Question about LG Flatron L1951S 19" LCD Flat Panel Monitor
LG1719S blank screen but with a flicker
Same as the original poster, screen is black, green light is on and for a split second it does flicker on.
As mentioned you cannot access the monitors menu so I assume that there is a fault with the monitor itself rather than any graphics card problems.
My question is is it worth being looked at / fixed or just buy another monitor?
  • LG Master
  • 2,404 Answers
Its a problem with the lcd and the cost to replace the screen is more then the cost of getting a new monitor.
Posted on Jun 16, 2009
Pinstripe cinema display flickers on momentarily then goes black. Image comes back for a split second while when power light glows steadily then goes away while power light flickers. this is a 22"...
when the screen is black and the power light is steadly lit, shine a flash light at the screen. if you can see something, the inverter board is bad and the back light cannot turn on. if the power light flickers, reseat the power plug and put your ear to the back of the monitor where the power plug is. if you hear a buzzing or any high pitched noises; the power supply is bad. use the macufactures warranty for repairs.
Nov 18, 2009 | Computers & Internet
Sony ericsson w910i blank screen
this because of the strip inside the mobile...i think that got damaged in u r mobile...so u just give u r mobile to u r sony service sation and they will take care of u r mobile....and then u r mobile will be proper...be cool!!!!
Aug 05, 2009 | Sony Ericsson W910i Cellular Phone
Blank screen
You said it correct the fluorescent bulbs are going bad, unfourtunately the are part of the screen (panel).
to replace the panel make sure you get the exact part # from the panel inside rear and check prices online and on ebay.
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Aug 03, 2009 | Princeton Digital VL2018W Monitor
Lg flatron blank screen
t certainly seems like the monitor is not getting a signal. Did this happen after you changed something, or just on normal boot up?
It could be the video card that has failed.
Also, check the pins on the connector; sometimes they can get pushed in.
If you can, try swapping out the video card or use the monitor on another computer.
Good luck,
May 09, 2009 | LG Flatron L1951S 19" LCD Flat Panel...
Screen goes blank after a few seconds
Hi ,
The monitor flicker problem. The monitor when turn on will display image for couple of second then turn black. The monitor status led is still green. This will happen each time it is turn on. The symptom at appear to come from the inverter board.
May 08, 2009 | NEC-Mitsubishi NEC Display Solutions...
Blank screen
its cheap buy a good one!!!!!!
Dec 22, 2007 | Computers & Internet
MONITER LIGHT IS GREEN BUT ONLY SHOWS A NORMAL SCREEN FOR 1/2 SECOND THEN TURNS BLACK
HI. I had the same problem with mine. It would flash the screen on for a split second and then turn black, the whole time the power light remained green. Upon opening up the case, I pulled the combo power supply board/inverter board out for inspection. I noticed one of the capacitors had a bulge on top indicating it was bad. It was the the 680uf 25v capacitor. I desoldered it, and soldered in the new one. After hooking everything back up, bingo!! Monitor now works perfectly. I couldn't find an exact match to the capacitance locally, but I had a 1000uf 35v cap in my utility box. It worked fine as a replacement. You can usually go within 30 percent of tolerance and be alright. Just don't go under on capacitance or voltage. I hope this helps.
Nov 25, 2007 | LG Flatron L1710M 17" LCD Monitor
Bank Monitor problems
Unplug the cable from your PC, if the monitor shows a test image, the monitor is fine and the problem is with your graphic card. If you dont see nothing on-screen after unpluging the cable from the PC, then the monitor in damaged. Send it to repair.
Jul 09, 2007 | Dell E193FP 19" LCD Monitor
Monitor flashes image for split second then goes blank but green LED flashes as well
while the monitor is still powered on, but with the LED flashing, unplug the monitor from the PC. press the power button, and the monitor should go off, now plug the pc back into the monitor. Turn the monitor back on and it should work.
Occasionally this will not work for me, but if I repeat it it normally works
Hope this helps - my problem is intermitant so it may be different to what u guys have
May 02, 2007 | ViewSonic VX924 19" LCD Monitor
LG Flatron L1951S 19" LCD Flat Panel Monitor Logo
208 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
