Question about Refrigerators
Water coming from new refrigerator water dispenser is not cold
Installed new refrigerator Saturday. Icemaker works fine, but water coming out of the water dispenser is warm. Will get colder when I run it for a while, but will not stay cold
  • 4 Answers
CHECK TO SEE IF THE DRAIN LINE IS CONNECTED TO THE PAN BEHIND THE KICK PLATE. I would offer a diagram but I'm in search for one myself.
Posted on Jun 16, 2009
Icemaker will not make, cold water works fine, have changed inside filter nd outside filter I added before I knew there was one inside
Refrigerators with both ice and water dispensers have a dual port electric water inlet valve. This inlet valve is the plastic part usually on the back of the refrigerator where the house water supply connects to. This dual valve has 2 electric coils that open to let water in depending on if you want water to a glass or if the icemaker needs to fill with water. Your problem seems to be the half that fills the icemaker may be bad. The valve comes as 1 complete part for both water and ice.
May 09, 2015 | Refrigerators
Water dispenser drips. filteris installed and icemaker works fine.
Ice water and ice maker, work on 2 different water valves...water dispenser valve is failing or clogged
Dec 18, 2010 | Kenmore 64802 Top Freezer Refrigerator
My refrigerator water dispenser is not working. I
In the back of the refrigerator there is a water inlet valve. It will have three hoses one coming in, two going out. A 1/4 line for the icemaker and a 5/16" for the water dispenser. If your icemaker is working and you dont have water at the door the valve to the water dispenser is faulty, you need to replace the water inlet valve. If neither icemaker or water dispenser is working chek your water supply line
Feb 22, 2010 | Refrigerators
Icemaker works; water dispenser not
You can get to it, it is just a matter of figuring which valve has gone bad. You may need to disconnect different lines and actuate the water dispenser to see if water comes out of the valve. You gain access to the valves from behind the machine by removing the access panel that is at the bottom
Jun 16, 2009 | Amana SXD524VW Side by Side Refrigerator
Water not going into icemaker. Water dispenser works fine.
Check the water valve at the back of the fridge if present.
Even if you used blowdryer, ensure that linse are not frozen by performing a complete defrost.
Disconnect water lines from icemaker, and blow with compressor if the above did not work.
May 20, 2009 | Kenmore Refrigerators
Testing IM-6 Water inlet valve
check water valve or icemaker
Apr 06, 2009 | GE Refrigerators
Water dispenser doesn't work but icemaker works fine
TAKE A HAIR DRIER AND HEAT UP THE RESEVOUR INSIDE OF THE REFFRIGERATOR BY THE OUTLET UNTIL THE WATER STARTS TO FLOW. GOOD LUCK
Jan 11, 2009 | Maytag MFI2568AE Side by Side French Door...
Ice machine not making ice
Hi, everak11,
Three possible solutions for you.
1: No water coming in from inlet valve. Check voltage on inlet if you have voltage and no water then replace valve.
2:Icemaker not cycleing. Lift the arm on the icemaker to shut it off and leave it for about an hour. Come back in and turn the icemake back on by lowering the arm. If the icemaker does not begin a new cycle and the arm start rising then the problem is most likely an icemaker. Replace Icemaker
3:Refrigerator not cold enough. If the freezer is not getting cold enough the icemaker will not cycle. Check the temperature in the freezer and make sure it is getting down to 0 degrees. If not then you may have another problem with your refrigerator. I hope this helps you, Let me know if you have any other questions or symptoms. Mike
May 08, 2008 | Refrigerators
New Kenmore Elite ice dispenser not working but water is
Should be no longer than 24hrs. Is the freezer good and cold.. has to reach a certain temp before icemaker activates. Might take little longer if you put a lot of warm things in freezer or refrig. when you made the change. Is there any water or ice in the icemaker itself? Water may not be getting to icemaker call them back out if it dont work soon thats what warrantys for :0)
Sep 02, 2007 | Whirlpool ED2FHEXN Side by Side...
Refrigerators Logo
825 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
