Question about Frigidaire FRS26H5AS Side by Side Refrigerator
Frigidaire is freezing everything!
I have a frigidaire side by side that is about 5 1/2 years old. Model FRS26H5ASB8 that never keep the refrigerator side any to cold. I always had the temp turned all the way up to 6 now suddenly it started to freeze everything. I cleaned the coils and everything under the fridge. Even after turning the temp control all the way down it is still keeping the temperature in the frige below freezing. What do i need to d to fix it?
    Top Expert:
  • Frigidaire Master
  • 81,285 Answers
Possible defrost timer or thermostat failure.
Posted on Jul 11, 2017
HVACRH20
  • 237 Answers
SOURCE: Frigidaire FRT18HB5DW2 fridge not cooling
Sounds like an air flow problem to the lower unit. Take the sheetmetal or plastic rear cover off the freezer back wall and make sure the coils are frosted up good and even but NOT a block of ice inches thick (air needs to circulate and a blocked coil won't let air move over it efficiently). Make sure the fan is running to move the air around. In the fridge area make sure the air dampers are letting the cold air from the freezer down to the fridge compartment. Depending on what you find will determine the next steps so let us know.
Posted on Dec 27, 2006
josh1856
  • 105 Answers
SOURCE: Frigidaire Sid eby Side
sounds like a "performance problem" try pressing and holding the reset button for 3 seconds.
Posted on Jan 27, 2008
SOURCE: Frigidaire stand alone Refrigerator won't cool Fans and Compressor work
Ended up having a freon leak in tubing around door. Luckly the warranty was 5 years in sealed system. New one was FREE.
Posted on Feb 23, 2008
SOURCE: Frigidaire frs24zrh refrigerator not cool enough
Check out partselect.com. need to replace defrost timer and defrost thermostat. good luck.
Posted on Sep 26, 2008
aborcass
  • 2651 Answers
SOURCE: does outside temperature affect performance of freezer
Top mount refrigerator installed in a garage and the food in the freezer is defrosting when
the temperature in the garage goes below 55 degrees fahrenheit.
On top mount refrigerators you cycle the compressor and fan/fans from the food
compartment temperature. When the room temperature gets colder than 55 F, you have
long off times waiting for the food compartment to warm enough to trip the cold control.
This long off time is allowing the freezer temperature to get high enough that food can start
to defrost.
There is a kit for refrigerators installed in applications where the temperature can go as low
as 34 F and still maintain good freezer temperatures. The kit part number is 5303918301
and it contains a heater that mounts in the control box and an instruction sheet advising
how to install the heater.
Kit 5303918301 contains:
Part # 5303950194 Instruction sheet
Part # 241532101 Heater
Posted on Nov 21, 2008
Why doesn't my Frigidaire FRT21TNG freeze or cool fresh section?
Good Afternoon Friend,
I understand that your Frigidaire refrigerator, model# FRT21TNG, is not freezing or cooling. I also see that the coils are not freezing, the drain line and everything cleaned, and that the capacitor was replaced. From this point, I suggest contacting your local authorized technician. They will be able to diagnose your appliance and determine why it will not cool as it should. Hope this is helpful.
-Best Regards-
WP
Jun 20, 2014 | Frigidaire FRS3R5EMB Side by Side...
Won't stop running. This says I have to end with a ?
I understand that your Frigidaire refrigerator, model# FRC05L5DW1, is freezing the inside as well as running constantly. I suggest resetting your appliance, by either unplugging it or shutting the power off at the circuit breaker, for 3-5 minutes. When power is restored, if you are still having the same issues, I suggest contacting your local authorized technician. Hope this is helpful.
-Best Regards-
WP
May 17, 2014 | Frigidaire Refrigerators
Comperssor kicks on but quickly cuts off intermittently every 5 minutes on my frigidaire fridge side by side
Freezer defrosted everything fan continues to run but will not freeze. Compressor is cycling enough to keep refigerator section cold. 106 Series Kenmore. Turned up thermostat to keep fridge cold and a shorter intermittent compressor cycle run
Jun 06, 2009 | Frigidaire FRS26H5AS Side by Side...
Frigidaire freezer not freezing ice cream
The freezer temp settings are not low enough or you are getting ready to have a poblem with the defrost circuit.
May 05, 2009 | KitchenAid Superba Architect KSCS25INSS...
FRE196AS frigidaire fridge/freezer - fridge freezes everything!
Hello Nicola,
I suggest you contact Frigidaire in the UK, and explain the problem to them. I have included their website for you to do so. You can even call them. I checked with Frigidaire in the US and Customer Service tells me your fridge should not be failing at this point. Contact Customer Service and tell them how disappointed you are in the product; explain the issue; and insist they offer assistance to repair it. Frigidaire Customer Service here does not want to lose any customers, and that includes you. Be nice, but firm with them. I hope this helps you in some way. Let me know if I can further assist. Just trying to to help. :)
http://www.frigidaire.co.uk/contact.asp
Feb 17, 2009 | Frigidaire FRS26R4A Side by Side...
Top mounted freezer on refrigerator not working
Move the refrigerator to a room that is at least 50 degrees F.
Temps on most refrigerators are regulated by the fresh foods temp. If your garage is let's say 35 degrees, the fresh foods temp will most likely never raise enough to turn the refrigerator on. With the refrigerator never running, the freezer compartment will warm to 35 degrees, resulting in everything melting. Even if garage is a bit warmer, say 45, the refrig will not run long enough for the freezer to maintain a low enough temperture. If the garage temp falls to below freezing, say 20 degrees, the food in the fresh foods compartment will freeze. (outdoor beverage dispensers have internal heaters to prevent product from freezing !) Please don't rate this if not a Fix-Ya for you, as anything else lowers my score.
Jan 22, 2009 | Frigidaire 5 cu. ft. / 142 liter Chest...
My refridgerator keeps cycling on and off. temperature is50 degrees . where do i put r-134 in on high side at? thanks.
Hi katdaddy,
Welcome to fixya,
You said,
Your refrigerator keeps cycling on and off. temperature is50 degrees .
This means either you have a leak that must be detected befrore you re establish freon pressure or your thermostat is bad.
What is the model # and age of the refrigerator?
Sep 28, 2008 | Frigidaire Refrigerators
Freezer won't freeze
compressor may be the problem,by pass the thermostate connections & chelk cooling replace if working.some sort of leakage may also be the problem.
Mar 16, 2008 | Frigidaire FRS3R5EMB Side by Side...
Food stays frozen regardless of temperature setting
It is possible it has a bad thermostat but most likely cause would be a bad damper motor.  It is the vent inside the fridge that opens and closes, based on temp. setting, to allow cold air from the freezer into the fridge section.
Oct 14, 2007 | Frigidaire FRS26H5AS Side by Side...
Frigidaire FRS26H5AS Side by Side Refrigerator Logo
162 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
