Question about Ovens
I have a Samet built-in oven (linea italiana #DG941ET) and I want to know what its temperature gauges mean. They range from 1 to 7. Thank you.
Samet Double oven - Small oven on top. Glass door just shattered whle cooking. Can i Buy a new door or have the glass replaced in South Africa.
Posted on Dec 25, 2009
My Samet Linea Italiana oven's grill does not work. How do I fix it? Or is there a Samet repairer in Johannesburg that can help?
Posted on Jan 26, 2010
I have an Linea italiana samat 6950i stove , the thermastat is no longer working and we are unable to get spares from South Africa, who can I contact to help me repair my stove ?
Posted on Aug 04, 2009
Samet model 611 stove wiring diagram
Request the diagram directly from Samet.
Aug 08, 2016 | Stoves Ovens
My built in oven AKZ 110 is showing F 03 and nothing happens when I try to tune it in to work just stays on F 03 no fan no light either
This should help any further assistance please feel free to contact me.
WHIRLPOOL
Range/Stove/Oven Fault Codes Non Y-Line
NOTE: Not valid for Y line. If there is a Y near the end of your model number, do not use this chart.
Failure
Code
Condition Check/Repair 4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock (ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock (ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock (ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3 Open oven temperature sensor or thermal fuse Replace oven temperature sensor or thermal fuse F4 Shorted oven temperature sensor Replace oven temperature sensor F6 Problem in time keeping circuit 1. Reset time and/or cooking operation
2. Check for proper ground F7 Stuck function switch or button on Electronic Range Control (ERC) Replace ERC (Electronic Range Control/Clock) F8 Failure Electronic Range Control (ERC) Replace ERC (Electronic Range Control/Clock) F9 Door lock circuit Check wiring and test operation of door lock switch bkg-faultcodedivider.jpg txt-gototop.jpg WHIRLPOOL
Range/Stove Oven Fault Codes, Common
Failure
Code
Condition Check/Repair Digit Failure Code2 F1 Analog to Digital Failure Disconnect for 30 seconds - if display reappears - replace control board F1 Safety flip flop Replace board F1 Shorted keypad Replace keypad F3 Oven temperature sensor opened Replace oven temperature sensor F2 Oven temperature sensor shorted Replace oven temperature sensor F3 Oven too hot Replace oven temperature sensor F3 Clean temp too hot Replace oven temperature sensor F5 Check door/latch switch Replace switch if defective 4 Digit Failure Code F1 - E1 Safety flip flop Replace board F2 - E0 Shorted keypad Replace keypad F3 - E0 Oven temperature sensor opened Replace oven temperature sensor F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace switch if defective
Jul 16, 2011 | Whirlpool Ovens
I own a Kenmore elite Model 790.4660 electric range. When I attempt to use the oven there is a beeping message "F30ERR" Thank you. Mark
Thank you for question. I understand your concern with your Frigidaire range. Without knowing the model number I can't be 100 percent certain but F30 generally implies an open oven temperature sensor probe. The oven temperature sensor probe is located inside the oven cavity in the rear upper left or rear upper right hand corner. It can generally be removed and disconnected from inside the oven cavity.
Check the wiring harness connections between the control board and the oven temperature sensor probe connector. Check the resistance or the sensor at room temperature with an Ohm meter, if less than 996 ohms, replace probe. Check with meter, for shorted probe harness between control & probe connector.
. I recommend calling a service technician to diagnose and repair your range.
If you do not feel confident repairing this problem yourself, then you can have it repaired at your home by a Sears technician. Here is a link for the website:Sears Home Services
Dec 29, 2010 | Kenmore Ovens
What does f2 mean on the oven
Hi mil4kids,
F2 means the oven temperature is too hot. The easiest way to correct this error is to check the sensor harness and harness connection between oven sensor and oven control. If you noticed that the wiring is all ok, replace the oven temperature sensor (RTD).
Hope it helps.
Thank you for using FixYa.
Dec 20, 2010 | Maytag 24" Built-In Single Gas Wall Oven -...
Whirlpool Gas Range SF357PEKQ0 -- over heats; will not shut off; have to turn off at gas line behind stove. Error Code: F3E2. Is the replacement part I need the thermostat sensor? Is this part easy enough...
Hi lkanderson97,
This error code F3:E2 means that Oven temperature is too high (Cook mode). The only way to resolve this issue is to replace Oven temperature sensor (RTD). This part can be replaced by your husband. You may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central. Just get your model number ready when you call. Once you got the part instruction is also provided on how you'll replace the sensor.
Hope this helps.
Nov 22, 2010 | Whirlpool GBS277PDS Electric Single Oven
Oven beeps and display read "F3". what does this mean?
Hi dpaulthomas,
The F3 fault code description is a shorted or open oven temperature sensor. The easiest way to resolve this error is to check the sensor harness and harness connection between oven sensor and oven control. If you noticed that the wiring is all ok, replace the oven temperature sensor (RTD).
Hope it helps.
Aug 31, 2010 | Maytag 24" Built-In Single Gas Wall Oven -...
I'm getting fault code f2 reading, do I need to replace the oven temperature sensor or relay board? what part number is this and where is it.
Hi
Thanks for using FixYa. Error F2 in your range/oven means oven temperature sensor circuit failure. To resolve this issue you’ll have to check the oven temp. sensor circuit if the reading is more then 1100ohms then it should be replaced however, if the rating is fine then it is the Electronic Range Control (ERC) that has gone bad & should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 22, 2010 | Maytag 24" Built-In Single Gas Wall Oven -...
Double oven is having an alarm sound and showing F7, what does that mean??
hello,
what this means is any indication of code error indicates that the water temperature sensor reading is out of range (below 23 degrees F or above 217 degrees F)
There is a chance that there is a loose wire connection on the water temperature
thank you and thanks for using fixya.
Jun 07, 2010 | Ovens
Self-clean turns off after 5 minutes with F2 error message
Hi MaryB,
F2 error code means that the oven temperature is too hot. You will have to replace relay board if faulty. Check and replace oven temperature sensor (RTD). If failure repeats, replace ERC (electronic range control or clock).For replacement part you may contact Sears at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central.
Hope this helps.
Apr 15, 2009 | Thermador C272 Electric Double Oven
Ovens Logo
2,025 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
