Question about HP LaserJet 1022 Printer
Hp laserjet 1022 installing for windows home vista 64bit, everytime I get the print spooler has stopped working and it, screws up and I cant resolve it, I don't know what else to do, I have contacted microsoft and hp and they can't resolve it, it is pretty ridiculous. It originally worked fine for the first 9 months and it just all of the sudden started this. I have an hp laserjet 1020 and it does the same thing. I can't clear the print que and usually I cant uninstall the printer from the control panel
    Sergeant:
  • HP Expert
  • 424 Answers
Driver download link: HP Laserjet 1022 Printer Driver
Posted on Jan 31, 2010
    Scholar:
  • 41 Answers
Open up your print queue. Cancel All jobs.
Go to the start menu and either click on, or search for cmd. This will open the command window. You also need to open your task manager.
In the task manager, search for a process called spoolsv.exe, or if that doesn't exist, find a process with "spool" in the name. This is your print spooling process. Right click the process, and end it. You can close the task manager now.
Next, go to the command prompt. Type "net start spooler" without the quotes, and hit enter. This should restart your spooling process. Close the command window, and try to print.
If this doesn't work, you should check to make sure you're printing to the correct printer If it doesnt solve the problem, uninstall your current printer (you may have to end the spoolsv.exe process again), and reinstall the drivers for your particular model, which you can find at the manufacturers website
Posted on Jun 23, 2009
    President:
  • 828 Answers
This one change your USB connector... a new one.,,,
Posted on Jun 16, 2009
My printer is telling me that its not conntcetd to my computer. When I try to reinstall it saying that the Prnter spooler is not responding. Help!!!
For you to print anything from windows you must the print spooler service running. You will find it under control panel, administrative tools, services. In the list under services you will fing the entry called print spooler. It will have stopped so click on start and exit the program. If it does not start then you have another problem with windows and that would need corrected first.
Hope the above works. Oh its the same for XP, Vista and Windows 7.
May 26, 2011 | HP LaserJet 1022 Printer
Tip
Spooler crash with Vista
When the spooler craps out under Vista, the easiest fix is to use the restore option in system tools and reload the previous configuation. I have this problem everytime I try to read a large PDF file in Outlook.
on Mar 08, 2009 | HP LaserJet 1022 Printer
My HP LaserJet 1022 is not responding even after I click print. It happens just now. Yesterday morning was fine. Keeps the document in pending and when I try to cancel or click print it says the print...
This seems to be a problem on these printers. I have five of them on my network and I had to use a generic driver to make them stop shutting off the print spooler on my print server. I use the LaserJet III driver which is a good HP generic driver. I found it to be best to uninstall all of the 1022 software and install the printer using the above driver that is part of the windows operation system therefore there is no need to download one.
Apr 10, 2010 | HP LaserJet 1022 Printer
I cannot print, the service spooler is not running
In run window type services.msc and the go to print spooler option just stop and restart the service.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Feb 22, 2010 | HP LaserJet 1022 Printer
I loaded Win 7. I need my printer to work badly. I have to print checks. I have a Laserjet 1022 Is there a driver or bata driver I can use.
Go to the HP website (www.hp.com) > click download drivers and firmware or support > type in HP laserjet 1022 > click the search arrows > click on you printer model > choose the operating system. If Windows 7 drivers aren't available yet the Windows Vista drivers should work just as well for the time being.
Oct 26, 2009 | HP LaserJet 1022 Printer
The printing spooler service is not running.
Go to the control panel. Select printers and right click on your printer. Select properties and turn print spooling on.
Aug 08, 2009 | HP Hewlett Packard LaserJet 1022 Printer
Lj 1012 or 1022 hangs the print spooler
Since you're mentioning policies, you've probably got a bit more background than most.
Check your update histories. You're looking for the same correction/time-factor with both XP/Vista.
Verify the driver version. Download the newest driver. Try it on one machine. Try the previous one.
Look at other printer drivers installed. Multifunction printers are the worst for conflicts and hogging resources.
May 14, 2009 | HP LaserJet 1010 Printer
HP print spooler problem and error 1068. Want my printer back!!!
Just go to your Server or Desktop PC and enable the RPC service (Remote Procedure Call)
Right click in "My computer" icon, from the manu select "Manage" then go to "Services and Applications" and expand that, after that select "Services" you will find that services in the right pane, just click in "Start"
May 08, 2009 | Sony Office Equipment & Supplies
Trying to install a print hp 1022 to my laptop which uses vista
Go www.hp.com and let the website auto-detect your printer and download the drivers automatically.
Jan 18, 2009 | HP LaserJet 1022 Printer
I hope this work for you, good luck!!!!
Jul 28, 2008 | HP LaserJet 1022 Printer
HP LaserJet 1022 Printer Logo
223 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
