Question about Kenmore Refrigerators
I have a kenmore coldspot 106.74259400 last night lost power and since then the fridge will not run. Lights and waterfilter work but compressor and fans not working. Cleaned out coils and drip pan 2 days ago and the condensor is cold to the touch and drip pan empty. No ice in freezer but back wall of it is cold. water was on the back shelf of the fridge unplugged for an hour replugged tryed dials and no good.
22yooper
  • 828 Answers
SOURCE: Kenmore Refrgierator is not cooling enough
Is the frost on the entire surface of the evaporator or just a portion. If it is only frosting on a portion there is a possibility your system has developed a leak and has lost some of the charge. Or your compressor has lost its ability to pump the gas. A bad condenser fan motor overtaxes the compressor and can cause premature failure. If it is a bad compressor it may be time to replace the refrigerator. Replacing the compressor is an expensive job and the warranty is only one year on a replaced compressor.
Posted on May 31, 2008
  • 117 Answers
SOURCE: condensation dripping from top of refrigerator
The problem is the defrost drain trough is plugged with ice. You will have to turn off the refrigerator, remove the freezer back panel and use a baby aspirator to help you apply and remove hot water to melt the ice. Then insert the aspirator in the drain hole to blow out any thing that may have gotten lodged inside. You will hear the water draining now to the pain underneath the refrigerator. Hope that helps you, good luck!!
http://tclaundryrepair.com/
Posted on Feb 25, 2009
  • 8 Answers
SOURCE: ice and water on the bottom shelf
the blower motor of your fridge which is located at the back panel of your fridge is not running
Posted on Mar 06, 2009
  • 531 Answers
SOURCE: WHIRLPOOL TOP FREEZER ET1WTKXKQ01. NOT COLD ENOUGH & KEEPS RUNNIN
remove the back wall leave the unit to run half hour open and see if coil have frost all the way from the top of the coil to the bottom if the coil is full you have adefrost problem could be your timer defrost thermostart or heater
Posted on Mar 31, 2009
Bat1956
  • 585 Answers
SOURCE: drip pan needs emptying; had repairman out for other issues, now fridge keeps overflowing
The accumulated ice you saw is of course the source of the water. The refrigerator will eventually rid itself of the excess ice and the problem will therefore disappear on it's own after a while. The drip pan is normally filled with only a small amount of water, and that is dried up by the condenser cooling fan under the fridge. The pan is removable from most units, but not without making a mess. I suppose you can make and clean up the mess one time and be done with it.
Posted on May 20, 2009
Kenmore coldspot 106.53769202 will not cool fridge, have deg=frosted,vacuumed underneath and emptied drip pan, no air blowing into fridge. Had gnats inside while power was off for over a month.
Does the compressor run? Does the small tube get warm? is the inside fan working? does it have an outside condensor fan? Is power getting through the thermostat due to gnats between the contacts? Does the inside light work? need more info.
Oct 16, 2013 | Kenmore 50522 / 50524 Side by Side...
Kenmore coldspot not working properly after power outage
I am glad you made it thru the storm OK. I am in New Orleans and I am no stranger to what you guys went thru.
First, are you sure the compressor is running?
Post back to me.
Nov 02, 2012 | Refrigerators
Kenmore Coldspot 25ssa. After power outage the refrigerator trips breakers and GFCI
Either the compressor or the start device on the compressor is shorted out. More than likely the compressor, hate being the bearer of bad news
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 07, 2012 | Kenmore Refrigerators
Hello I have a kenmore coldspot side by side that just stopped working last night. The fridge and freezer are now warm. Does anyone know what this might be and how I may be able to fix it? I am not...
check the relay switch on the side of the compressor. remove it and shake it if it rattles it needs to be replaced. also make sure the condesor coils under fridge are free of lint buildup.
Feb 28, 2011 | Refrigerators
I have a Kenmore Coldspot m# 57282791. Last night, it stopped staying cold, and I have not heard the motor/compressor come on at all since then (the part that cools the fridge, right?) There is a small fan...
If the compressor is not running, it could be either a bad relay or compressor.This is not an issue with defrost components or temp. control .If you have experience in repairing appliances, could take all precautions necessary and use multimeter - You could do a continuity check on compressor motor and all combination's. An infinity value on multimeter would confirm bad compressor.
On the side of the compressor you will see a box (maybe a cover) remove the cover if it has one and then remove the wire harness. next you will see the relay with the capacitor mounted to it. give the relay a tug and pull it off the side of the compressor. once you have it off pull the capacitor off and then give the relay a shake. If it rattles the relay is bad. if the relay does not rattle the compressor is bad and you will need to call a service guy to replace the compressor.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jul 10, 2010 | Kenmore 57029 Side by Side Refrigerator
Kenmore Coldspot model 106 - Snowing in freezer!
its not defrosting. check heater operations. bimetal near heater. check defrost timer
Feb 08, 2010 | Refrigerators
Refridgerator will not run
if it have a thermostat it can be your problem
Jun 16, 2009 | Kenmore 64802 Top Freezer Refrigerator
Kenmore coldspot
HI.
i guess u will benifit from this link
plz rate this post
click here
BEST REGARDS
Aug 11, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
FREEZER NOT FREEZING AND FRIDGE NOT GETTING COLD
First check to see if your compressor is running at all. If your compressor is at room temperature you cold control is not supplying power to the compressor. Replace the control or locate the defrost timer and rotate the clutch head screw ( Normally black or Grey) and rotate it a small amount clock-wise. If the compressor then starts replace the defrost timer.
Apr 12, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
113 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
