Question about LG BG8000ER Air Conditioner
Compresor turn off every 3 mintue
My ac cut of after 3 mintue
  • 378 Answers
Ya the compressor might be switch off by the thermostat . the thermostat setting might be not cool or # 2. Or thermostat need replacement if you had set it to the cooler side.
Posted on Jun 16, 2009
Repleace ac compresor for ml 320 99 year
evacuate the system,remove a/c lines from compressor,remove belt,then 3 bolts,2on the body of compressor and one on the back. thats simple.
Jun 27, 2012 | 2001 Mercedes-Benz M-Class
A/c compresor cuts out after 10 minutes
first..have you serviced your in cabin air filter? If not do so before proceding. second...your AC compressor relay or AC clutch switch may be going out. third.. you may need to recharge the system.
Sep 03, 2010 | 1998 Ford Ranger SuperCab
My ac is blowing hot air. I have taken it to 3
maybe its not leaking, did they check the clutch on the ac compresor
Jun 12, 2010 | 2006 Ford Expedition
AC light blinking
you need an ac mag clutch relay under the hood in fuse block behind battery
Apr 25, 2010 | 2002 Toyota Camry
2006 Chevy Cobalt cuts off if ac is running
this may be a compresor issue,when the car is normal(a/c off) the compressor is not draging the engine,how ever when on if the compressor is goin bad(seizing) will turn your engine off and the belt will drag. have you compressor checked and also see if the system is over charged.
Sep 10, 2009 | 2007 Chevrolet Cobalt Coupe
Compressor not cycling on and off
unless the compresor is on u cant get a good eye on if ther is enough freon but still should cycle on and off/if it has a low side cut out switch (scews in the large line with two wires)that can be checked by bypassing the switch/but mind u it could still have a problem with ac system/and if the ac works when bypassed(very short run time)then replace switch with new one right away,also look for ac clutch relay and check or replace
Jun 30, 2009 | 2002 Dodge Durango
I bought a sensor for the ac because it wont throw cold air, i dont seem to find were it goes. they told me it was next to the radiator but still cant find. please help
if it is near the radiator it must be a high side clutch cut out or highside fan switch/follow small ac line/hose out of ac compresor ,it should go to condenser the witch is probley in that line
Jun 30, 2009 | 2006 Lincoln Zephyr
AC dask board signal
Replace the A/C compressor revolution sensor, bolted to the side of the compressor, unless the connector was inadvertantly left unconnected. This is the only reason the AC light will blink.
Aug 31, 2008 | 1995 Toyota Tercel
AC switch located on dask board blink went turn on
that means that it did a self initialization. does the a/c work?
LG BG8000ER Air Conditioner Logo
170 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
