Question about Acer Aspire 3680 Laptop
When i turn it on and then press enter it restarts
When i turn it on and then press enter it goes to loading and then it just goes to this blue screen and says something about error and restarts all over again. It doesn't even go to the log in screen or anything.
  • rukeih Jun 16, 2009
    Thanks for your help. But I think vista is broken or damaged because my sister just told me that when installing updates she clicked restart or cancel and then she shut it down, which I think messed up the whole system and now I have to restore it somehow. I'm trying to download a ISO image(using home PC)to a CD or a USB but I'm having a difficult time.
    Thanks tho.
That is the screen of death seems to be a problem with acers got one that has done the same and know of others,if it is over 3 years old you could try and fit a new drive or just dump it or sell it for spares.
If under 2 years old under euro law electronic equpment is covered for 2 years as it deemed it should last for that length of time without failing
Posted on Jun 16, 2009
    President:
  • 828 Answers
This problem goes to your hard drive.... it appears that the partition of your HD are not available or damage, reformat and put new system...
My computer is stuck on the blue hp menu screen, how do I fix it?
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key
this will vary depending on your computer and operating system
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
hope this helps
Sep 19, 2012 | Computers & Internet
My computer screen turns blue and restarts window vista
Hi jjlishus,
I see you mentioned that you are having issues with you computer going into a blue screen then it restarts.
You can try to boot into safe mode to see if Windows Vista will Load without having the bluescreen and if it will not shut down or restart, from Safe Mode, try and do a system restore to a data where the problem has not happened yet.
From there-on see if the issue will still happen or no
Getting into Safemode:
restart PC keep on tapping F8 on your Keyboard this will prompt you options, Look for Safemode then press enter this should bring up the safemode screen.
If during the loading of safemode and still happens are any error show up or it goes to a blue screen, you can try going into safemode with command prompt.
to get to safemode in command prompt just do the same as ging into safemode and select safemode in command prompt.
once in the command prompt
Type CHKDSK , then press enter it should check the system for 5 mins or so depending on your PC/Laptops speed.
if still the issue is the same reformatting or restoring your windows back to defaults may fix the issue.
I hope that this will help,
mvincentc
Jun 07, 2012 | Acer Brand 14.1 WXGA Matte Laptop...
Forgot username and password for IBM thinkpad x41
Back up your most important data to an external storage device in case anything goes wrong while changing the BIOS settings. Remove any disc that is currently inserted in the IBM Thinkpad X41's disc drive.
2-Shut off the Thinkpad X41 laptop. Turn the laptop back on and wait for the "To interrupt normal startup, press the blue Access IBM button" message to appear on the screen.
3-Tap the blue Access IBM button at the top of the keyboard. Click the "Access BIOS" button when the "Rescue and Recovery" menu appears.
4-Click "Yes" and wait for the BIOS to load. Type in the current BIOS password for the IBM X41 and press Enter.5-Navigate over to the IBM's "Security" heading by tapping the right arrow key twice. Scroll down to the "Supervisor Password" listing and press "F5."6-Type the IBM's current BIOS password and hit Enter. Leave the next field blank if you want to completely remove the BIOS password, or instead type in a new password to replace the old one. Press Enter.7-Press "Escape" and then highlight "Restart" and press F5. Navigate to "Save changes and Restart" and press Enter.
  • Nov 05, 2011 | IBM ThinkPad X41 Tablet PC
    It has a blue screen doesnot do anything
    Here are a few things you can do or try
    Restart the computer. If you are already in Windows, you can do this from the Windows Start menu, go to Turn off computer and click Restart. As the computer restarts, watch for a progress bar at the bottom of the screen. press F8 about once every second. Immediately press F8 before the progress bar reaches the right side of the screen. From the Windows Start-up menu, highlight Safe Mode and press Enter. Wait for your desktop to appear, and then make the necessary repairs (for example, uninstall programs or devices). When the repairs are done, restart the computer, and allow it to boot normally.
    Alternate:
    From the Windows Start menu, click Run. In the Open field, type MSCONFIG and click Ok. On the BOOT.INI tab, check /SAFEBOOT.
    Click Restart when prompted.
    Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer)
    or
    Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
    click start all programs accessories scroll to system tools from there you should see a system restore click next a sytem date should open up select the date you want to restore your computer to or if you want a full factory restore or
    Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer) or
    Hope this helps don't forget to vote
    Feb 23, 2011 | Computers & Internet
    Reset the BIOS on a Compaq server 740 jumpers settings
    Don,t do that insatead:
    Entering the BIOS Setup menu Entering the BIOS Setup menu requires pressing a specific key at a specific time. If you fail to enter the Setup menu on your first try, repeat the following steps until you are successful:
    1. Close all applications that are currently running and restart the computer by clicking Start , Shut Down , Restart the Computer , and then OK .
