Question about Kenmore Elite 45986 Front Load Washer
My Elite washer has a musty odor. Dried food left in GE Dishwash
My Elite washer has a musty odor. I have run an empty cycle with bleach and still smell it. I wiped inside the rubber part around the washer with bleach. Is there a trap somewhere that may have a sock in it?
My GE Dishwasher leaves dried food bits inside the glasses. Cleaned out the filter in the bottom and use Jet Dry. Ideas?
  • urspidergal Jun 16, 2009
    How do I get the front panel off?
    Looks like it worked! Really smelly goop came out along with a plastic hair thing and 1/2 a pencil! Thanks!
    President:
  • 1,197 Answers
Take the bottom front panel off - after disconnecting the power - and unscrewed the filter/trap. There shud be about a cup of water, some slime and a probably a sock stuck in the filter. it must ve got stuck down in the drain
It was repaired under warranty but the repair man must have missed the sock in the trap. shud be 10 minutes start to finish to remove the front panel, clean the trap and replace the panel. All you need is a torx head driver to remove the three screws at the base of the panel.
Posted on Jun 16, 2009
  • SAM JAYANTH CHANDRASEKAR
    hi this is iversh again.....
    with regard to ur diswasher.....
    If your dishwasher is not cleaning poorly, check these:
    Water-inlet valve
    Most cleaning problems are caused by the dishwasher not getting enough
    wash water, so the water-inlet valve is often to blame. This valve is
    usually at the bottom left or right of the dishwasher, behind the lower
    access panel. It's the device with the main water line from the house,
    a rubber tube to the dishwasher, and two wires attached to it.
    When
    a water-inlet valve is defective, you may hear the sound that's usually
    referred to as "water hammer." If the water-inlet valve is defective,
    you need to completely replace it.
    Internal filters
    Every dishwasher has some type of filter to keep large food particles and foreign objects away from the pump assembly:
    • Most modern dishwashers have self-cleaning filters that don't need any routine cleaning.
    • Some have filters in the bottom of the dishwasher that
      you need to periodically clean. You don't need any tools to remove the
      filter, and cleaning it is easy. Consult your owner's manual to
      determine which type you have and its maintenance requirements.
    If your filter is clogged, it may be causing the cleaning problem.
    Drain valve
    Some dishwashers have a valve (or gate) that should open only during
    draining. If debris lodges in the valve, it can't close properly, so
    water drains out during the wash cycle. Most dishwashers drain into the
    garbage disposer. If yours does that, listen for water flowing into the
    disposer during the wash cycle. If you can hear it then, the drain
    valve may be clogged.
    Spray arms
    There's a spray arm at the bottom of your dishwasher--it may have a
    tall spray tube mounted to the center of it. There may also be a spray
    arm located directly beneath the upper rack of dishes and/or above the
    upper rack.
    If
    debris is blocking the holes in the spray arms where the water comes
    out, it could cause cleaning problems. Regularly inspect each of the
    spray arms and clean out the holes as necessary.
    Water temperature
    To get the best cleaning results, the water entering your dishwasher
    needs to be hot enough. Try running the hot water in your kitchen sink
    for about 30 seconds before starting the dishwasher, to pre-heat it.
    Also, if your dishwasher lets you select a higher wash or rinse
    temperature, try that to see if it helps.
    To
    check the temperature of the hot water that comes from your kitchen
    faucet use a waterproof thermometer. If the water isn't 120 degrees
    Fahrenheit, your dishwasher may have trouble getting your dishes clean.
    You could increase the temperature of the hot water to the whole
    house--and therefore the dishwasher--by adjusting the hot water heater
    thermostat.
    Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
    Detergent cup
    Dishwashers don't perform their best if detergent is introduced only at
    the beginning of a cycle, so add detergent to both parts of the cup.
    Please do rate the solution as FixYa if u found it helpful.....
    good luck
    There are three T15 Torx screws along the bottom of
    the panel. Once it is off, you will have access to the pump to remove
    the filter and clean it out.
Want to remove odor from dryer
Hi photoed1
The odor that you are experiencing may be from the growth of mold.
Inside the washer, some small pool of water may be left standing and is harboring mold spores.
Even though you may operate the washer regularly, the mold spores are not being washed away.
Here is a couple tips that might help to eliminate odor issues in your washing machine.
First, and the most effective is to, leave the lid or door to the washer open.
By leaving the door open, it promotes air circulation and evaporation of standing water.
The reduction in odor occurred quickly and dramatically.
Another tip is to run the washer empty for a quick rinse cycle.
Add an entire cup of bleach at the start of the cycle.
The bleach is effective at destroying organisms, such as mold and bacteria.
However, running it once will not be completely effective.
I suggest pouring another cup of bleach into the wash tub, after the cycle has completed.
