Question about H.D. Hudson 2g Yard N Garden Sprayer
I have a hudson classic sprayer and have no instructions.
Need to know how to remove top to fill it.
  • 3 Answers
The pumping mechanism should unscrew from the plastic bottle. Push the handle all the way down and try to unscrew the pump while holding the bottle steady.
Posted on Jun 16, 2009
  • jfmyers7
    jfmyers7 Jul 23, 2014
    how do I get instructional manual ?
Hudson parts for 30161 sprayer where to buy
Direct, eBay, Amazon.
To speak with an expert, please call 1-800-9-SPRAYER
and someone will assist you with your inquiry.
Product Search ' H. D. Hudson
www.hdhudson.com/product-search
Hudson® Universal Maintenance Kit Model 6972. One Kit Repairs over 90% of Hudson Sprayers with Genuine Sprayer Service Parts! 6972 Hudson® Universal Maintenance Kit. View Product Details ...
HD Hudson: Home
www.hdhudson.com/ HD Hudson Manufacturing Company is the world's leading manufacturer of innovative, high quality, consumer and commercial sprayers and sprayer systems.
Product Details ' Hudson® Universal Maintenance Kit ' H. D. Hudson
www.hdhudson.com > Product Search Simple parts kit offering - one kit repairs over 90% of all Hudson® sprayers! Contains necessary parts to rebuild the majority of both metal and poly sprayers. In most cases, kit will upgrade existing components on customer's sprayer; Contains Viton® O-Rings, TOV™ Thumb Operated Valve, Pic-A-Pattern™ Fan/Cone nozzle ...
Product: Hudson Eliminator Sprayer - 1 Gallon, Model# 30161
https://www.northerntool.com > Sprayers > Handheld Sprayers Item #268137 is no longer available. Hudson Eliminator Sprayer - 1 Gallon, Model# 30161. Find Similar Items. Replacement Parts Available. More Info · Find Parts ...
Hudson Pump Sprayers Parts: Amazon.com
https://www.amazon.com/slp/hudson-pump-sprayers-parts/2naarhymmyr79cg
Buy products related to hudson pump sprayers parts and see what customers say about hudson pump sprayers parts on Amazon.com ? FREE DELIVERY possible on eligible purchases.
H. D. Hudson Manufacturing Company Online Store
hudson-sprayer.com/ COMPRESSION. SPRAYERS. ? Locate Sprayer Parts · ? World Health Library · ? Newsletters. This equipment has been found to comply. with the performance guidelines of the. World Health Organization Specification. number WHO/VBC/89.970.
Hudson Sprayer ' eBay
www.ebay.com/bhp/hudson-sprayer Find great deals on eBay for Hudson Sprayer in Find More Garden Tools & Equipment. Shop with confidence. ... Hudson 62062 Bugwiser 2 Gallon Sprayer Galvanized Steel,No 62062 Hudson, H D Mfg Co 62062 029925620629. ItemWeight: 5.59. ... Hudson Brass Extension Wand with Nozzle Trigger & Parts Set. $18.00.
H D Hudson Sprayer Parts - Sears
www.sears.com/search=h%20d%20hudson%20sprayer%20parts Items 1 - 37 of 37 - Hudson H. D. Hudson Manufacturing Company H. D. Hudson 96302E H. D. Hudson Comando Sprayer, 2 Gal, 18 in Extension, 42 in Hose 96302E Pack of 1 · 0 · Sold by SIM Supply · Hudson H. D. Hudson Manufacturing Company H. D. Hudson 20012 H. D. Hudson Multi-Purpose Poly Sprayer,. $31.13 ...
Hudson Sprayer: Amazon.ca
https://www.amazon.ca/slp/hudson-sprayer/e675o8k2yzys3u8 Buy products related to hudson sprayer and see what customers say about hudson sprayer on Amazon.com ? FREE DELIVERY possible on eligible purchases.
Hudson Universal Maintenance Kit
Apr 07, 2018 | Coffee Makers & Espresso Machines
Looking for hudson sprayer repair kits
you will need to contact them from here
http://www.hdhudson.com/contact-us
they will direct you to the closest reseller of their kits or they can ship one to you.
Dec 29, 2012 | H.D. Hudson 2g Yard N Garden Sprayer
Why does Pump not build pressure
probably bad seals or ring or the relief valve is stuck open
Aug 29, 2012 | H.D. Hudson Hudson Pumpless Sprayer 2...
I'm not sure how to fill the thing. It's a 2 gallon sprayer, yet when I open the top (i.e. remove the pump mechanism), there is a chamber, but it only holds about 1/4 gallon. How do I get the...
it sounds like you unscrewed the pump assembly. that chamber is actually part of the pump and sometimes they do separate. try to remove what you called the chamber. if that is part of the pump then it has to come out before you can put the pump assembly back together.
May 25, 2011 | H.D. Hudson 2g Yard N Garden Sprayer
How do i fill my hudson sprayer
On the link below page 2 will tell you how to fill your sprayer.
http://www.hdhudson.com/PDF_files/poly-sprayer-instruction-sheet.pdf
Good Luck and please rate 4 thumbs up for the free answer.
Jun 27, 2010 | Eliminator Hudson Sprayer - 1 Gallon,...
I have the hudson eliminator sprayer and squeeze the trigger I just get one burst of spray and then a couple of drips. I do have it pumped up all the way. What is the problem?
IF your sprayer is full you should be good to go after 20 or so full stroke pumps
If it is not spraying unscrew the adjustable tip and clean out the little holes around the end
If you leave spray in the unit after using it it will get crudded up and plug up
Mar 08, 2010 | H.D. Hudson Hudson, H D Mfg Co 1 - 1/2gal...
How to remove lid
The only way that I know of is to hold the bottom part (jug) securely and turn the pump handle. If you put some pressure on there and just hold firmly it should eventually start to unscrew. You need to push the pump handle down as far as it goes and it will lock into some "ears" on the pump assy so it will turn the pump assy as well.
Sep 06, 2009 | Eliminator Hudson Sprayer - 1 Gallon,...
From jdwillia on hudson sprayer
I poured hot water in the top and let it soak for ten minutes. Removed pressure valve and it broke free.
Jun 16, 2009 | H.D. Hudson 2g Yard N Garden Sprayer
Need help with Hudson Trombone Tree and Shrub Sprayer Model 61224
There's a parts illustration on the Hudson web site that may be helpful to put the sprayer back together correctly. Here's the link: http://www.hdhudson.com/PDF_files/10.pdf
Jun 16, 2009 | H.D. Hudson Hudson Trombone Sprayer - 140...
H.D. Hudson 2g Yard N Garden Sprayer Logo
1,359 people viewed this question
Top H.D. Hudson Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
Are you a H.D. Hudson Garden Expert? Answer questions, earn points and help others
