Question about Whirlpool Dryers
Yes i have a whirlpool estate dryer and the fuse is blown. i had a repair tech to come in and he stated that the fuse is the problem. he stated to me that he didn't have a fuse for my dryer model number which is teds680eq2, he stated that he could troubleshoot it and it will work just the same by connecting both fuse wires together because the purpose for the fuse is only to heat the dryer. He stated that it want cause a fire of damage any other components. he put both wire on in the dryer begin heating up immediately. he also said that many tech want tell you this because they know that this part price is very high, about a 60 dollars or more. do you know how true this is or what shold i do. is it safe or will cause some problems later on.
  • 135 Answers
Find a new servicer. The most expensive fuse is about $20. It is VERY NECESSARY as a safety from overheating and even possible fire. Hope this helps!
Posted on Jun 16, 2009
Tip
How to fix your dryer if it does nothing
kenmore, whirlpool, roper,estate,kitchaid,inglis,most of the time if your dryer does nothing you have a bad door switch or blown main fuse,to replace the door switch remove the 2 lint filter screws(top lint filter)pull the top toward you and up,remove 2 screws on old door switch,install new one,to check for a blown fuse remove the back look down to your left and you will see a small white fuse,that is the main fuse-mike
on Feb 11, 2010 | Dryers
I have a whirlpool estate dryer and it will not heat up
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Jan 22, 2011 | Estate Dryers
Estate Dryer eed4300tqr the dryer does not heat at all during it 's heating cycle and how do I repair it.
This is the most common locations for thermal fuses and heating element on Whirlpool,Kenmore,Estate dryers. seth765.jpgseth765_0.jpg
check the continuity on all these thermal fuse and the element replace the one that has no continuty
Jan 18, 2011 | Estate EED4100SQ Electric Dryer
The dryer runs but there is no heat coming out of it
lllThis is the most common locations for thermal fuses and heating element on Whirlpool,Kenmore,Estate dryers. This is the most common locations for thermal fuses and heating element on Whirlpool,Kenmore,Estate dryers. seth765.jpgseth765_0.jpg
Jan 18, 2011 | Maytag Atlantis MDG6400AW Gas Dryer
ESTATE DRYER NOT HEATING
Check for a blown thermal fuse. It's about an inch long and is inside the rear of the dryer, usually attached to or near the exhaust duct. It can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity means a blown thermal fuse. The filter being full of lint has most likely caused the fuse to blow, Sorry for your trouble and I hope this helped. Best wishes.
Sep 14, 2009 | Estate TEDS740JQ Electric Dryer
Dryer does not start
Check the fuse on the blower housing.
To get to the heating element on most of these dryers you remove the back dust cover: whirlpool%20dryer.jpg 1. Hi Limit (small limit upper right hand side of this pic) the most frequent problem if dryer RUNS but no heat. 2. Heater assembly. 7. Control thermostat(s). 5. Fuse(350F), if blown(open) the dryer will NOT run. 4. Heater element.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 13, 2009 | Dryers
Estate dryer by whirlpool
I have the same exact model dryer and it is doing the same thing, in addition the timer does not move at all in the auto position, the dryer will run indefinitely unless you shut it down manually, heating is also sporadic.. would it be the thermostat or the coils we use our dryer daily also.. Thanks
Nov 01, 2007 | Estate TGDS840JQ Gas Dryer
Dryers Logo
95 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
