I have a zerox 8500 printer that displays an error 09,038.46:6744. What would cause this?
  • John Bishop Jun 16, 2009
    I tried to do this but it didn't go to the service diagnostics screen. I waited to hold the back and the ok buttons until the ZEROX started moving from right to left and pressed the two buttons down until the ZEROX stopped. It then went through a bunch of clicking and buzzing but only told me I still had the same fault code.
  • 23 Answers
First of all the error indicates that you have an ink stick fault most likely a cracked ink stick.
You need to enter diagnostics and clear ISC faults.
To enter diagnostics power off device.
power on device before the XEROX get to the middle of screen hold the back and ok buttons down until service diagnostics screen.
when diagnostics appears scroll to check functions and clear ISC Faults.
Posted on Jun 16, 2009
EPSON DFX 8500 ERROR CODE E5 THEN POWERS OFF
HI, you got a mechanical error on your printer this is because it got a paper jam problem and that may result that your printhead slams. Try to look if there's something in your printer that preventing the gear inside to move. If so re install again the driver software of your printer.
Feb 18, 2008 | Epson DFX-8500 Matrix Printer
I have a new hp officeet pr 8500 printer but on start up the screen displays error code 0060 and then goes blank. how to fix?
This error means there's an ink leak in your printer. HP recommends that you turn the printer off (using the power switch at the back of the printer), wait 20 minutes and turn the printer on (condensation may be causing error and the printer needs time to dry).
Mar 12, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
My HP 6500 709N all in one printer displays "paper jam" error message. Have searched thru printer - no jam, no little bits of paper. Have been thru the trouble shooting process - doesn't help and...
HP Officejet Pro 8500 (A909a) All-in-One Printer This model has a two-line display.
  1. Unplug the power cord from the HP All-in-One.
  2. Wait for 20 seconds.
  3. Press and hold # and 3 while plugging in the power cord to the HP All-in-One.
  4. Release the buttons after the HP All-in-One starts up.
HP Officejet Pro 8500 Premier (A909n) and 8500 Wireless (A909g) All-in-One Printers These models have a touch-screen display.
  1. Touch the Setup icon.
  2. Scroll to and touch Tools .
  3. Scroll to and touch Restore Factory Defaults . A Defaults Restored message displays.
  4. Press the Cancel button to return to the main menu.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jan 27, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
I have a problem with my HP 8500 where it is always jamming or indicating there's a paper jam when there isn't one. The rollers are very noisy. It has been a problem from the first, but is now impossible...
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Jan 03, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
Hi i have phaser 8560, it gives me a error 09,038,46:62248, plese who can solve me the problem.
Hi there
The onlty thing I can find close to this is.
Acording to the manual its a ink loader error like your loading the wrong type of ink like the puzzles pieces arent matching and hitting the sensor flags right. Yours by the 8 is referring to the black ink. Anyway go to troubleshooting on the control panel. then to service tools. when in service tools press and hold the up arrow while still pressing the up arrow press the down arrow. the display should say hidden menus. go to diagnostic mode press enter go to funtion menu. then go to clear ISC fault and enter. ISC=ink stick count fault. I hope that helps. Just to let you know Ive had nothing but problems with third party ink and once its in the system its hard to get out so I would watch what im doing with my expensive equipment
Feb 18, 2010 | Xerox Phaser 8500/DN Printer
Can i print B&W copies on the color zerox 8500 phaser?
Most likely the IP address has reset. If you have your configuration go into network setup, then re enter your IP address, and turn DCHP off, make the IP address static,
Feb 16, 2010 | Xerox Phaser 8500/DN Printer
Error code 09,038,46:21303
When you service a Phaser 8500 or 8550 printer for:
· a persistent Ink Out message
· 9,035.43 Cyan Ink Stick Count Fault
· 9,036.44 Magenta Ink Stick Count Fault
· 9,037.45 Yellow Ink Stick Count Fault
· 9,038.46 Black Ink Stick Count Fault
Test the Ink Out Sensors for proper operation.
Inspect the Ink Sticks.
Apr 09, 2008 | Xerox Phaser 8500/DN Printer
Zerox 7750
Most likely the toner hopper, is bad. The auger broke or something along that ling
Oct 20, 2007 | Xerox Phaser 8500/DN Printer
94 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