    2. When the red Compaq logo or blue HP logo screen appears, press the F10 key on the keyboard to enter the Setup menu.
    NOTE: An alternate to the above steps, especially if the logo screen disappears too quickly to enter BIOS, is to shut down (turn off) the computer. Wait 30 seconds, turn the power on and press F10 or F1 at the logo screen. Reloading the default settings Complete the following steps to reload the factory installed BIOS Setup settings:
    1. In the BIOS Setup utility, select the Exit tab.
    2. Select Load Setup Defaults .
    3. Select Save Changes and Exit (pressing F5 and the Enter key will also load the Setup Defaults).
    4. Press Esc and then Enter to exit Setup.
    Nov 13, 2010 | Computers & Internet
    On my laptop i have a problem with the blue screen. When I turn my laptop on it loads for a few seconds then it gives me the blue screen, what do i do?
    During the boot process you will see on the screen to press delete to enter setup
    Press and hold delete during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart then
    once you have your computer running try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f which will scan for and attempt to fix any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive then you might test all leads that are attached from your motherboard to your hard drive or just replace them there probably old and faulty
    hope this helps
    Oct 24, 2010 | Computers & Internet
    Hi, I'm having Dell Inspiron 1525 laptop and using operating system is Windows XP. From past one week it is restarting itself. While loading windows blue screen is coming and in fraction of seconds it is...
    Hi. All Dell Notebooks has this Image Restore in one of the partitions of the hard drive.
    You may restore factory settings of your computer but your files will be lost.
    Try to boot using safemode with networking first so you can save your files online.
    Turn your computer on and on the Dell logo, press Ctrl+F11 if system came with pre-loaded XP then follow the intructions.
    If system came with windows Vista, on Dell logo, press F8 and select Repair your computer and press Enter. Click Next and/or enter your password if asked. If not, follow the intructions until your system goes back to factory image.
    Hope it helps!
    ^_^
    Jun 07, 2010 | Computers & Internet
    When you first start your computer how do get it to read the disc first?
    You go into Boot Menu, and set the - first boot device to CDROM.
    The computer will then read what is in the optical drive, first.
    Computer off, press the Power On button. Watch closely for the blue dell logo.
    Looking at the bottom of the monitor screen when the blue Dell logo comes up, you will see - F2 = Setup.
    At the top right of the screen you will see F12 = Boot Menu.
    This screen goes by F-A-S-T!
    As SOON as you see the blue Dell logo press the F12 key.
    If you miss this small window of opportunity, just wait for Windows to fully load, then click on Start, Turn Off Computer, and Restart.
    If Windows is not loading, then press the CTRL, ALT, and DELete keys at the SAME TIME. (Not shouting)
    This will restart your computer so you can try again.
    Upon entering Boot Menu you cannot use your mouse anymore, you have to use the keyboard.
    The Boot Device Menu has the devices listed, and each device has a number next to it.
    At the bottom of the menu, type the number that is next to CDROM, then press the Enter key.
    This is Dell Support, and the main page for the Dell Dimension 4700 Service Manual,
    http://support.dell.com/support/edocs/systems/dim4700/sm/index.htm
    Left-click on - Entering System Setup
    Should you have any questions concerning this, simply state so in a Comment.
    May 03, 2010 | Dell Dimension 4700 PC Desktop
    Uploading windows vista upgrades command was to restart system for changes to take effect. On restart screen went blue and showed Tech info *** STOP: 0x0000C1F5 (0x00000000, 0x00000000, 0x000000000,...
    Press F8 continuously while starting the computer. When black screen appears eventually (right before Windows loads), choose Last Known Good Configuration.
    Aug 06, 2009 | HP Computers & Internet
    Restarts before windows loads up.
    hey hey chill...simple my friend just have your windows service pack with you inhand.Turn your Laptop on immidiately when your CD-ROM/DVD-ROM starts flashing its light, open it then insert your service pack disc (its the CD/DVD you receive when purchacing the laptop) then let it restart again...then again when it starts press F8 repeatedly until you enter a some menu then re-install the Windows Xp again from the disc and walla your Pc will be fresh again...
    Feb 24, 2008 | Fujitsu Siemens Lifebook T4010 Tablet PC
    Acer Aspire 3680 Laptop Logo
    75 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
