Question about HP LaserJet P3005n Printer
Noise when printing
Lasejet 3005n makes a thumping noise when printing.
    President:
  • HP Master
  • 1,996 Answers
Try to work through helpful links here, here, or here. or here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jun 16, 2009
WHAT IS THE THUMPING NOISE WHEN PRINTING?
Two possibilities I can provide:
1. The fuser pressure roller is out of round and the noise is the flat spot hitting the hot roller on every rotation.
2. These printers have an envelope mode that activates a solenoid in the fuser when printing envelopes to force air out of an envelope.
If it makes the noise constantly then it is the fuser. If only as the page is exiting then it is the envelope mode.
Oct 09, 2014 | Lexmark T634 Laser Printer
Makes a thumping noise
Most likely your needle needs replaced. As they get older, or hit a pin, they will dull. You can usually tell by your stitch quality, or the thumping sound you are hearing.
Sep 14, 2014 | Euro-Pro Sewing Machines
Creda simplicity TVU1 tumble dryer is making a thumping noise while drying
Hi dave hemming.
I do not believe it is a bearing that is causing your thumping noise
No...you do not need a new drum...all you need is new drum rollers
You probably have a flat spot on one of the rollers, it will make the thumping sound when the drum rotates.
Go to the following webpage and get your drum rollers and install them and that should take care of the noise you are hearing
Please take time to rate me
Bud
http://www.appliancepartspros.com/index.aspx
Oct 13, 2012 | Dryers
Ink carriage started make some horrible noises. Stopped printing. I changed to new ink. Now no ink is printing. Ink carriage just makes thumping noises. Is there a part that can be easily purchased or...
Examine the belt that powers the print head, see if it is excessively sloppy, check the head moves freely along the print head bar, if it snags, there is damage to the bar or the print head holder is worn
TBH, I'd bury it if there is any wear as replacement parts are expensive compared to a new printer
Jan 04, 2011 | Epson Stylus Photo 1280 InkJet Printer
My dryer makes a thump thump sound
  1. Thoroughly check the inside of the dryer for any foreign objects with hard surfaces. Sometimes items that fall out of pockets become stuck inside a dryer and make thumping noises.
  2. Check for level
  3. Make sure the dryer is level. A dryer that is out of level may not rotate properly. Banging or thumping noises from unleveled dryers are common, particularly if the dryer is resting against another metal object such as a washer.
  4. Check rollers
  5. If the thumping noises are present only for the first few minutes of the drying cycle the likely culprit is rollers. If the rollers are warped they will need to be replaced and a professional should be called in to help
Dec 17, 2010 | Frigidaire Electric Dryer
Flashing pyramid of dots,
Your toner cartridge is empty. After turning it off then on again it is probably running for several minutes while making a light thump thump noise. This means it is trying to add toner but not getting any. You need to replace the toner cartridge or have it refilled.
Thank You for using Fixya.
Jun 10, 2010 | Sharp AL 1631 Copier
Dryer making sqeaking noise
greetings,
the most likely answer is the belt pulley..the rollers can also make noise,but they usually will make a thump thump noise..remove belt pulley and lubricate and see if this helps
May 17, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
My 3005N makes a grinding noise when printing
Replace the fuser and fuser idler gear RU5-0957-000CN
Feb 05, 2010 | HP Office Equipment & Supplies
Hp Laserjet printer okay, but making noise
Please rating my solution :-)
If i helped you.
Mar 19, 2009 | HP LaserJet 5000n Printer
LOUD thumping noise when printing
Fuser/ upper heat roller/film or lower pressure roller has lost it's coating, nees new fuser assembly (hot bit at back) about $150 plus labour
Oct 12, 2007 | HP LaserJet 1300 Printer
HP LaserJet P3005n Printer Logo
271 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
