Garden Logo
Posted on Jun 16, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Poulan Pro pole saw model sm446e. For
I have a Poulan Pro pole saw model sm446e. For some reason I can't install the pole sectioin to the motor unit.
Anonymous
Level 3:
President:
  • Master 2,220 Answers
  • Posted on Sep 23, 2009
Anonymous
Master
Level 3:
President:
Answers
2220
Questions
Helped
1383498
Points
7625
Without seeing the saw and pole we cannot answer your question.
Poulan Pro pole saw pp258tpc. Where can I get a manual?
My first thought is to look in the yellow pages under saws to find a Poulan dealer. I you are internet savvy try Google.
Aug 08, 2015 • Garden
Why pole saw wont saw?
There could be a couple of reasons why your saw won't cut.
The first thing I would check is to make sure you have your chain facing the right way.
The chisel edges should be facing forward, or in the direction the saw chain is rotating.
If this is not the problem, then I suspect the chain itself is dull.
Poulan Pro PP258TP fuel mixture
The manual calls for 40:1 but with the new "FD" rated oils it can operate on 50:1 ratio. I recommend using the pre-packed fuels. They have the "FD" rated oil and 93 -95 octane non-ethanol fuel.
I NEED HELP WITH FUEL LINE ROUTING FOR POULAN 445 PRO.
I HAVE A POULAN PRO 445 POLE SAW AND NEED AN FUEL FILTER AND HOSES . IS THERE ANY WAY I CAN SEE PARTS # FOR THESE ITEMS AND ALSO A PIC OF PUTTING IT TOGETHER ? Thanks , Omar
2helpful
I had to replace all my gas line on my Poulan 446t i need someone that knows how they hookup
Typical fuel system and a couple of tips. Leave the carburetor connections a little long so they can be swapped if need be. I think the upper most connection goes to the bleeder.
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
I think this is an IPL for your pole saw: (there are others, this may not be your saw):
http://www.ordertree.com/modelinfo/PWE/PP446T-Gas-Pole-Pruner/75.PP446T-Gas-Pole-Pruner.1.59.1.html
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best; components are listed but may be on different illustrations.
All Models:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type (true for chainsaw, my first pole saw. If uncertain try to contact them please.). HTH
Lou
Please reply back (below) with the final configuration. Help me provide better guidance to the next guy please.
34helpful
4answers
I need info on a Poulan Pro 445 fuel line routing
I'm so confused. This is reported as a Poulan and McCulloch pole saw, which one? Is it a pole saw? That is the only 445 Poulan I can find. It is reported as an electric but has a fuel routing problem.
If it is a Poulan Pro gas pole saw it is here: PP445 Gas Pole Pruner
The fuel system routing is terrible, but it is all there is.
Fuel Routing follows:
Tank to carburetor (hose in tank with filter on free end)
Carburetor to primer (primer draws fuel from the tank through the carb)
Primer to fuel tank (returns any excess fuel to tank when pushed) HTH
Lou
38 cc Poulan Chain Saw
Since You weren't Model Specific...I assumed you meant a Poulan Pro 38cc, here's a Contact Site for OEM Manuals:
http://www.poulan.com/poulanpro/manualSearchResultsAJAX.do
Top Poulan Garden Experts
Jay Finke
Jay Finke
Thomas Perkins
Thomas Perkins
Sean Wright
Sean Wright
Are you a Poulan Garden Expert? Answer questions, earn points and help others
