Question about Sanyo Televison & Video
My picture is not good. I'm hooked up to digital
My picture is not good. I'm hooked up to digital cable but not a HD service. How can I improve my picture. I cannot figure out how to use my digital tuner.
  • 92 Answers
To get best picture and sound you need to use HDMI connection. This is normally if you have a HD cable box. If you don't have a HD box, use the coax connection directly from the cable line. On your TV, hit the menu button, use the arrow up/down to select manual channel search, select cable and hit enter. this will scan all the digital and analog channels.
Posted on Jun 16, 2009
I brought a 43 in Vizio D43n. I have standard cable box not HD.Can I just use it with this TV ? Or do I have to shell out an extra $ 10.00 a month?
Hiya!
The simple answer is yes
All newer TVs play digital stations by default
Even on good ol' 'antenna' setting
Nov 20, 2016 | Vizio Televison & Video
I bought a lg 42le4500 led/lcd tv and hooked it up to my v+ box via a hdmi lead, but picture is a bit fuzzy is there somthink i can do to sort this?
Check the setting on the V+box for a HD setting hook up should improve the picture.Still have the same problems,the HDMI cable it is the problems,changes another HDMI cable
May 10, 2011 | LG 42LE5400 42 in. LCD TV
I just bought my 42in last night and I attached my cable box to it, with a normal black coaxal cable and the red/white/yellow hookups. The only problem i have is the picture looks kind of grainy and...
Cable box have HDMI port,hook it up on a HDMI cable to the tv,will improve picture quality greatly.Tries HDMI cable to hook up the PS3 system and go in setup changes to HDMI setup will get HD format picture,will be very clear no more grainy and inconsistanty.
Feb 17, 2011 | Sansui HDLCD-4212 LCD TV
Hi My LG 52LB9DF tv is slightly blurry - I'm not sure if it's the size or quality of the tv? Even the HD channels are slightly pixellated. My friend has a smaller tv with a much sharper resolution....
1. Your TV has a digital tuner built-in, you do not need a set-top box to receive local digital channels.
2. Try to disconnect the box, hook up the antenna directly to the TV antenna input & program the tuner, you may getting better picture.
Aug 29, 2017 | LG 52LB9DF LCD TV
New flat screen hdtv has a fuzzy picture
Yes you will get a better picture quality out of a cable box if you get an HD cable box.
The reason you are getting the diminished picture is due to the signal you are feeding the TV is an analog signal. The newer HD TV's are made for digital TV and this older technology shows all its flaws on this type of TV.
When you get the new box understand that the same channels you are getting plugged directly into the tv are still going to have some grainy look to them but the good thing is that a lot of them are starting to be rebroadcast on HD channels and that is where your new toy will truly shine.
Enjoy your new TV...
Good Luck...
Jan 05, 2010 | Philips 23PF5320 23 in. HD-Ready LCD...
Picture out of focus at times
Firstly, to get a "Shop" standard picture, you need to have a true HD feed. Usually a demo disc filmed in HD at 1080p, played on a true HD system at 1080p into your TV. Most broadcast feeds at present are on 720p.
However, you can improve the picture significantly just by changing a few settings on the TV:
Contrast: Change to about 65% of maximum. Too much
contrast gives a blurry / grainy image.
Sharpness: Change to about 20% of maximum
Also turn of any dynamic or digital contrast settings on the TV (if it has them)
Apr 19, 2009 | Televison & Video
Component Cable
Component video quality is better then Composite Video (yellow wire)
Of course component cable hook up will improve picture quality.
Feb 04, 2009 | JVC HR-XV1 DVD Player/VCR
How to improve picture quality?
are you using an hd source ? hd cable box, satelitte receiver or antenna with the digital channels programmed in. regular tv channels will not look as good as the picture you saw in the store when you bought it. they all use only high definition signals.
Dec 14, 2008 | Sony BRAVIA KDL-40S2010 40 in. LCD...
HD Hookup on Dish Network 2nd Location
In order for you to receive HD broadcasting you must have a HD-TV, otherwise you wont get the picture in HD. Also I should point out that you need to make sure that the signal itself is being broadcast in HD.
Apr 28, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Directv Samsung problem
I also have directv.At this point,it is a video signal issue on their end.The up conversion is ok at best.Depending on the original video that is probably as good as it gets.The other problem is the wow factor from hd.It is hard not to be critical of the non-hd channels.
Mar 02, 2008 | Televison & Video
Televison & Video Logo
85 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
