Jim Goldsmith
Are you a FrancisFrancis! Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
