Question about RTO Tractor Forks Bucket Forks, Pallet Loader, Skid Steer
I ran out of gas and wont astart back up what do i have to do
  • 32 Answers
Maybe put some gas in the gas tank.
Posted on Jun 21, 2009
  • 474 Answers
Is it a diesel tractor? if it is depending on the age you may have to bleed the injecters. before you do this look at the injecters and determine if there is 1 or 2 lines going to it. if there is oly 1 line then you have to bleed them manually. this is done by loosening the line nut on top of the injecter. it is best to have a freind help you. loosen half the injecters skipping every other one. make sure that you can tighten them back with only a half a turn or so. have you pal crank the motor over while you watch the injecters. air should start bubbling out of the top of the injecter. when the air stops and just fuel comes out tighten the injecters. this will ussually let the engine start. then with the motor running crack the lines one at a time to get rid of the air on the remaining injecters. this step may have to be repeated several times to get th motor to run right.be aware that the pressure on the fuel coming out is at high pressure and can hurt you or catch on fire so I dont advise smoking while doing this. if the injecters have 2 lines it is self bleeding and you should have a primer pump. locate and pump until you have good resistance. turn over motor no start then repeat.
Posted on Sep 12, 2009
Ran out of gas out gas back in wont start wont?
you haven't mentioned what make or model of vehicle
you will have to check that the pump is actually working as some fuel pumps have small plastic gears as the pump and when run out of fuel these gears have no lubrication and so melt in the case
( toyota 4 runner from experience)
Jul 18, 2015 | Cars & Trucks
Ran out of gas and wont start
ran out of gas while it was warming up , I put gas back in it and turned the key a few time still wont start up
Jan 03, 2014 | 2000 Dodge Stratus
Ran out of gas and now wont start 1994 jeep grand cherokee
check the installation of fuel injection or carburetor your...
Jan 16, 2012 | 1994 Jeep Grand Cherokee
Ran out of gas and wount start
if u just ran out of gas and it wont start first put gas in it if u have all ready done that make sure your putting at least a half tank in so you fuel pump can start up again. if it still wont start give it a bit then put it into acc just before start e brake on go to the back of your car to your gas tank under your car not were u fill and lisen for a buzzing noise thats the pump if u do not get that bring it in for maintenance.
Nov 19, 2010 | 2001 Pontiac Grand Prix
Ran out of gas, replaced gas try starting, wont
hit the key five times without trying to start, just bump the starter, after the fith time turn it over and it should crank
Mar 23, 2010 | 1999 Cadillac DeVille
1998 chevy malibu turned car off at gas station want start back
sounds like an antitheft system malfunction - check to see if light stays on after you remove the key
Jan 09, 2009 | 1998 Chevrolet Malibu
ASTART LTV-26HBG
Are you still having these connection problem? Please call me at 323-767-6030 and I will go through it, with you.
Thank you,
Ivan.
May 25, 2008 | Astar LTV-19BG TV
RTO Tractor Forks Bucket Forks, Pallet Loader, Skid Steer Logo
372 people viewed this question
Top RTO Garden Experts
John Trevino
Joseph Mueller
Joseph Mueller
JOHN BROWN
Are you a RTO Garden Expert? Answer questions, earn points and help others
