Question about Canon EF-S 18-55mm f/3.5-5.6 USN Lens
Canon lens will not auto focus.
We have a Canon EOS Rebel & the Canon EFS 18-55mm that originally came with the camera. We have been using the camera with no problem for about 3 yrs when one day the Auto focus stopped working. . Additionally, the auto focus does work with our telephoto lens.
SOURCE: Auto Focus not working for Canon EFS 18-55mm lens
I see this same problem occuring all over the internet on Canon lenses. Autofocus not working any longer. For some stupid reason the lense will lock up and quit autofocus while other lenses will work fine. A light pull on the lense focus ring away from the camera body will give a noticable pop or click which unlocks the jammed lense. Try it if you are having troubles with your autofocus. This is a very common problem and worth giving it a try.
Posted on Dec 20, 2010
SOURCE: Canon Rebel focus
I would only suggest you might clean the metal contacts on the inside rim of the lens....just be very careful what you use....a pencil eraser is good but make sure you clean away any shavings that might get into the camera...
Posted on Dec 14, 2007
SOURCE: Camera won't shoot with lens on Auto Focus
Talked to canon support, they suggested to send lense in for review/repair. They said it could be the motor, I think it was a gear problem based on the noises and jerkiness of the focusing action while in manual focus (manual focus gave out as well). Cost TBD - "would definately be more than $50. I shopped around and elected to buy a new lense rather than try to hassle with the repair, shipping, insurance, and the wait, etc. Besides, I have a deadline that I need the lense for, so repair at Canon really became a non-option. I think the cost would've been pretty much the same in the end as the new lense, since this wasn't one of the costlier of lenses to begin with.
Posted on Mar 20, 2008
empeethree
SOURCE: Auto focus suddenly stopped working
This may not be the same as your issue, but our AF stopped working as well. I tried all the recommended fixes - removing the card and battery, recharging the latter, removing the lens and cleaning the contacts, etc. None of those things worked. However, I then switched to MF, requiring me to turn the barrel, and I realized it was stuck and just needed a little force to get unstuck. Might have been the humidity. Anyway, our problem was solved - AF was back to normal after that.
Posted on Aug 24, 2009
  • 30 Answers
SOURCE: my canon eos rebel xt 350d wont focus
change your manual settings
Posted on Oct 11, 2009
Quantaray lens
You did not mention which lens. Some Canon digital cameras will only take EFS lens, others take both EF and EFS. Also there are other types of lens mounts made by Canon.
Cordially,
Jan 01, 2014 | Canon EOS Rebel XS 35mm SLR Camera
Canon Rebel EOS Rebel Ti1 will not auto focus
The lens needs servicing, because the lens is stiff the auto focus motor cannot turn the lens to focus.
Mar 24, 2012 | Canon Digital Rebel EOS 450D EOS Rebel XSi...
New Canon EFS 18-135mm IS lens failed to auto focus on EOS Rebel XTI and shutter won't release to take photo. Lens over a few months has worked without a problem. What is the problem?
Make sure both the lens and the camera are switched to af (auto focus). If that doesn't work remove the lens and replace it to make sure it is mounted properly. You can also check the camera with a different lens to make sure it isn't a problem with the settings on the camera. If all of that fails take it to a camera or electronics store that does service work to make sure it hasn't been damaged.
Jul 30, 2011 | Canon Cameras
Hello, We have a Canon EOS Rebel xti & the Canon EFS 18-55mm that originally came with the camera. We have been using the camera with no problem for about 2 yrs when one day the Auto focus stopped...
I've seen that before and in my experience it's usually due to the autofocus motor going. Your best bet would be to contact the Canon Imaging in your country and see what they suggest you do.
May 05, 2011 | Canon EF-S 18-55mm f/3.5-5.6 USN Lens
Canon EFS Lens question- please help!!
Make sure that the switch on the lens is set to AF. If that doesn't work, you may have a faulty lens. The EFS 18-55 is not a high quality lens.
Mar 10, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Tamron lens for Xti?
if it is an auto focus lens that works on one eos camera, it should work on almost all of them. the only known exception is that some high end extenders will not fit the eos1dmarkII as it protrudes into the opening too far.
but a good rule is that if it fits without any obstruction issues, it should work. try cleaning contacts on the lens and camera body. if that doesn't fix it, talk to Tamron. you can use it manually, but will not be as easy and you would get less predictable results.
my suggestion is to always go with lens from camera maker.
sounds like there is an issue with the tamron lens. not the camera.
good luck
mark
Dec 16, 2007 | Canon EOS 400D / Rebel XTi Digital Camera...
Canon 350d problem
The only thing I could think of is theat the contqacts on the camera body are out of alignment or damaged through putting the alternative lens on. I ant see the camera so cannot say for sure You must eyeball it your self to see or get onto Canon It will cost of course -lots
Sep 13, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Canon EF-S 18-55mm f/3.5-5.6 USN Lens Logo
1,320 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
