Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Whirlpool washer will not stop at end of cycle
Washer does not stop at end of cycle and does an extra rinse. when it does extra rinse water is real slow to fill. The extra rinse is not wanted.
    President:
  • 3,113 Answers
Turn off extra rinse switch or pull wire going to it. If water is slow the water valve may have a restriction in it. Remove hoses and check for blockage in the hose screens.
Posted on Jun 16, 2009
What is the capacity of a front loading whirlpool washer MO#GHW9150PWO
Whirlpool GHW9150PW 27 Inch Duet Front-Load Washer with 3.8 Cu. Ft. Capacity, 8 Wash Cycles & Triple Dispenser.
whirlpool ghw9150pw0 capacity Google Search
Nov 25, 2017 | Whirlpool Washing Machines
Water will not spin out. Code says 5d
The troubleshooting page in the owner's manual says: 5d "Sd" Suds Detected - Did you use regular detergent? Regular or hand-washing detergents are not recommended for this washer. Use only High Efficiency (HE) detergent. Did you add too much detergent? Always measure detergent. Follow detergent manufacturer's directions. If excessive suds are detected, the washer will display this code while running a suds reduction correction routine at the end of the wash cycle.The susds reduction routine removes extra suds and asures proper rinsing of your garments. If te code remains and the wash cycle dial is flashing after the recovery routine has stopped, re-select your desired cycle using cold water. Press start. Do not add detergent.
Dec 31, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool washer stops in the middle of cycle does not rinse and
If your washer stops at the same time each wash, you have a dead spot in your timer. It will need to be replaced. .
Aug 15, 2009 | Washing Machines
My whirlpool washer fills up with hot / warm water (cold doesn't work) pretty quick for the washing cycle but it takes forever when filling the rinse cycle....help
The amount of water on the rinse is lower becaus it's using cooler water. You stated that the cold water isn't working.
Shut the water supplies off. Take the hoses loose from the hose bibs. There should be screen washers in the end of the hose. These are to catch the sediment that normally flows through the water supply pipes in our homes... Take the washer screens out and clean them with an old toothbrush.
Reinstall and while you're at it clean the hot side too.
Then take the machine end of the hoses off and check that it's all clear there as well.
Re install and run your machine on a cycle and monitor it to see if there is better flow on the cold wash cycle AND the rinse portions of your cycles...
If there is no screen washers in the hose, chances are you'll need to clean the water supply valves in the machine... real fun.. HOPE There's washers in your machine..
K
Jul 24, 2009 | Whirlpool Washing Machines
Extra rinse cycle
Press the button and you will get an extra rinse cycle at the end of a normal rinse cycle. A B C
May 25, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
LA5558XSN0 Washer ExLarge Rinse Cycle doesn't engage
sounds like adrain line issue, your creatring a syphoning effect . id assume thedrain line is either real low, perhaps running across thefloor or is screwed tightly to a longer hose ejecting through a wall with a full dry well
Feb 26, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Adds water at the end of the spin cycle
If it is just splashing the water at the end of the cycle and shutting off-timer issue.
Sep 15, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care II GSQ9669LGO
Sounds like you may need to replace the timmer
Jun 06, 2006 | Whirlpool Ultimate Care II GSQ9669L Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
321 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
