Unable to login 198.162.0.1 IP address to setup wifi.
SOURCE: router unable to acquire ip address
logon into your router through n/w interface first (ethernet not wireless) using the default IP assignment of the router. Now you can manually assign an I/P to it.
SOURCE: cisco router 1841 connected to serial interface
Theres no need to setup for the nat but please check the wan interface and subnet mask ip it has to something else and not 255.255.255.252..Try 255.255.255.240 it must work...
SOURCE: Have D-Link G604T router/modem and want to connect
Dear,
I think this will help you
http://www.tp-link.com/support/showfaq.asp?id=151
SOURCE: disable Nat TP-LINK TL-WR1043ND
yeap it should be the firewall, here is the manual http://www.tp-link.com/resources/software/201161017075118.pdf
think this should help you.
But if you want my expertise, make the tp-link as a router and vdsl just the internet line. connect it to router wan and buy a switch for all your devices.That should be the safest and smartest way.
Testimonial: "Hi, I've finally found some time to test the dissabling the FW and I can say that in my case it helped. I can see now from TP-LINK IP cameras connected to the VDSL modem/router. Well done guys, thank you for your help. Kvinar"
