Question about Ovens
Digital readout comes up ''probe E E E E'' when we try to cook. it is a wall oven mod # w181
  • 6,784 Answers
The temperature sensor is malfunctioning. it is either damaged or, the sensor housing is faulty. you will need ot replace the sensor(temp) asap if possible.
Posted on Jun 16, 2009
We have a maytag oven. all the buttons work except for the bake and light button.Mod # umc5200aaw
only half of one side of the maytag oven touchpad control panel works, its one 2 yrs old help!
Jul 06, 2011 | Maytag 30 in. Electric Single Wall Oven...
Jenn Air Wall Oven W181 Thermostat
I have found the following message on GE Repair Help:
Tim
  • Refrigeraton Guru
  • Technician
xx.gif Re: W181 Oven « Reply #3 on: January 10, 2010, 03:46:04 PM » You need to measure the length of that probe. If its near 3 inches you need this one.
http://midwayparts.net/midwayparts/zen-cart-v1.3.8a-full-fileset-12112007/index.php?main_page=product_info&cPath=6&products_id=232
If its near 6 inches you will need this one.
http://midwayparts.net/midwayparts/zen-cart-v1.3.8a-full-fileset-12112007/index.php?main_page=product_info&cPath=6&products_id=233
These are replacement kits the original is no longer available. « Last Edit: January 14, 2010, 09:26:32 AM by Tim » I have already ordered the part and hope it will work. Best regards, Miro Bogavcic
Jan 31, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
Superba convection oven probe display problem
I had a similar problem today with my KitchenAid Superba wall convection oven (2002 model). I was roasting tomatoes at 225 degrees F for 3 or 4 hours when the control pad changed and showed that the probe was in use (never have I used it and had to look for it). I, too, tried to plug in the probe and take it out, but nothing changed. My worry was that I could no longer use the timed bake function. After trying to reset by turning off the oven at the breaker, with no change, I turned on the oven to 400 F and left it on for 10 - 15 minutes hoping that the high temperature would dry out whatever moisture that must have gotten in the place where the probe connects. Then I turned it off and just waited. After a half hour or so the control pad cleared and nothing showed (that is what you want when the oven is off!). Everything is back to working now.
Sep 08, 2009 | KitchenAid KEBC107 Electric Single Oven
Stove shuts off and posts F10 on readout
The F10 indicates that the electronic oven control board senses a runaway temperature condition in the oven through the oven sensor circuit.
This can be caused by a faulty oven temperature sensor probe or a failed electronic control board.
Oven temperature is detected by the control board as it monitors the resistance through the oven temperature sensor circuit.
You could have a failed oven temperature sensor, a wiring harness failure, an open thermal switch or a failed electronic oven control board that would cause this problem.
The first component to check would normally be the oven temperature sensor probe.
If you have a volt/ohm meter, you can shut off the breaker for the range and remove the screws that mount this sensor to the back wall of the oven.
Carefully pull the wire harness into the oven cavity until you get to the wire harness disconnect plug.
You should have enough slack to pull it this far into the oven.
Disconnect the sensor but do not let the wire harness retract back through the back wall of the oven or it will be hard to reconnect.
Measure the resistance of the oven temperature sensor with your volt/ohm meter. At room temperature, the resistance should measure around 1100 ohms.
The resistance chart is shown in the image below.
If the resistance is above 2200 ohms at room temperature, then the sensor probe is causing the F10 error code and will need to be replaced.
You can order a new sensor probe from the Sears PartsDirect website. The part number for the sensor is 316217002.
If the resistance is normal, then one of the other causes mentioned above is producing your F10 code.
You would need to access the electronic oven control board (Timer) in the console and check the resistance at the sensor circuit connection to the control board as the next step in troubleshooting this problem.
http://media.fotki.com/1_p,wbqdsfkrfqtswfqxgtqsskgwtqkq,vi/krdbrtqkgxkrbbqbrwb/1/1303472/5961857/image37801img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 30, 2009 | Whirlpool RBS245PDS Electric Single Oven
240V wall oven,digital readout and oven light come on but no heat
Bad clock assembly although the clock works the solid state switches internally typically go bad even on brand new ovens,does broil work,the top elements should work?
Jan 21, 2009 | Ovens
Kenmore Elite made by Frigidaire 30" slide in electric range model # 790.46603501 shows F30 ERR. Oven will not work. Range top is fine. Help!!! Turkey to cook!! Lynne
The F30 error code indicates that the electronic oven control board detects an "open" oven temperature sensor probe circuit.
This is usually caused by a failed oven temperature sensor probe.
Replacing this component will likely fix your problem.
You can order this part from www.searspartsdirect.com website.
If you replace this part yourself, be sure that you unplug the range to disconnect electrical power before accessing this component.
On some models, you can replace the probe by removing the screws that mount this component to the inside back wall of the oven.
Carefully pull the probe inside the oven cavity until you encounter the wire harness disconnect plug.
Unplug the sensor and replace it with the new one. Mount the new probe on the back wall of the oven.
On some models, you have to remove the lower back oven panel to access the sensor probe.
If you replace the probe and still have this problem, you will need to unplug the range and measure the resistance through the violet wires that plug into the control board (this is where the sensor probe circuit is connected to the control board).
If the resistance through the oven temperature sensor probe circuit is normal (about 1100 ohms at room temperature) then the electronic oven control board will need to be replaced.
http://media.fotki.com/1_p,wbwdqtgkkqdrrfgxgtqsskgwtqkq,vi/ktrrwffdrxkddstsrtq/1/1303472/5961857/image45310img-or.jpg
Nov 26, 2008 | Frigidaire FEB27S6DC / FEB27S7DC Electric...
Whirlpool Generation 2000+ oven
Yeah just turn the left hand knob to the one setting which isn't a cooking function - I think it looks a bit like a dash - and then power up as normal on the right hand knob.
It happpened to me but you get the hang of it and it's not a fault.
Sid
May 18, 2008 | Ovens
New oven won't work
cobrapilot sorry to be the bearer of bad news. Some where in the oven the contacts going to the oven probe are closing. This could be wiring going to the probe missing insulation and hitting the sheet metal, or the probe socket itself closed. I usually see this after the unit is in use, not right after install. Have you tried to cook a roast or such in the probe mode to see if it will work? For the oven may work just fine then. You are correct about your last line, until service resolves this issue, you have just an expensive microwave. Also as a side note, be sure an be there when the tech showes up. They may just try to say we need a part and not actually attempt to fix your unit. I am not sure what area you are in, however try Olson Appliance Service, He has a website, he is authorized Kitchen Aide service and maybe he can help.
Feb 03, 2008 | KitchenAid Architect Series KEMC308KSS...
Kenmore electric oven
Sears Kenmore Electric Wall OVen, Mod.#9114012192 purchased in 1993. Set oven for 425 degrees, reaches set temperature, stays on about 10 minutes and temp. display goes out and oven starts cooling down. Will not stay on desired temp.to cook. Can you tell me what my problem is? Thanks. Doug.
Dec 02, 2007 | Ovens
Ovens Logo
60 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
