Question about HP Deskjet F340 All-In-One Printer
HP F340 driver installation
I have downloaded the print driver from hp.com. I tried to install it and it starts out OK but then it starts going slower and slower and eventually it hangs. I have tried with the CD that came witht he printer witht he same results. I am never prompted to connect the printer along the way. I tried this on another system I have and it installed in a couple of minutes.
  • 157 Answers
There is a dialog box behind the installation one asking whether you want to install the non signed driver, try moving the install window out of the way and you should see the other dialog box. otherwise when it hangs you can press ctrl alt del and go to task manager and find a process called wrapper.exe and end ig.
Posted on Jun 16, 2009
Photosmart for 300 series
Depending on what operating system your running. You need to make sure your product is plugged in through a usb connection. Now if your computer doesn't find the product that's ok you just need it to be plugged in. then you need to download the proper drivers for it. For instance if your running windows 7 64 bit, you need to download the drivers making sure you have 7 64bit drivers. In this case you want to install the firmware update make sure you see a yellow smiley face after the firmware is installed to your F340 HP Deskjet F340 All in One Printer Drivers
Apr 27, 2012 | HP Computers & Internet
My printer scans, copy but won't print from computer?
Did you set this printer as the default printer? To do this go to Start - Printer and Faxes, right click on HP printer, select Set As Default Printer. If you are not see your HP Deskject F340 there, that mean your printer driver is not installed. Please install your printer driver.
If you already set it as the default and it is still not printing. Restart your computer to try solve problem.
You said that printer scans so the connection between your computer and printer is fine. Problem is your computer doesn't take the printer as it's printer device yet.
Hope this will help. Thanks for reading
Jul 19, 2011 | HP Deskjet F340 All-In-One Printer
After getting Windows 7 I can't use the scanner button on my F340 aqll in one and I can't figureout the scanner feature on Windows 7
It sounds like you installed the generic OS driver from Windows 7. This driver only works for the printer. (Alternatively, you do not have the monitor program running or the destinations set in the HP software.)
If you plugged in the data cable before installing the HP software, uninstall the printer (Devices and Printers) then disconnect the data cable (USB). Go to http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&product=1128309& and select your Win7 version (32- or 64-bit). Then click Next. Expand the section marked driver and download the Full Software. Install the software. Connect the data cable when prompted to do so. (Try a new USB cable since scanning requires bi-directional communication with the printer and can fail when the printer works). Avoid using a USB hub or print server.
If you do have the HP software installed, check that the monitor program is running (Start > Control Panel > System and Security > Adminstrative Tools > Component Services > Services.) The line for the HP monitor should say started. You may need to download and install the patches or the diagnostic utility from the above site to find a specific problem with the Win7 installation.
Next launch the HP software and attempt to scan from the computer. Next use the settings that give good results to program the defaults for the scan destination buttons. Now try to use the scan buttons on the all-in-one.
Once you have the HP drivers for both the printer and the scanner installed, the Windows 7 Fax and Scan and Paint programs should let you successfully scan from the computer. (New scan for fax and scan. File > Import from Camera or Scanner > New Scan for Paint.)
I hope this helps.
Apr 24, 2011 | HP Deskjet F340 All-In-One Printer
HP Deskjet F340 Printing, but not scanning. I have a MAC.
go to your mac hard drive on your desktop go to applications if you installed the drivers correctly you should have a hp folder if not I suggest installing the drivers for your os check your os version by clicking on the apple icon top left and go to about this mac, In the hp folder you looking for scan pro and you can use that for scanning
Jan 26, 2010 | HP Office Equipment & Supplies
I have a F340-all-in-one. Will not scan
i would suggest to download the software from hp.com
for this printer.. and then try to install..
note : download the full feature software only..
Oct 22, 2009 | HP Deskjet F340 All-In-One Printer
Lost disk for install
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=1128309&lc=en&cc=us&dlc=en&lang=en&cc=us&submit=Go%20%BB
Go there and Select your Operating system. The HP site should supply the drivers you need.
Jun 20, 2009 | HP Deskjet F340 All-In-One InkJet Printer
F340 issue
You need to uninstall any printer software you have installed. Reboot your computer and go to this site to download the Vista software.
F340 Vista Downloads
You can get the full feature software and driver or order a CD.
Nov 08, 2008 | HP Deskjet F340 All-In-One Printer
My hp all-in-one wont scan
First unplug the scanner and install the printer drivers from the hp website. If you all ready have the drivers installed reinstall them. Then go to the printers scan software and try it. If that fail go to start bar-control panel- cameras and scanners and set the printer up. If all else fails call hp directly and they will fix the problem.
Oct 11, 2008 | HP Deskjet F340 All-In-One Printer
Cannot scan with hp f340
here is a link to the scanner install walk-through... HP Deskjet F340... http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01585107&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=1128309&lang=en
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Jul 24, 2008 | HP Deskjet F340 All-In-One InkJet Printer
Can not print from computer to printer
hi,
try the following:
> start-->run, type services.msc
> double click on print spooler and click on stop and then click on start. press ok and close all the windows.
> unplug the usb cable from the printer
> now go to control panel and open printers and faxes.
> right click and delete all the printer icons related to hp deskjet f300 series.
> now plug the usb cable back to the printer
> wait for few minutes while it installs the driver automatically.
> thats it... now try printing
thanks and regards
agnel
Mar 15, 2008 | HP Deskjet F340 All-In-One Printer
232 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
