Question about Hotpoint 24 in. FDW60 Free-standing Dishwasher
FDW60 has standing water in the bottom and will not fill up
Hi My FDW60 has standing water in the bottom. Initially I thought this was a block but upon inspection the waste pipe is clear. When I turn it on it sounds as though it is trying to pump out continuously but it is not filling up. After running a cycle and opening it the washer is full of steam but no water seems to be spraying out.
You most likely have a stubborn clog in your kitchen drain. Try filling the sinks with warm soapy water and then letting the water drain while also turning on your garbage disposal. Sometimes the extra water pressure will help push the clog through.
Posted on Jun 16, 2009
Won't wash
If this happens within the first. 9 secs after filling it means you have a hearing fault
Mar 23, 2014 | Hotpoint 24 in. FDW60 Free-standing...
How to change the fdw60 heating element
Hi The element is on the bottom , so if you disconect water and power then turn unit over so it is laying on the front door , you will see the two connections where the two wires connect to the element and also should see how to remove the element at this time , it's not a hard job just takes some time to get to it
Nov 15, 2011 | Hotpoint 24 in. FDW60 Free-standing...
The tank where the salt goes should that be filled with water, never used a dishwasher before
Yes it should. Mine is always full of water when I fill it with salt. If there is no water how can the salt dissolve?
Nov 08, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Water not pumping away
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
Jun 06, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Leaking dishwasher fdw60
Try the corrugated hose that the water is pumped out through. It may have a small hole which leaks and creates the trip. It's happened to me.
Aug 17, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint Dishwasher not working - FDW60
unplug it for an hour this normally fixes this problem on my machine
Jul 28, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint fdw60 trips consumer unit when switch the plug switch
Hi i have hotpoint FDW60 when i swich the plug and the dishwasher starts then you hear the dishwasher filling up it trips my electric in the house.
Jul 19, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Dishwasher won't empty
sounds like the hose is blocked (usually with broken glass, followed by larger food particles) that runs from the dishwasher to the sink. You may need to remove this piece to check. If that isn't the problem, it's probably electrical.
Jan 26, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Empties and fills but boils the water
Can you hear/see any washing sound/spray, it sounds to me like the wash pump could be faulty.
Nov 20, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint FDW60 problem
Wash motor either seized up/ faulty or the is an itme jamming up the impeller. Regards Advisor
Aug 22, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint 24 in. FDW60 Free-standing Dishwasher Logo
654 people viewed this question
Top Hotpoint Dishwashers Experts
Marvin
Marvin
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
