I can hear the radio even while playing a cd
SOURCE: Yamaha RX-v661 7.1 Receiver
Could be overloading your circuit and the receiver goes into safe mode to protect itself
SOURCE: Yamaha RX-V663 - HDMI doesn't work.
Hi and welcome to FixYa,
Initially, a workaround:
Even if it were a compatibility issue or HDMI processor issue on the receiver, the above should get you going.
Good luck and Thank you for using FixYa. Happy Holidays.
SOURCE: Yamaha RX-V995 receiver turns on & then powers off 2 seconds late
I suggest you run self diag. press [FM/AM] key + [Input mode] key and press the [power/standby] switch.
ps prt = power supply problem
dc prt = shorted output or leakly cap in channel
tmp prt means to hot on heatsink
you'll likely have to measure the resistances of the output FETs to find a short,
SOURCE: Yamaha RX-V463 Receiver Speaker Setup
That receiver has A and B channels. Look for the Speaker button and press it until B appears on the diplay. The other room speakers will play the same thing as in the main room.
SOURCE: Yamaha RX-v565 Radio & iPod
The most likely reason is that the audio settings on the receiver are set for digital audio and the connection for the iPod is analog. However, It's very difficult to determine anything without knowing how it is all setup. Please can you answer the following questions so that I know where to start looking.
1. How is the iPod dock connected to the receiver?
2. Is the Blu-ray player connected through the receiver to the TV (with HDMI?) or is the Blu-ray connected directly to the TV for video?
3. Is the audio for the Blu-ray sent direct to the receiver or via the TV?
4. Are "DIRECT" or "STRAIGHT" switched on?
5. When you select the input for the iPod on the receiver, what icons/words are illuminated on the receiver display?
Ideally, any information you can give me on how all of your devices are inter-connected would assist me greatly in solving your problem. I'm sure it's just a setup/settings issue rather than a fault with any of the devices.
Sorry for all of the questions, but it's very difficult to know what the problem might be without knowing how it's setup. Please reply to me with the details by clicking on "Add a Comment" below your question and I will get back to you without delay.
Regards,
BElectric
