How do I gain access to the inside of my Gateway MX3416 laptop to be able to replace the heatsink fan? I removed all of the screws that I can see, but cannot find what is holding it together at the rear, near the hinge area.
  • 244 Answers
Usually there are some screws that holds the laptop together under the keyboard.
Remove the keyboard, and find those screws.
That will do.
Please don't forget to rate this answer if it helps.
Posted on Jun 16, 2009
    President:
  • 828 Answers
Read the manuals and search for initiative to remove the heat sink fan...
I'm user gateway nv48 but my problem now my laptop always auto shut down when i play games. if surf internet it not happen like that.if i put my laptop in my hand and put it not flat , my fan laptop create...
Your computer is shutting down due to overheating. Since the fan is making noise it is not working or cooling correctly either because it has lint or debris interfearing with the fan blades, ot the fan bearing is going out. To determine this you need to access the fan and clear it of any blockage. You will need to remove the keyboard to access it. Not all Gateway models are the same but once under the keyboard you should be able to work with it. CLICK HERE for keyboard removal instructions. If you find lint or dust blocking the fan exhaust at the heatsink and can clear that out your laptop will run much cooler and should solve your problem. If the trouble is with the fan itself you can still find a replacement and be able to swap it out.
(if the removal of the fan requires removal of the heatsink assembly you will also need to apply new thermal compound between the CPU and heatsink after cleaning the old compound off with rubbing alcohol.)
Apr 25, 2011 | Gateway Computers & Internet
Gateway MX3416 will not boot. LED light indicating that there is a battery is still on. Screen is black but the CD-ROM drive seems operational. Removing RAM and replacing did not help.
Does the Gateway appear to boot up but you do not get an image on the screen?
Does the power LED light up and does the hard disk LED flash as the Gateway boots up?
If so then the Gateway could have a back-light problem or the video card may be faulty.
To determine the exact fault, please click on this link and follow my instructions to determine the fault an possible fix :-
http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Jul 02, 2010 | Gateway MX3416 Notebook
Vaio CS17G crashing due to overheating. Please guide in deassembling it so dat i can check the heatsink and fan
There is a panel beneath the laptop with 3 screws. Take the panel off and you can gain access to the heatsink and fan
Jun 08, 2010 | Sony VAIO VGN-CS110E/W NoteBook
Laptop will not power up ... Gateway MX3416. Blue light when power button pressed and goes away once power button released.
pull the power cord out from the main socket. Remove the battery . leave it for 5 minutes. Restart. Below link might be help full if you still have the problem..
http://pc-and-peripheral.blogspot.com/
Oct 16, 2009 | Gateway MX3416 Notebook
I need to replace the cooling fan and heatsink on my Gateway ML6720. I'm having trouble finding the part. If I can find it, can you tell me how to replace it?
The best thing you can do is replace the fan itself with a like kind of shape and size. I usually do this by going to a computer store with the old fan and matching it up with the ones they have in stock, or measure the size in milimeters and buy one on line. The fan is held on by 4 screws and it is much easier than trying to remove the heat-sink and take the chance of damaging the motherboard. You can just screw the new fan to the old heat-sink and you are done, plug it in and insure the fan is blowing in the right direction and you are done. Good Luck, RAC
Apr 20, 2009 | Computers & Internet
Gateway 7510GX CPU Fan noise
If this is a brand new laptop it would be still under warranty.
I suggest returning it to the supplier for repair under warranty because if you attempt to repair it you could void your warranty.
You should only attempt repairs after the warranty has expired.
Apr 06, 2009 | Gateway 7510GX Notebook
Hi my dv 9000 makes ugly sound-noises
If it is the fan, it may simply be cruft inside the brushless motor. It is possible to fix this following HP's manual at: http://h10032.www1.hp.com/ctg/Manual/c01311536.pdf
Once you gain access to the heatsink/fan assembly (this takes 6-90 minutes), you can remove 4 small screws, remove the fan from the motor, and clean it out. This worked for me.
Warning, many components are very ESD sensitive, and the flat cables and connectors are fragile.
Note to HP: Please make these easier to service! Adding a removable panel would have made this a 10 minute operation.
Jan 20, 2009 | HP Pavilion dv9000z Notebook
Toshiba laptop shuts down on its own
Solution:
If the CPU heatsink is not clogged with dust and lint completely, you can use canned air and just blow it inside the laptop through the openings on the bottom and on the sides. It’s nice as a precaution measure, but it might not work if your laptop already has a problem and the heatsink is completely clogged.
Open the laptop case, so you can access the CPU fan and the heatsink. In some cases you can access the heatsink through the latch on the bottom of the laptop. Sometimes (for example Toshiba Satellite A70/A75) you have to open the laptop case all the way down.
Carefully disconnect the fan cables on the system board and remove the fan. If the fan makes unusual sound when it spins (grinding sound), I would recommend to replace the fan.
Clean the fan and the heatsink with compressed air.
I would also recommend removing old thermal grease from the CPU and applying new grease for better heat conductivity.
Nov 27, 2008 | Computers & Internet
Gateway mx6448
The biggest removable door held on by about 6 screws on the bottom of your laptop is what you need to remove. Once inside you will see your heatsink! Very easy to access, I wish you luck.
Mar 11, 2008 | Gateway MX6448 Notebook
Black screen..computer working
Hello Sir,
This is the Dust problem.If the CPU heatsink is not clogged with dust and lint completely, you can use canned air and just blow it inside the laptop through the openings on the bottom and on the sides. It’s nice as a precaution measure, but it might not work if your laptop already has a problem and the heatsink is completely clogged.
  1. Open the laptop case, so you can access the CPU fan and the heatsink. In some cases you can access the heatsink through the latch on the bottom of the laptop. Sometimes (for example Toshiba Satellite A70/A75) you have to open the laptop case all the way down.
  2. Carefully disconnect the fan cables on the system board and remove the fan. If the fan makes unusual sound when it spins (grinding sound), I would recommend to replace the fan.
  3. Clean the fan and the heatsink with compressed air.
  4. I would also recommend removing old thermal grease from the CPU and applying new grease for better heat conductivity.
Mar 11, 2008 | HP Compaq nx6125 Notebook
Computers & Internet Logo
216 people viewed this question
Alun Cox
David Payne
David Payne
