Question about Epson Stylus R265 InkJet Photo Printer
Printing Black and White pictures
I use an Apple Mac and when I print pictures in Black and White. they have a blue effect over the picture. I think I have tried all the settings to no avail. Is there any answer to this?
    Problem Solver:
  • 7 Answers
Re: Printing Black and White pictures
i supose that you use compatible inks with your printer..
the problem is that the copatible inks are not good enough
you can also try to use another paper-diferent papers give diferent colours or you select another type of paper on the main printer software
Posted on Dec 05, 2007
0 characters
3 Points
Bizhub c200 printing with streaks of red and blue lines what to do
If that lines are consistent with the red and blue and it does not appear during black and white print that means the cleaning blade in the affected color units need to be replaced
May 16, 2014 | Konica Minolta bizhub 250 All-In-One Laser...
The printer is printing the pictures nicely , but not the text
Black cartridge bad or not working. Try printing in black & white or grayscale, if it doesn't print at all then I'm correct in my assumption.
Jun 03, 2012 | Printers & Copiers
How can i make my pictures lighter. they are too dark
look at control panel printer properties of the printer ur printing to. See if there is a setting for
"picture quality" you may be able to adjust from there. If not depends on the picture editing software that ur using most all have "contrast" "brightness" slide bars that will alter picture viewing and printing
Feb 15, 2011 | Printers & Copiers
Fixing Error 20 on Cannon PIXMA MX870
lease try the steps below and let me know........
1.Step 1
Double click Kodak EasyShare on your desktop to launch your program. If necessary, use the download link in the resource center to setup and install the program first. After launching your program, click "My Collection" to see your albums. Choose an album on the left side and click it to view its pictures. Click the "Slideshow" button to view all the pictures as a slideshow.
2.Step 2
Click the add pictures button to insert new pictures into EasyShare. Select the location of your pictures. When the new folder opens, select the pictures that you want to upload. Click the "Entire Folder" button to select all pictures. To select individual pictures, press and hold the "Ctrl" button, then click each individual picture. When finished, click "Done."
3.Step 3
Click on a picture to highlight it and then click the "Edit" button to change the brightness, contrast and size as desired.
4.Step 4
Click on a particular picture, then click the "Edit" button at the top of the interface to toggle through different effects. Click the "Scene" effects button to select from a black and white look, a sepia tone, a sunset tone or a forest look. Once you have selected your effect, click the "Accept" button to make changes to your picture.
5.Step 5
Click the "Fun" effects button and then choose from spotlight effect or coloring book effect. Choose the fish eye effect to give your pictures a fish lens look. Select cartoon effect to give your pictures an abstract look. When you have chosen your effect, click the "Accept" button to make changes to your picture.
6.Step 6
Drag your pictures to the picture tray on the right side of the screen to email your pictures. Next, click the "Email" button on the left. When the new email window opens, insert your recipient's email address, type in a subject and a short message. Click the "Send Invitation" button.
7.Step 7
Click the "Print at Home" tool on the left side. Select your paper size, print size and printer. Make sure your printer is turned on and connected to your computer. Click the print button to begin printing your pictures.
8.Step 8
Click the "Order Prints Online" tool and follow the guidelines to select print order options or different printing formats such as on mugs, t-shirts and calenders
Aug 10, 2010 | Canon Printers & Copiers
Cannot get black and white pictures
When you want to print a document, go to Printer Preferences and check the "Grayscale printing" checkbox. Then, it will print also black and white images.
Feb 15, 2010 | Canon Printers & Copiers
HP C4480 Won't Print Borderless
Most pix you shoot are not exactly 4x6 which will leave white edges top and bottom- Sides Try using the HP software- see if any difference Inkypete
Apr 22, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
Printing black and white photos from digitally taken colour photos
Hi Pat,
First you will have to check the Nozzle of your printer. To do this, press the setup button and select Nozzle Check. Use a plain paper to do this. Press Ok after that. It will print out a pattern for each color. Make sure that the lines are connected to each other specially for black since that you are printing a black and white photo. Lines going across is on a stair case pattern and should be connected to each other. Proceed with cleaning cycle if needed.
You can do a cleaning cycle using your printer of the computer. You can skip this if you have a good Nozzle check.
Using printer:
Press setup then select head cleaning.
Using computer.
Go to utility of the printer and find maintenance. Click on the head cleaning button.
Once that the nozzle are fine, you can now try printing. I strongly suggest that you use other application first instead of Adobe Photoshop. Since that Photoshop uses color management, it can be that the settings are incorrect. Save first the picture that you opened in Photoshop. You can save it on your desktop to easily locate the file. Make sure that the file is in jpeg format. Now to isolate the issue if it is cause by a software or not, try the standard application for your O.S.
Smaple Application:
Windows O.S. : Windows Picture and Fa Viewer
- right click on the file and select open with.
- select windows picture and fax viewer.
- folow the on screen instuctions.
Note: If you are now on the window on what pinter to use. Make sure that you set the option for printers under preferences to print in gray scale or black only. Select also the correct paper type.
- Proceed with printing.
Mac OSX: Preview or Iphoto
- open the picture under one of the application.
- click file then print.
- Make sure printer is selected.
- underneath the print option, you will have to go to print setting.
- find the option that says color then select black.
- select the appropriate settings for paper.
- the click on print.
Now see if it did print out corectly. If it did, it means that the appplication is the one causing this. If you are familiar with the color manage features of the application Photoshop. Let Photoshop handles the color. After getting to the widow what printer to use, to the the preferences of the printer and select the correct paper type. You will have to find the color management of the printer.
For Windows, It under the advance option under the main tab. Select off no color adjustment.
For Mac instead of going to print setting, find color manage and turn it off. Select off no color adjustment.
Then try printing.
Regarding your other question, If the printer is producing excess inks on your print out when ot comes to black printing and color printing, that pad needs replacement.
Aug 15, 2008 | Epson Stylus Photo RX700 All-In-One InkJet...
Switching between color and black and white
Go here. In the search box in the center of the screen, type "print with black ink only" and click Search. Choose the appropriate link, and you will get instructions for printing from either Windows or Mac.
Jul 03, 2008 | Canon MX300 Office All-In-One Printer
Problem while printing rectangular boxes
check your printing program. are you using a mac or apple program? like quark? check setup, maybe there's something like reverse printing option or transparent printing.
Sep 11, 2007 | HP DesignJet 500ps (42 in.) InkJet Printer
Epson Stylus R265 InkJet Photo Printer Logo
64 people viewed this question
Top Epson Printers & Copiers Experts
Are you an Epson Printer and Copier Expert? Answer questions, earn points and help others
