Question about Seagate FreeAgent Go 250 GB USB 2.0 Hard Drive
How i can get usb drive to startup disk - Seagate FreeAgent Go 250 GB USB 2.0 Hard Drive
    President:
  • 828 Answers
Download USB boot system... or USB bootable disk software
Posted on Jun 16, 2009
  • 157 Answers
You need to plug in the usb drive, then start the computer and go into the bios setup, by pressing del or f2 or f1 it should say when you turn it on. once in you will have a list of options, you need to look for boot device priority or something similar and move the usb hard drive to the top of the list. Note only newer computers will have this option. some computers will support pressing f12 when the computer starts up to select a different boot device.
Tip
How to format ur usb drives to ny format or to make it a dos bootable disk
U can use Hp usb disk storage format tool to format ur drive to any Partition such as FAT,FAT32,NTFS
this utility can be used to make window bootable usb setup and can also create ur DOS startup disk.
This utility can be found here:
http://en.kioskea.net/remote/download_get.php?ID=127
on Mar 29, 2010 | Computers & Internet
How can we create a start up disk?
If you want a MSDOS start up disk. 1. Go to Explorer 2. Locate a:/b: drive (floppy disk drive) 3. Format it and check the option to create MSDOS start up disk. If you want CD/USB XP startup disk. 1. It is free downloadable online.
Mar 12, 2011 | Microsoft Windows XP Professional
The motehrboard bios doesnt boot from usb to install windows, how can i update the bios to boot from the usb?
Insert your USB jump drive into a USB port on the computer containing the bootable program. Copy the information to your jump drive, then insert the drive into a USB port on the computer you wish to boot the program from.
Power on the computer. When the computer begins displaying its startup information, hit the key indicated on screen to enter the computer's BIOS (the "F1" or "Delete" keys are commonly used to access the BIOS).
Browse through the menu options in the BIOS to locate the computer's startup and booting options to locate the "CMOS" menu, which is where you'll have the option to set which devices will boot at startup.
Browse though the list of bootable option---they'll be ordered as "First Boot Device," "Second Boot Device" and so on. Set the USB jump drive as the first bootable option---your BIOS may refer to the drive as a "USB Removable Floppy Disk."
Save and exit the BIOS. When your computer restarts, your program will boot first before your operating system.
Feb 17, 2011 | Intel QDI P2PE/800 Pro 82845PE Socket 478...
Virus in my computer will nnt let me startup please help my email is iva.corley5@gmail,com
Download DRWEB Cure It save to a USB stick, boot to safe mode (F8) and run the programme from the usb stick
Feb 12, 2011 | Computers & Internet
My computer says there is no disk or please insert disk
disk, are you referring to a cd/dvd disc or are you reffering to a harddrive disk??? If you are reffering to a harddrive disk, then your hard drive is either damaged/ or inproper loose connection or if it s usb/network disk, make sure it is plugged or configuration is changed in the bios menu. If this is a harddrive disk, and after POST or startup, it is giving you this error message, then before we pressume it being damged, check in your bios menu to see if the bios reconized the hard drive disk, if not, your hard drive is damaged and needs to be replaced.
Jan 20, 2011 | Computers & Internet
No recognised on startup
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge guarantee".
Nov 17, 2010 | Iomega Prestige 1 TB USB 20 Hard Drive
Windows won't star up
If some startup foles are corrupted it might not start up. You can download a utility Active boot disk Make a bootable usb with it , then run a check disk on your c drive. If it repairs the bitmap sector your windows should startup
Jul 29, 2009 | ASUS Eee 4G Notebook
Partitioning lacie hard disk 2.0 500 gb
Windows XP: Right-click on "My Computer" and select "Manage". From there, select "Disk Management" which lets you view the drives and do things to. More details here...
If you're on Mac OS: Here's how
Mar 20, 2009 | LaCie Hard Disk 500GB with Hi-Speed USB2.0...
Seagate FreeAgent  Go 250 GB USB 2.0 Hard Drive Logo
115 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