This will leave bleach as the standing pool and should prevent the growth of mold or bacteria.
However, if you do this, before doing a load of laundry you should run an empty rinse cycle again,
to avoid damage to the clothes from the bleach left standing in the wash tub.
Please take time to rate me
Bud
Apr 18, 2013 | GE Dryers
Why does My washer have a moldy musty smell?
The odor that you are experiencing may be from the growth of mold. Inside the washer, some small pools of water may be left standing and is harboring mold spores. Even though you may operate the washer regularly, the mold spores are not being washed away.I have a couple of tips that might help to eliminate odor issues in your washing machine. First, and the most effective in my research is to, leave the lid, or door to the unit open. By leaving the door open, it promotes air circulation and evaporation of standing water. The reduction in odor, will occur quickly and dramatically.
My second tip is to run the washer empty for a quick rinse cycle. Add an entire cup of bleach at the start of the cycle. The bleach is effective at destroying organisms, such as mold and bacteria. However, running it once will not be completely effective. I suggest pouring another cup of bleach into the wash tub, after the cycle has completed. This will leave bleach as the standing pool and should prevent the growth of mold or bacteria. However, if you do this, before doing a load of laundry you should run an empty rinse cycle again, to avoid damage to the clothes from the bleach left standing in the wash tub.
Apr 30, 2011 | Asko W6021 Front Load Washer
Musty smell
The odor that you are experiencing may be from the growth of mold. Inside the washer, some small pools of water may be left standing and is harboring mold spores. Even though you may operate the washer regularly, the mold spores are not being washed away.I have a couple of tips that might help to eliminate odor issues in your washing machine. First, leave the lid, or door to the unit open. By leaving the door open, it promotes air circulation and evaporation of standing water. The reduction in odor, will occur quickly and dramatically. My second tip is to run the washer empty for a quick rinse cycle. Add an entire cup of bleach at the start of the cycle. The bleach is effective at destroying organisms, such as mold and bacteria. However, running it once will not be completely effective. I suggest pouring another cup of bleach into the wash tub, after the cycle has completed. This will leave bleach as the standing pool and should prevent the growth of mold or bacteria. However, if you do this, before doing a load of laundry you should run an empty rinse cycle again, to avoid damage to the clothes from the bleach left standing in the wash tub.
Aug 11, 2010 | Kenmore Elite 45986 Front Load Washer
GWL15 Model musty odor
You need to clean your filters and pump out, after which, you need to flush the system with white vinegar and water 50:50 make up a bucket of solution, and after cleaning all the lines pump, and filters, put the solution in the bowl, and run the short cycle to push the water through, this should help. You need to wash all parts in same type solution or bleach.
Jul 14, 2010 | Fisher and Paykel GWL11 Top Load Washer
My front loading washing machine has a musty odor. what can I do?
My second tip is to run the washer empty for a quick rinse cycle(on hot water cycle). Add an entire cup of bleach at the start of the cycle. The bleach is effective at destroying organisms, such as mold and bacteria. However, running it once will not be completely effective. I suggest pouring another cup of bleach into the wash tub, after the cycle has completed. This will leave bleach as the standing pool and should prevent the growth of mold or bacteria. However, if you do this, before doing a load of laundry you should run an empty rinse cycle again, to avoid damage to the clothes from the bleach left standing in the wash tub.
  • Additionally, inspect the door gasket for gunk or mold. Clean the gasket well. This is another gathering spot of bacteria and mold growth.
Jun 28, 2010 | Kenmore Washing Machines
My Kenmore Elite smells like mold!
Run a cycle ,no clothes in, with about 3 cups/ 750 ml of bleach in it. How? put a fil a plisticbag with the bleach and set it in the washer. It will tip up when you start the cycle. You should end up with a clean washer and clean empty bag.
Jun 27, 2010 | Kenmore Elite 45986 Front Load Washer
My washing machine has a musty smell. How do I clean it?
Dec 04, 2009 | LG Washing Machines
My GE Front load washer (WBVH6240) has an odor that smells like mildew in it. If the is left closed the odor is really bad. Do you know how to fix this or what is comes from?
run a empty cycle with bleach on whites/ sanitize. clean boot (rubber gasket at door) with bleach or other cleaner inside especially at bottom, make sure 3 holes at bottom are clear.
this may take multiple cycles to rid of odor.
For maintenance, you should wipe excess water from boot after last load, and check lower drain holes. Once a month wipe boot with windex or other. and run cleaner cycle (empty) newer machines have a special clean washer cycle. (6240 doesnt).
Also clean your drain pump filter at bottom front behind access panel.
If boot is really bad , replace.
Jul 16, 2009 | GE WSXH208A Front Load Washer
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a “Clean Cycle” available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 16, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
158 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
